Think You Don't NEED to re-gear?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by GSK9 B1T3, Apr 3, 2011.
  1. Apr 3, 2011 at 1:28 PM
    GSK9 B1T3
    GSK9 B1T3 [OP] Well-Known Member
    Another One
    Washington
    TRD Rugged Trail ED
    Toyotec Ultimate 3" TC UAC 305/70 R16 Breather Mod Front fender Mod Steel Brake Lines All around
    So I see a lot of people saying they do not need to re-gear even though they have 33's up to 35's. Maybe they don't but do they have sliders, bumpers, winch, skids, recovery gear, etc. All this stuff is added weight and stress on the gears. Not to mention the already up sized tires. So yes you may not need to re-gear with bigger tires but once you get all the stuff to actually USE the bigger tires you will need to re-gear IMO.
    Any thoughts?
    This is a bit pre-mature as I have not re-geared yet but have my nice new Nitro 4.56 sitting on my floor.
    For those of you who haven't re-geared and are fine thats great I just want to hear what people have to say about the topic, as I am not trying to flame you all.
    *SIDE NOTE*
    Looked online everywhere for hours. Has anybody come across a good "How To" re-gear an e-locker?
  2. Apr 3, 2011 at 1:59 PM
    Tacoyota
    Tacoyota senile member
    North of Cali, South of Canada
    08 4wd
    4.56 gears, rear trutrac,DT header, 235/85r16 Duratracs, 2nd filter pulled, inter.wipers, Cruise control, Factory alum. whls/winter tires(2nd set), Afe pro Dry-S , Dumbo eared flaps cut down.
    Thats just it. There is no 100% yes or no answer. My view is if you a getting the bigger tires and seldom go offroad, of course you dont need to. If you are going to 4 wheel , my opinion is yes you do. My reasoning is with a manual transmission, go up a steep hill and stop at some point. The better gearing will help keep you from; 1) stalling 2) lets you roll slower...control 3) easier on the clutch. Im sure theres afew more reasons too.
    All that and then add the extra 200lb+ in gear you mentioned. 4wheelin isnt cheap. It only gets spendier if you try to go cheap imo.
  3. Apr 3, 2011 at 2:01 PM
    rab89
    rab89 Well-Known Member
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    is this a whole thread to state your opinion on other people's way of doing things? odd
  4. Apr 3, 2011 at 2:17 PM
    smileyfish
    smileyfish Well-Known Member
    mark
    mass
    trd sport
    none YET
    to keep the power and fuel economy of your rig the same as stock you should regear (if you care)
    3:73 (stock)
    33's = 4:10/4:11
    35's = 4::56
  5. Apr 3, 2011 at 2:20 PM
    Tacoyota
    08 4wd
    Of course not.
    Ive seen others peoples way of doin things some are good some are bad. Ive seen too many shortcuts and advice not fully thought out, followed by exasperation.
    For example when I was 22 or so. I was told I didnt need a locker, the tires have all the traction. Thats poor advice in the snow with one tire in the air off of the beaten path. Glad i had a tow strap.
    So yea, you can lift a truck 4" , and you dont have to do an alignment job, or head light aim, or, you can get a winch , and you dont have to get another battery or 1 bigger. Feel free to "dont have to". You dont have to do maintainance either if thats your way. Its your truck treat it as you see fit .
  6. Apr 3, 2011 at 2:22 PM
    ink junky
    ink junky I love tacos too!!!
    TACO LOVER
    TEXAS
    2010 4x4 trd off road DC,
    Aero turbine 2525, Snorkel, AFE pro dry drop in filter, BFG 33s, spydertraxwheel spacers :/. Debadged, rebadged black, TW sticker :D, bed lights, rod holders, OEM roof rack, Complete OME lift, bed lined fenders. Armor Tech Off road wrap around HC rear bumper w/ tire carrier swing out. Relentless front aluminum bumper. Le Devil Horns (_)
  7. Apr 3, 2011 at 2:30 PM
    Tacoyota
    08 4wd
    Dang you GSK9 , its like you knew what im up to .:)
    Ive been looking at around $4000 to do what I want to my truck . My plan is to get a 4 leaf for my rear buying it form someone, then a new rear bumper, rebalanced out with the good ol 5100 shocks. Then move on to a 4.56 ring change/rear locker install. No actual lift, just whatever resulted from the new leaf springs. I want DT headers along the way too.
