Things I can't figure out on my own.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TRDTaco420, Mar 15, 2023.
  1. Mar 15, 2023 at 10:17 AM
    TRDTaco420
    TRDTaco420 [OP] Chum is Fum
    The Bear
    Tacoville - Canada Eh!
    2019 Mid. Blk. Met. ACLB TRD Off-Road
    Kewl shizz
    General questions about my 2019 TRD off road.
    Is it my imagination or is my truck pulling to the right? Any way to tell before taking it to a place and getting an alignment which of course they will tell me I need because they're in the business of making money.
    Second issue is a picture of the window when I hit the auto down button it halts once in a blue moon at that position, has anybody ever had this occur?
    Last item is my lighting, when I engage the high beams, the fog lights shut off. Is there a hack to keep them on as well as the high beams?
    Thanking all you experts in advance.
    HondaGM likes this.
  2. Mar 15, 2023 at 10:20 AM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    Fog lights should cut off on high beams..when have you had an alignment?
    is the window binding in the run channel..,looks like there tinted also
  3. Mar 15, 2023 at 10:23 AM
    TRDTaco420
    The Bear
    Kewl shizz
    And the fog lights do shut off, the point is I want to keep them both on.
    When I'm in the middle of nowhere and there's no lights I want everything on so I have daylight in front of me.
  4. Mar 15, 2023 at 10:24 AM
    23TacoSR
    23TacoSR Well-Known Member
    Why would you use your high beams with the fogs?
    burnttaco7, Dfpftw, 9th and 5 others like this.
  5. Mar 15, 2023 at 10:24 AM
    23TacoSR
    Ummmm, don't all of those lights do the job?
  6. Mar 15, 2023 at 10:26 AM
    Clearwater Bill
    Billy
    Largo Florida
    Not sure. Let me check......
  7. Mar 15, 2023 at 10:27 AM
    HondaGM
    James
    South-Pole, Alabama
    2023 access cab V6
  8. Mar 15, 2023 at 10:29 AM
    TRDTaco420
    The Bear
    Kewl shizz
    If only Karnak was my mechanic...
    Also I'm not going to blind Captain Kirk but I want to blind the trees in front of me when I'm off-roading.
  9. Mar 15, 2023 at 10:31 AM
    HondaGM
    James
    South-Pole, Alabama
    2023 access cab V6
  10. Mar 15, 2023 at 10:32 AM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    If you drive on a flat level surface, let go of the wheel, and the truck steers to one side or the other, that is what is called pulling. It can a result of alignment, tires, suspension component wear, or other things, but is usually caused by alignment.
    The window behavior is normal. You can roll down the window part way or all the way.
    I didn't know the fog lights turned off when the high beams are turned on, but that make sense to me because the high beams would defeat the purpose of the fog lights. Why do you want to use them together?
  11. Mar 15, 2023 at 10:33 AM
    Exfordman
    Exfordman Well-Known Member
    Norman
    2021 Tacoma TRD OR 4X4 LB White
    None
    Many vehicles will drift right due to a road crown which can be very slight. Also on rare occasions a tire can cause a pull. That's verifiable by swapping front tire positions.
  12. Mar 15, 2023 at 10:33 AM
    23TacoSR
    Okay, I know it's Friday somewhere in the world...
    wilcam47, Stevie17, HondaGM and 4 others like this.
  13. Mar 15, 2023 at 10:35 AM
    TRDTaco420
    The Bear
    Kewl shizz
    Yeah most of the roads are sort of banked I guess for drainage so I got to find a flat road to test that.
    As for the window when you push all the way down on the switch it should lower without stopping just the passenger side stops at that point which is weird to me.
    And as previously mentioned, I want to use the high beams and fogs pointing forward to give daylight ahead when I'm in the middle of nowhere.
    Stevie17 and HondaGM like this.
  14. Mar 15, 2023 at 10:35 AM
    Tacoma Rant
    Tacoma Rant I can’t be good all the time.
    Wisconsin
    2023 Tacoma TRD Sport Electric lime
    I had another car that the windows would stop halfway down sometimes. It ended up being what the other person posted. You just need to clean the track that the window rides in. No need to remove the door panel or anything like that, just clean the part where the window rides up and down in.
    HondaGM and TRDTaco420[OP] like this.
  15. Mar 15, 2023 at 10:39 AM
    HolyReptar
    HolyReptar Well-Known Member
    Bry
    Thousand Oaks
    17 TRD Offroad 4x4
    Some Bolt ones here and there
    1. Getting the Alignment checked is free do that first.
    2. The window does have a stop feature so you can set it to the exact position you want it down at. Press it once quick it should go down all the way and press again to stop but a longer hold the auto down feature gets canceled and it stops where you let go.
    3. That is a safety feature now a days, there is mods you can do to change it so that highs and fogs are on all the time. I was just looking at one myself for SnGs but you have to do some wiring and adding a switch which to me is overrated.
  16. Mar 15, 2023 at 10:39 AM
    HondaGM
    James
    South-Pole, Alabama
    2023 access cab V6
    Put some Ultra Glide in that window run and see how she works....
    Stevie17 and TRDTaco420[OP] like this.
  17. Mar 15, 2023 at 10:39 AM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
  18. Mar 15, 2023 at 10:40 AM
    in2seconds
    in2seconds Well-Known Member
    Edmonton, AB
    2021 TRD Offroad Premium
    Per regulations, high beams and fog lights CANNOT be turned on at the same time. If you want to accomplish this then you'd have to run a switch for the foglights independently.
  19. Mar 15, 2023 at 10:44 AM
    wmdpowell
    wmdpowell Well-Known Member
    Bill
    Essex county NY
    23 trd OR DCSB 4x4 silver
    a cross on my rearview Circle mirror Scotch guard seats
    Some states have law that says you have to turn off fogs when high beams on. You might be able to wire your way around that .
    LeakyAC and TRDTaco420[OP] like this.
  20. Mar 15, 2023 at 10:45 AM
    TRDTaco420
    The Bear
    Kewl shizz
    Thank you for your most useful contribution.
    wilcam47 and HondaGM like this.
