These springs suck...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by onesojourner, Mar 9, 2016.
  1. Mar 9, 2016 at 10:46 AM
    onesojourner
    onesojourner [OP] Well-Known Member
    The Ozarks
    I hauled a little mulch the other day and I could not believe how much it squatted this thing. I only had about an inch from the stops and they easily bottomed out if I bounced on the bumper a little. There is know way that this can handle 1200#s in the bed. I bet this mulch didn't weigh 300#s.
  2. Mar 9, 2016 at 10:48 AM
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    I've had almost 1000 pounds in the bed with my Dakars and it barely squatted..now that I have a shackle flip, I bed it wouldn't sweat it.
    scottalot likes this.
  3. Mar 9, 2016 at 10:51 AM
    AZBACKCOUNTRY
    AZBACKCOUNTRY Well-Known Member
    Doug
    AZ-between the hammer and the anvil
    11' AC TRD OFF-ROAD 4x4
    Pelfreybilt front aluminum bumper,AVID off road weld on sliders, RCI Offroad IFS & transmission Skid (steel), RCI LCA skids (aluminum),upper grillcraft, relentless hi clearance bumper,OEM color matched front grill color, ARE MX camper shell, wet Okole realtree seat covers,pelfreybuilt hi lift mounts,ICON 2.5 Coil-overs extended,, ICON tubular UCA's. Allpro expo leafs, SS extended brake lines.Bilstein 110 extended rear shocks.prinsu Cabrac.dwreck pod mounts OKLED 18w cubes.Baja Designs Squadron-R Sport, LED Wide Cornering, Ambers fog/driving 20" IGGY LED Single Row bar.tepui awning,rotopax 2 gallon, TREDs and mount , 100 watt renogy solar panel.victron 20 amp Bluetooth charge controller,Pro comp wheels - cooper st maxx 285/75/16 tires. Skygear bussman fuse relay smart box. ARB 12v plug hard wired for ARB fridge. Pelfreybilt gas tank skid. Smittybilt X2O 10K winch
    All pro expos here, never going back to stock junk.
    Az
    ChadsPride likes this.
  4. Mar 9, 2016 at 10:53 AM
    KeithB
    KeithB Well-Known Member
    Keith
    Cheshire, CT
    SWB '09 Tacoma DCSB Sport 4x4
    Wheels and Tires: 17x8" Ultra Goliath wheels with P285/70R17 Falken Wildpeak AT3/W tires, Suspension: Fox coilovers set at 2", TC UCA's, 1.5" lift 3 leaf pack with overload left in Other: TRD SS exhaust, Pioneer AVIC 4100 H/U with Android Auto (awesomeness), sat radio bluetooth, Accessories: Toyota roof rack, black Toyota running board steps, cargo divider, weathertech floor liners, Literider roll up soft tonneau, thule bars over tonneau, USB ports front and rear, seat heaters, birddawg mirror riser Cosmetic: window tint, grillcraft black mesh upper/lower grill, vinyl armrest in doors, Clazzio black seat covers with blue stitch, Redline steering wheel wrap Lighting: fogs only mod, back up lights, amber interior accent lighting, amber 10" LED light bar in hood scoop, 33" LED bar behind the lower grill, amber lamin-x on fog lights, Tacomabeast headlights and matching tails.
    Mulch is heavier than you think. Figure a 2 cubic foot bag weighs about 20 pounds. I've had 40 bags in the bed to about the equivalent volume that your picture shows. That's 800 pounds. It did squat down quit a bit but did not hit the bump stop. I have firestone riderite air bags now to compensate for the occasional heavy load.
    On second thought, maybe my memory is off a bit. Just did a calculation on the bed volume and got 37.5 cubic feet for a 5' bed. No way I had 80 cubic feet in there. Maybe it was 25 bags (50 cubic feet - so above the bed rails) or 500 lbs.
  5. Mar 9, 2016 at 10:58 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Get some 4 leaf packs from someone that has changed theirs out. A regular cab is much better suited to the oem 4 leafs than an access or double cab is. I got 3/4" lift from some 5k 4 leafs and no sag hauling stuff, no axle wrap & way way less body roll cornering. They may not last forever depending on how often you haul/tow but they are huge improvement for reg cabs over the sad ass 3 leafers. Of course, all the non-oem options will do the trick for a stack more jack.
  6. Mar 9, 2016 at 11:01 AM
    cj13058
    cj13058 Well-Known Member
    Oregon
    2024 Tacoma TRD Off-Road Premium iForceMax Bronze Oxide
    2024 Tacoma TRD Off Road Premium iForceMax Bronze Oxide - AluCab Contour canopy 2005 Tacoma TRD Off Road DCSB Radiant Red - ARB 3'' lift, ARE canopy, 265/75/16 All Terrain KO2, after market stereo, ECGS differential bushing, ARB Deluxe front Bumper, Warn M8000 winch, custom winch control box install, FrontRunner Slimline canopy rack,
    I woudln't say they suck, but they are pretty wimpy. Upgrade with a Dakar leaf pack and you'll be good to go...but your comfy squishy ride will be gone.
  7. Mar 9, 2016 at 11:02 AM
    ChadsPride
    Sponsored by TacomaWorld.com
    My PreRunner feels like a low rider after 1.5yrs of ownership. Can't wait to put some now coils and leafs on it. Coming up with the $$$ is the only issue!!!
    Tatts521, AZBACKCOUNTRY and scottalot like this.
