Think this can be jb welded?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 2009Access4x4, Jul 28, 2024.
  1. Jul 28, 2024 at 10:56 PM
    2009Access4x4
    2009Access4x4 [OP] Well-Known Member
    Shane
    2009 Silver 4x4 access cab 6cyl
    Title says it all. Do you think this can be jb welded back on?
  2. Jul 28, 2024 at 10:57 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Just get it welded on.
  3. Jul 29, 2024 at 2:20 AM
    mit88
    mit88 Well-Known Member
    Planet earth
    You can but it will not last.
  4. Jul 29, 2024 at 8:02 AM
    2009Access4x4
    Shane
    It was welded on by a shop three years ago.
    bkhlrTaco's likes this.
  5. Jul 29, 2024 at 8:05 AM
    knottyrope
    knottyrope Well-Known Member
    Knotty
    Bahstun
    09 Taco CCLB 4x4 SR5 4.0
    Pads, rotors, ujoints, 5900K Super White Xenon HID Halogen Bulb Fog Light
    JB weld will burn off
    new pipe time or find a mig/tig welder
  6. Jul 29, 2024 at 8:36 AM
    2015WhiteOR
    2015WhiteOR Well-Known Member
    Gainesville TX
    Try a...different shop this time. Any old school muffler shop will probably charge $20 max to fix that.
  7. Jul 29, 2024 at 9:42 AM
    ridefreak
    ridefreak Well-Known Member
    NM
    2006 DCSB TRD
    minor tweaks
    I in the doubt JB weld will hold it through the first drive and definitely not after going over railroad tracks.
  8. Jul 29, 2024 at 10:20 AM
    Musubi3
    Musubi3 Well-Known Member
    Big Island
    2014 Tacoma DC 4x4 TRD Off Road, Supercharged
    I'd just TIG that back on. Agree that JB Weld would not last at all.
  9. Jul 29, 2024 at 10:35 AM
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    Just hacksaw it all off right behind the axle
    tacoman45 likes this.
  10. Jul 29, 2024 at 12:32 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    The hanger doesn't have enough contact patch onto the exhaust tubing. The forces exerted on that small area during your driving are what caused it to break. Needs a longer hanger with more contact patch.
  11. Jul 29, 2024 at 12:36 PM
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
    That repair is screaming for bailing wire.
    llibrm, WOODY2, nd4spdbh and 8 others like this.
  12. Jul 29, 2024 at 1:13 PM
    2009Access4x4
    Shane
    Shouldn’t the shop that I took it to have already done that?
  13. Jul 29, 2024 at 1:14 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    This is a 5 minute fix.
    Not sure why it's turning into something more :rofl:
    TACOTU3 likes this.
  14. Jul 29, 2024 at 1:18 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    The photo shows they did not.
  15. Jul 29, 2024 at 1:27 PM
    planetbuster
    planetbuster Well-Known Member
    San Diego
    2014 DCSB TRD OR Lifted+supercharged
    take it to a decent muffler shop, any teenager could weld that up but hte reason jb probly isnt the move is how much grinding youd have to do, to clean up all those surfaces. real welding is the answer, imo.
    kidthatsirish and Torspd like this.
  16. Jul 29, 2024 at 1:57 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Welding is the only "right" way.
  17. Jul 29, 2024 at 2:07 PM
    bkhlrTaco's
    bkhlrTaco's “expletive deleted”
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    I'm going to 2nd, 3rd.....even the "high temp" JB Weld will burn off before long.
  18. Jul 29, 2024 at 3:41 PM
    TacoTuesday1
    SD CA
    You could weld that.
    or get a replacement catback. My TRD catback was like $150 lightly used.
  19. Jul 29, 2024 at 3:44 PM
    TACOTU3
    TACOTU3 Well-Known Member
    2000 Xtracab V6 4x4 TRD
    Why stop there? Replacement truck is probably only ~$8k!
  20. Jul 29, 2024 at 3:48 PM
    BigCountry762x39
    BigCountry762x39 Well-Known Member
    TL
    PNW, Oregon!
    2009 Tacoma, with the cool white paint peel
    Arb Deluxe bull bar Front Bumper Ironman4x4 12k winch synth line AFE Intake OME 2.75in Dakar Leaf springs (R) Fox 2.0 bypass shocks (R) Bilstein 6112 (F) 33's on KMC wheels off road lighting comfort mods Redrock HD roof rack Retevis rt95 Radio Slotted Rotors and HD pads
    seeing where this is on the truck give yourself a "high clearance" exhaust mod. chop that exhaust pipe off right before it flattens back out and then no need to re weld that mount back on, and hacksaw blade/ saw-z-all blade anyone can use. or if you want to get fancy use a cut off wheel!
    but you could likely use JB weld that far back in the system but why not chop the pipe back
    though it looks like that some kid of modified exhaust as the normal hanger back there is still in the pic on the frame.
    Sharpish likes this.
