Thickest Strut Spacer without changing studs?
Discussion in 'Suspension' started by DLillest, Jul 11, 2019.
  1. Jul 11, 2019 at 6:31 AM
    DLillest
    DLillest [OP] Well-Known Member
    Quebec, Canada
    2007 SBM DCSB 6MT 4x4
    I'm looking to level my truck 1-1.5" in the front, but also correct the Taco Lean at the same time.
    I was thinking of upgrading my oem 2nd Gen front suspension for some 3rd gen Offroad Bilsteins. This should give me my 1 inch of lift. Plus add a 1/4" or 3/8" spacer on the drivers side.
    My question is, to correct the Taco Lean, how thick of a top spacer can I add before I would need to change out the studs bolts for longer ones? is a 3/8" or 1/2" spacer too thick?
    For some context, I don't really take my truck offroad, its mainly used for towing a boat to the cottage, hauling reno supplies on the weekends and taking the kayak down to the river.
  2. Jul 12, 2019 at 8:38 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    3/8”. 1/2” you’ll need longer studs.
    DLillest[OP] likes this.
  3. Jul 12, 2019 at 8:39 PM
    gotoman1969
    1/4” non issue
  4. Jul 13, 2019 at 10:45 AM
    01 dhrracer
    01 dhrracer Well-Known Member
    Palm Desert/Bermuda Dunes
    Still Shopping
    Just to be clear a 1/4" spacer will provide approx. .440" of lift.
  5. Jul 15, 2019 at 6:27 AM
    DLillest
    Quebec, Canada
    Thanks, I already purchased a 1/4" spacer that I haven't put on yet. I was wondering if a 3/8" spacer would fit without swapping out the studs. I don't want to disassemble the strut assembly.
    Agreed, thanks for confirming. I was contemplating adding a 3/8" spacer for just a slight extra 1/4" lift. Just wanted to make sure I have enough clearance without changing out the studs.
