Think I have Axle Wrap...Need a Mechanic Recommendation
Discussion in 'Technical Chat' started by amasih, Jun 17, 2008.
  1. Jun 17, 2008 at 6:05 AM
    amasih
    amasih [OP] Member
    Atlanta, GA
    99 PreRunner SR5 V6 ExtraCab
    I've had my 99 Pre-Runner for a couple months now, and the dreaded "Axle Wrap" is bugging me. On top of that, I do have a feeling that I need new shocks for the truck (looks like it might be the original bilsteins after 123K miles).
    So I made the mistake of going to the local dealer to have them check out the frame for recall and also to advise me on the shock/leaf spring issue. I ended up walking out of there with a new timing belt/water pump and front brake rotors. I know, I should have just left, but they actually wanted to do a whole lot more stuff to it, and I know I did need new front brakes and, well, if the timing belt wasn't done...anyway, trying to convince myself I'm not as dumb as I thought.
    Also, they didn't mark anything down about the frame inspection on the work order. I told him to do it, and he said it looked fine. I just hope they actually did do the inspection. Of course, this has been a SE truck away from the water since day one, so I'm prob OK.
    So...I don't want to go back there to have someone comment on the leaf spring/shock issue again, and am looking for a mechanic in the Atlanta area that I can trust to look at this issue and tell me what's going on. I called one place yesterday and asked about "Axle Wrap" and explained to him what it was according to what I read here, and he said "Well, the Internet is good for a lot of things...car advice is not one of them. I don't know what you're talking about and I've never heard of leaf springs going out on a Tacoma".
    And he's a "Toyota-only" mechanic. UGH!
    So, any recommendations?
    Thanks.
  2. Jun 17, 2008 at 8:06 AM
    humanoid
    humanoid bite me
    Sunny SoCal
    I had a '99 Xtra Cab PreRunner SR5 V6
    He's a moron. If you really want to get rid of axle wrap, order a set of new leaf springs or a traction bar on line and get them installed somewhere other than a dealer.
  3. Jun 17, 2008 at 8:10 AM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    + 1 ^
  4. Jun 17, 2008 at 8:51 AM
    amasih
    amasih [OP] Member
    Atlanta, GA
    OK. I'm fine with doing that. Any recommendations on leaf springs to get and shocks? I don't do any off-roading, etc., so not looking to lift the truck up, but I do like the current ride height.
    Then, if anyone still has any recommendations of a good shop in Atlanta, I'd appreciate it.
