Think I bought the wrong wiring kit?
Discussion in 'Audio & Video' started by bowhuntingaddict, Jun 9, 2011.
  1. Jun 9, 2011 at 8:54 PM
    bowhuntingaddict
    bowhuntingaddict [OP] Well-Known Member
    I just bought a hifonics brutus 1700.1 amp, and the wiring I bought for it is an EFX 4-gauge Amplifier Wiring Kit. I don't know too much about all of the wiring so I was wondering if this wire is too small. The other question I have is about the fuse. The amp"s fuse rating is 160A and the wiring kit comes with a 100A fuse, and I was wondering if i could just use a different fuse for it. I think I screwed up on this one, but I'd appreciate any advice.
  2. Jun 9, 2011 at 8:57 PM
    Toyota Tacoma
    Toyota Tacoma Well-Known Member
    Brady
    Kelowna, bc
    dbl cab long box
    Suspension: -Bilistien 5100's all around -Add a leaf -Firestone ride rite air bags Performance: -K&N cold air -Borla cat back Stereo: -Pioneer AVH-X2500BT head unit -Kenwood 1400 shallow mount 12'' sub in custom box -Alpine 1100 amp -Alpine 400 4 channel -4 energy component 6.5's Wheels/tires: -17x9 with 4.5 backspacing XD hoss rims with 33'' bfTreadwright gaurd dogs and spidertrax spacers Looks: -Satoshi grille made by myself -Hood, front bumper, grille, roof, tailgate and rear bumper plasti-dipped. -BHLM -eyelids -matted out tailights -Tacoma bed mat Small mods : -Trailer 7 pin replaced and moved into bumper beside licence plate -Removed mud flaps -Repainted frame/lower a-arms, skid and rear diff/housing with por15 -Led bulbs -Interior lights replaced with blue led's -Beep on lock added
    you could get away with using it, i am running 2 ken-wood 1100 watt amps off 4 gauge and a larger fuse with no problems
  3. Jun 10, 2011 at 5:48 AM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    What are the chances that you would actually push it past 100 amps though? That is a sheeite-ton of wattage equivalent! You must like a bit o' blood leaking from your ears :)
