They crashed, bumped my truck unloading it at the dealer about a month ago. I noticed a wobble
Discussion in '3rd Gen. Tacomas (2016-2023)' started by beakerthemuppet, Feb 14, 2022.
  1. Feb 14, 2022 at 4:13 PM
    beakerthemuppet
    beakerthemuppet [OP] Member
    So I collected it about a month ago. The bumper protector is scratched so they said they will replace it when it’s in stock. Since picking it up I w had a chance to inspect it a lot more. The front left gap on the bumper is closed, the rear right fender flare has been bent. So there’s a gap in it where the sealant has stretched. I noticed the front Toyota badge had a small gauge out of it. I also noticed at 45-60 kms it seems to wobble back and forth. Is it likely that the chassis is damaged or more likely just a wheel balance that’s off? I’ll be taking it in to them within a few weeks but I’m hoping that they haven’t overlooked any serious damage that might have occurred during delivery. Even though the gouge on the Toyota badge at the front isn’t noticeable unless you go really close to it, I’m tempted to mention it and maybe see if they need to change the grill then if they will offset the cost on an oem pro grille.
  2. Feb 14, 2022 at 4:32 PM
    Grossomotto
    Grossomotto Complete 3rd Member
    39.9526° N, 75.1652° W
    2017 4WDV6LB6MT
    Welcome to TW. I'm of the opinion your truck is all set (not crashed).
    I'd drive that rig to Ottawa and back
    hiPSI likes this.
  3. Feb 14, 2022 at 4:50 PM
    beakerthemuppet
    Hey thanks. I’ve being lurking for a long long time. They definitely crashed it though. They admitted it and I can see some damage. I love the truck. I was just wondering if the wobble and the incident could be related. I doubt it but stranger things have happened.
  4. Feb 14, 2022 at 4:57 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Fix the scratch and move on. Sometimes a scratch is... just a scratch.
    Check your tire pressure. When a truck is new it sometimes does new things. Give it a week.. or month.
    9th likes this.
  5. Feb 14, 2022 at 6:02 PM
    beakerthemuppet
    I am. It’s been over a month. It wobbles a lot on the highway at higher speeds. It’s almost shakey.
  6. Feb 14, 2022 at 6:11 PM
    Benny blanco
    Benny blanco Mr. Jiggletits
    Ben Day Ho
    Whoville<>Trollhättan
    21 Cement TRD OR MT
    Some stuff
    You have to post pics so we can all judge wether or not it will be ok or parted out. Tw rules
    BudFriendguy likes this.
  7. Feb 14, 2022 at 6:12 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    What vehicle did you have before the Tacoma?
  8. Feb 14, 2022 at 6:33 PM
    xndak
    xndak Well-Known Member
    2023 Off Road
    Lots of new vehicles are either not aligned properly during manufacturing or it gets out of whack during shipping, etc. My new 18 offroad was well out of spec when I took it to an alignment specialist shop.
  9. Feb 14, 2022 at 6:45 PM
    mabepossibly
    mabepossibly I know enough to make an ass of myself
    Andrew
    Albany, NY
    2021 TRD OR Manual
    Skids, Sliders, Lights
    It’s worth taking it to a good body shop and having them give it a once over and putting it on a frame machine. If they find nothing you spent $200 on your own piece of mind. If they find something, you have something to go back to the dealership with.
    ndoldman59 and b_r_o like this.
  10. Feb 14, 2022 at 7:43 PM
    2020SilverSky
    2020SilverSky Well-Known Member
    Seattle. WA
    2020 TRD Off Road 4WD 6MT
    If it was damaged... "crashed" sounds a bit dramatic... bad enough to cause drivability issues, there would be much more damage than some scratches. Personally, I would start with checking to make sure tires are all balanced. Those weights pop off all the time.
  11. Feb 14, 2022 at 9:40 PM
    Benny blanco
    Ben Day Ho
    21 Cement TRD OR MT
    Some stuff
    You’re right, but a good body person will see defects in everything. I’ve seen those guys point out stuff most wouldn’t even see.
  12. Feb 14, 2022 at 9:45 PM
    Kyle_
    Kyle_ A guy and his expensive hobby
    Kyle
    SoCal (805)
    2021 TRD OFF-ROAD 4X4 DCSB
    @tacoma.kyle on IG
    Genuinely wondering, if you were concerned about it when you picked up the truck, why did you sign and accept delivery of it?
  13. Feb 14, 2022 at 10:36 PM
    Benny blanco
    Ben Day Ho
    21 Cement TRD OR MT
    Some stuff
    Hah. My bet is op wanted the taco
  14. Feb 15, 2022 at 7:34 AM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    Time to part it out, if crashed that bad.
