think i can tow skid steer?
Discussion in 'Towing' started by countryboy22, Jul 22, 2012.
  1. Jul 22, 2012 at 1:03 PM
    bash42
    bash42 Well-Known Member
    Eastern PA
    '22 DCLB TRD OR Super White
    You act like he is towing a 40 ft camper. This is just above the tow rating for the vehicle, as long as he drives smart he will be ok. Manufacturers put tow ratings on vehicles knowing that the owners will push the limits.
    As long as you have the tow package and are a responsible driver then you should be ok. Just be careful of the brakes, probably a good idea to put on a brake controller, they are very cheap.
  2. Jul 22, 2012 at 1:06 PM
    bash42
    Eastern PA
    any time you walk out your door you risk an accident. Relax, he's not trying to tow 10,000 lbs. he is right at his trucks limits.
  3. Jul 22, 2012 at 1:06 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    That setup weighs about the same as an empty 40' camper (7,000 lbs)... The load and trailer is small but very heavy, which is where the potential problem lies. The physical size isn't the issue here.
  4. Jul 22, 2012 at 1:08 PM
    Pugga
    Massachusetts
    That's the most ridiculous thing I've heard today, thanks! :thumbsup:
  5. Jul 22, 2012 at 1:09 PM
    bash42
    Eastern PA
    understood.....but you don't have to deal with the wind resistance of a 40ft and the unbelievable awkward turning etc of that big of a camper. The put the weight limit where it is because they know people will push it. Just look on the forum at what others are towing short distances. Just drive safe and be smart.
  6. Jul 22, 2012 at 1:09 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    He hasn't said if he has a tow package or not, and even if he does, if he doesn't have a brake controller, he's not going to buy and install one TODAY... which is when the Bobcat is to be returned... and it's going to cost more than having RSC pick it up.
    Without a brake controller, he has no trailer brakes unless they are self-contained.
  7. Jul 22, 2012 at 1:12 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Wrong-They put a weight limits based on engineering life spans and capability of components...so when you start free styling because "they know owners will push it" - You are taking the truck outside the designed limits and hoping that it holds up...Noy a smart gamble IMHO.
  8. Jul 22, 2012 at 1:12 PM
    Pugga
    Massachusetts
    No, I'll give you one more guess...
  9. Jul 22, 2012 at 1:13 PM
    bash42
    Eastern PA
    Rich, good point. I wasn't aware of the specific timing he needed, just speaking to the fact that he would probably be ok with the weight of this set up.
  10. Jul 22, 2012 at 1:16 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    With a towing package and trailer brakes with the V6... personally I'd do it for 25 miles keeping it mellow.
    Without the towing package or with a 4-banger?
    Fuck no.
  11. Jul 22, 2012 at 1:19 PM
    goomba
    goomba It is a Fluid Situation
    Josh
    San Antonio Fl
    96 White Ex. Cab Tacoma TRD 4X4
    3" lift Up front(Donahoe Racing ext. travel coil overs, Camburg UCA's), 1.5-2" lift in the back(aal and some billy 10" stroke short bodies), Bushwhacker Cut-Out fender flairs, 16"x10" Procomp Street locks, and 305/70 Procomp X-Terrains.
    Wow we have a fight on our hands. Get over yourselves. All we need is just one opinion and reason from each person, not a fight.
  12. Jul 22, 2012 at 1:20 PM
    DanglingFury
    DanglingFury Creeper
    Keith
    Bowling Green, KY/Lake Cumberland, KY
    2006 4Runner 4x4
    Daystar 2.5"/1" lift-level BFGoodrich KO2's
    I wouldn't recommend it. Not that far anyway.
  13. Jul 22, 2012 at 1:20 PM
    joes06tacoma
    Joe
    Central Coast, CA
    That's the biggest problem right there. I also find it hard to believe the trailer only weighs 1,000 pounds. So, at LEAST 500 pounds over the rating with factory tow package. You have to include the driver and any passengers in that weight as well. Realistically he'd be over 1,000 above what the truck is capable of with the brakes properly set up. I believe Toyota also specifies weight distrubuting hitch to be used to achieve the tow rating.
    Call whoever delivered the thing and get them to pick it up. Not worth it. If you kill someone, that's criminal negligence.
  14. Jul 22, 2012 at 1:21 PM
    bash42
    Eastern PA
    yea, my 2011 2.7L probably would have fallen apart trying to tow this thing. haha:D
    Did you see the top gear episode where the Ford pulled the locomotive? i believe it was 100,000+ lbs?
  15. Jul 22, 2012 at 1:23 PM
    #35
    Rich91710
    Rich
    Los Angeles
    08 Base
    Ya, but they didn't try to stop it and didn't care if the trans only lasted 5,000 miles.
  16. Jul 22, 2012 at 1:27 PM
    #36
    bash42
    Eastern PA
    yea, i understand & not saying its a good idea but it was just amazing that it actually got 280,000 lbs moving in the first place! ;)
    http://www.youtube.com/watch?v=bev8khM-2xQ
  17. Jul 22, 2012 at 1:35 PM
    #37
    Rich91710
    Rich
    Los Angeles
    08 Base
    OTOH... know how much power it takes to get a train over the Cajon Pass... I-15 out of the LA Basin into the high desert?
    2hp per ton.
    That's it.
    5hp is enough to move a Tacoma over that grade.
  18. Jul 22, 2012 at 1:38 PM
    #38
    UNDEAD1153
    UNDEAD1153 Well-Known Member
    Weston
    Chattanooga Tennessee
    White 2011 TX Pro Double Cab
    Rough Country 6" lift, 17" XD Addicts, 315/70/17 Nitto Trail Grapplers, 6K HID's, Wet Okole's, Kenwood DD head unit, Custom Exhaust
    How exactly do you turn over drive off in the auto's??? I've wondered that for a while.
  19. Jul 22, 2012 at 1:42 PM
    #39
    Rich91710
    Rich
    Los Angeles
    08 Base
    Push the shifter to the left after engaging drive.
    The dash indication will say "3" for the 2.7 or "4" for the 4.0
  20. Jul 22, 2012 at 2:54 PM
    #40
    countryboy22
    countryboy22 [OP] Well-Known Member
    Arizona Mountains
    05 SR5 4x4
    TRD cold air intake, Bilstein 5100's @ 2.5, Toytec 1.5" aal w/rear bilsteins. MBRP tip, Flowmaster Delta Flow 50 series, Toytec axle shims and carrier bearing drop.
    Well decided not to do it . Yes I got auto with tow package but there is a pretty good climb for me to take it back, soended up calling a buddy and he is coming to get it with his. Cummins