  8. Mar 9, 2016 at 12:32 PM
    KeithB
    Keith
    Cheshire, CT
    Keep the oem spings and add Firestone Riderite air bags. They are the way to go. Retain soft ride and eliminate sag with heavy loads. Best of both worlds.
  9. Mar 9, 2016 at 1:32 PM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    If they were ever cheaper than $250 I'd certainly grab some. That $250 just hasn't reached the top of the mod priority list for the truck yet. Those or the other things like that......Timbrens, yeah Timbrens.
  10. Mar 9, 2016 at 1:47 PM
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
    If it can be said, by how much do Dakars improve payload?
    Or does it just allow the truck to handle loads better? I understand that frame and chassis strength plays a big role in that outside of suspension.
  11. Mar 9, 2016 at 2:03 PM
    cj13058
    Oregon
    From what I understand, it does increase the payload capacity. How much exactly I cannot remember.
    Hiluxs (non North American Tacomas) come with a different leaf pack than we got. It rides stiffer and I remember seeing somewhere that they payload capacity was slightly larger...bu like 100 lbs or so.
  12. Mar 9, 2016 at 2:03 PM
    Kyitty
    Kyitty Mr. Beard
    Bozeman, MT
    2015 Tacoma DCLB Better Than TRD
    See Build Page
    Yeah I've put 400lbs of boxes in my bed with my Dakars and not noticed a difference at all.
  13. Mar 9, 2016 at 3:58 PM
    calico
    calico Well-Known Member
    Northeast
    13 Tacoma Limited
    Viper Alarm and Remote Start Prestigious Society mod Camera display relocated to headunit Weathertec floor mats, window deflectors, and mud flaps Toyota Bed mat Tailgate lock Undercover SE tonneau and Swing Cases (driver and passenger) Hi-lift install Fumoto Qwik Valve ImMrYo Mirror mod Salex console organizer
    I've wondered is it the leafs themselves that suck, or the way they are mounted. I remember when I first saw mine they looked almost inverted and I thought something was wrong with them. The service manager showed them to me when they put the truck on a lift. The way they were mounted I could see why they were in the flat shape they were in.
  14. Mar 9, 2016 at 6:47 PM
    steelhd
    steelhd Well-Known Member
    Eastern WA
    2011 DCSB TRD OR
    They suck. Toyota correctly calculated that the average American, and the average American automobile "journalist", are both far more interested in experiencing a car like ride going to the mall than having the advertised payload capacity. So they put shitty weak springs in the rear and only a minority of owners ever noticed because we actually use our trucks as trucks. If you did notice within the warranty period and said the super secret code words (rough ride under load) to the dealer they would grudgingly install the four leaf pack that came standard on Canadian Tacos. Even that wasn't much of an improvement but it was something.
    calico[QUOTED] likes this.
  15. Mar 9, 2016 at 6:55 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Not on the bumpstops
    jmd025, ChadsPride and Marty65 like this.
  16. Mar 10, 2016 at 6:13 AM
    GroupW
    GroupW Well-Known Member
    Mark
    Arizona
    Red TX
    3 inch lift with Toytec Boss and All Pro UCA's up front. AP expedition leafs with Bilstien 5100 shocks in the back. 255/85/16 Cooper S/T Max tires. All Pro skids, rear bumper and sliders, Hidden winch mount with XRC 8000 winch. Dual Optima batteries with IBS combiner/isolator and solar. CMC. Auto sliding rear window mod, hidden CB, CVJ axles and plenty of other little mods.
    I guess that if you're thinking of changing springs you have to decide what you want your truck to do. Carry loads, work better off road, or look better. All valid. I've had OE springs - suck all around, Dakars - way better load carrying, good lift and tougher than nails but (IMHO) rougher than a cob off road and definitely reduced rear axle travel (2-3 inch lift with stock length shocks), and currently AP expos. My last vehicle was a modified Land Rover, so I'm kinda partial to the soft "coil-spring" feel and tons of articulation so my favorites so far are the AP's. More leafs equals more supple ride, and more drop so you maintain suspension travel with the lift. Only downside so far is RUST! I hate friggin' rust!
    Air bags are great for carrying weight, but unless you valve them so that they work independently, they seriously restrict up-travel and will limit your off road performance...but I guess that's why god made lockers.
    If you just want to look better...who cares. Buy something cheap.
    Personally, I'm waiting for a coli-sprung, 3 link mod! Ahhh... Suspension!
  17. Mar 11, 2016 at 6:55 AM
    neverstuck
    neverstuck Well-Known Member
    Guido
    Lebanon
    13 DCLB sport
    slide-in camper, OME Nitros w 884's and Dakars, Michelin A/T2, Pro EFX heated towing mirrors, Timbren HD bumpstops, KB VooDoo bed rails and tailgate cap, ImMrYo rvm bracket, G-Tek Fab door sill protectors, Ultragauge, window visors, hood deflector, Wet Okole seatcovers, in-vehicle safe.
    @onesojourner I think the axle tube plays a big role in payload as well. As I understand it they will flex and blow a seal.
    I have Dakars and they only squat about 1.5" with 1000 lbs but unless you're looking at totally changing your suspension front and back forget the Dakars. If you just want to be able to haul the odd thing from Home Depot or whatever, swap for the 4 leaf OEM pack which you can probably get for next to nothing used... or add some Timbren SES bumpstops. product # TORTUN4 or TORTUN4L for a softer lighter duty version.
