Things to look for in new truck
Discussion in '1st Gen. Tacomas (1995-2004)' started by fireturk41, Nov 24, 2013.
  1. Nov 24, 2013 at 6:08 PM
    fireturk41
    fireturk41 [OP] I like to break shit!
    Kevin
    High Point, NC
    280k miles
    SAS, Locked front rear, Ufab sliders and bumpers, air compressor, 35" BFG KM2 on steelies and 36" TSLs
    well as many of yall know my truck is up for sale, I found someone with an 02 4cy interested in trading. Im usually on the other side of this question but as we all know you tend to get tunnel vision when youre interested in things like this. but what should I look for and inspect im very mechanically competent, also any particular issues that plague 4 cyls?
  2. Nov 26, 2013 at 10:26 AM
    Hawaiian05
    Hawaiian05 Well-Known Member
    Tony
    Boise, ID/ Hawaii
    2021 Army Green TRD OR 6mt/ 2002 4Runner Sport
    I won't point out the obvious things, given you are mechanically inclined (based off your Sick build!). But there are a couple things I've noticed over the years with the 4 cyls, 2.4 or 2.7. One thing is that they tend to need a valve adjustment at certain intervals, but I'm not sure of the specific timeframe/guideline. I also know that some never complete the valve adjustment and are still running strong.
    Another thing I've seen on a few occasions, though a little rare, is the overtightening of the belts, causing premature wear on the bearings. The first sign that I've seen with these is abnormal engine sound, but not too distinct if very minor wear. Again, a little more of a rarity, but seen a few.
    Other than that, those 4 cyls are supposed to be pretty durable motors. In addition, the maintanence is simple on those (fluids, drive belts (t-chain driven), and spark plugs), with the exception of the messy oil change (due to filter location).
    Hope you find what you're looking for.
  3. Nov 26, 2013 at 11:06 AM
    fireturk41
    Kevin
    High Point, NC
    280k miles
    That's the good thing about the 3.4 my oil change is super simple. So other than the basics main thing I hafta check is valve adjustment and belt tension/bearings
    Do the manual trans have any issues known with them?
  4. Nov 27, 2013 at 8:13 PM
    Hansel
    Hansel Well-Known Member
    Glenn
    Arizona
    base
    never heard anything negative about the manual or auto tranny in these trucks.
