Thin ass tailgate panel?
Discussion in '1st Gen. Tacomas (1995-2004)' started by taco terror, May 27, 2013.
  1. May 27, 2013 at 11:25 AM
    taco terror
    taco terror [OP] 1st gen = best gen
    USA
    1996 Black Tacoma, 3.4L
    4.56 ECGS regear, Wheelers 6 leaf pack, Eibach coils, Bilstein 5100s, AR Baja wheels, 33 BFG ATs, Line-x
    My Grandpa installed a rubber mat on the tailgate via screws years before I got it. I finally took it off today because I am getting ready to get a spray in bedliner and noticed that the screw on panel was dented all to hell. I took off and its like a piece of fuckin tinfoil.:mad:
    does anyone out there make a thicker replacement that I can get sprayed with bedliner and put that on instead?
  2. May 27, 2013 at 7:07 PM
    taco terror
    USA
    any Juan?
  3. May 27, 2013 at 9:38 PM
    TacoDell
    TacoDell Truck ~n~ Tow
    SoCal
    '00 Tacoma SR5 4X
    Donahoe CO's, Deaver leaf paks, Lockright Locker, All Pro body armor ( sliders, front and rear bumpers ), All Pro under belly skids, Warn M8K w/Masterpull synthetic line, Dual Optima battery system, 4 ea LightForce Striker 170 offroad lights, 8 ea wired rock lights, and plenty more I'm sure
    doubt you will find any thicker access plate then what is.
    wish there was tho'
    thought I read they sell for near $ 25. new (likely primer)
    prolly locate one cheaper at a salvage yard...
    or... you can just beat yours back into shape ;)
    The center square is the most critical of the others...
    because if dented too deeply...
    It can sometimes hit the T-gate's latch handle (internally)
    and that can push the latch handle outward some.
    I've read of a few home brew reinforcement mods concerning...
    But nothing that is without weld / fab work.
    I hammered mine back out...
    and now pay more attention to my knee's placement
    when crawling over the tailgate.
    Eventually I plan to cut out the centers of each square
    and weld in a new thicker plate.
    or maybe I'll locate another access panel...
    and cut the squares out of that...
    and weld those up making a double wall.
    meh... I really haven't thought it thru
    just know I'm tired of beating that panel straight.
    I've seen folk run a full width/height tailgate cover plates...
    ie: made diamond plate or the like
    or the tailgate cover that comes with the plastic bed liners.
    Those might minimize that bending some.
  4. May 27, 2013 at 9:54 PM
    Loggerhead
    Loggerhead Well-Known Member
    Seán
    Alaska
    2002 SR5 TRD 5spd 3.4 Xtra Cab
    Getting your bed sprayed helps some. Mine feel slightly sturdier with the rhino lining on them, although I still wouldn't drop anything heavy or intentionally put a lot of weight on one of the access panels though . . .
  5. May 27, 2013 at 10:24 PM
    cjrichmar
    cjrichmar Active Member
    CJ
    SoCal
    07 Crew Cab
    Tailgate Mod BHLM D-Ring Install LED Interior Lights Bakflip G2
    Lots of people have complained about the weakness of the tailgates. There are several topics that discuss the issue, to include:
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/29117-weak-tailgate-reinforcement-solution.html
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/78315-my-tailgate-reinforce-project.html
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/136618-how-im-fixing-my-flexy-tailgate.html
    Personally, I bolted some angle iron on the inside of the tailgate and installed a replacement panel from Relentless Fabrication, they run about $150. I've since put 400 and 450 lbs motorcycles in the back of the truck with no problems multiple times.