    BTW smiley , 3.73 , is that v-6/auto? I thought all the 4x4 were 4.11 or is that just manual transmissions?
  8. Apr 3, 2011 at 2:37 PM
    My68ur8trd
    My68ur8trd Well-Known Member Vendor
    Justin
    Williamsburg, VA
    2007 TRD OR Dcab 4x4
    URD Catback | TRD CAI | TRD S/C | APR X-1 | DTLT | APR 2.85" Pulley |Fabtech 6" | Icon C/O | Alcan Leafs | 33 Grabber AT2 | 17" XD Addicts
    Even for street use I say you should if you want to keep the performance.
    I run 33 x 12.50s and I can definitely tell they are there. Not so much WOT, the truck has more than enough power to get them moving right along, but its the part throttle lugging that annoys me the most.
    since the RPMs are lower at a given speed, light throttles gives little response where it was sufficient with stock tires.
    If you have a boost/Vac gauge, you can really see it. Cruising on the interstate stock, it would pull about 20 in/hg vacuum, now it sits right at 10 to keep the same speed. and you can correlate your MPG to Vac as well.
    Offroad is a different story all together. I want to re-gear at some point, but I am not set that this is the tire size I want to run ( I may go to 35s) so ill give it some time
    Justin
  9. Apr 3, 2011 at 2:40 PM
    S.B.
    S.B. Well-Known Member
    Sean
    San Diego
    15 Taco
    LT, Glass, CBI Front bumper, NWTI Rear bumper, 35s
    autos 3.73 and 4.11 on manuals, well atleast its this way for V-6
  10. Apr 3, 2011 at 3:30 PM
    smileyfish
    mark
    mass
    trd sport
    none YET
    ^^ what he said auto.
  11. Apr 3, 2011 at 4:40 PM
    gtrotter
    gtrotter Well-Known Member
    Interlake, Indiana
    2009 Regular cab 4x4, ARB's, 4.88's, bumpers, 2017 DCSB SR5 stock,2008 Reg. Cab 4x4
    locker,mud tires, lifted, toolbox
    I've got 4.88's with my 33's :D. But seriously, the gears do make a difference offroad. Onroad, it is noticable but not needed.
  12. Apr 3, 2011 at 4:45 PM
    smileyfish
    mark
    mass
    trd sport
    none YET
    4 popper? ^^
  13. Apr 3, 2011 at 4:51 PM
    gtrotter
    Interlake, Indiana
    Yeah, the 4.88's,33's, and 4 cylinder makes a world of difference. I'm interested to see how they do with 35's.
  14. Apr 3, 2011 at 4:57 PM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    I've got 33s and the truck is heavy. I need to regear but it's too much money. I won't re-gear until I go 35s.
  15. Apr 3, 2011 at 9:04 PM
    nighthawk87
    nighthawk87 Well-Known Member
    What's the parts and labor for a 4.56 gear install running you guys? I know this is not a DIY install as I ha my ram re geared and it was an experience to say the least.
  16. Apr 3, 2011 at 9:18 PM
    especk
    especk Nothin' Special
    Erik
    Redding, CA
    2010 Tacoma Reg Cab 4x4
    3" OME lift with 885 coils on nitrocharger 90000 shocks with 5mm trim packer on driver's side, TC UCAs, Rear OME Dakar leafs with nitrocharger shocks, All-pro U-bolt flip kit and 3* Toytec shims, extended rear brakelines, 16" Raceline Rockcrusher 887 wheels with 3.6" backspacking, BFG KM2 305/70/16 tires, Doug Thorley header, Doug Thorley catback exhaust, Volant CAI with ram air, Weathertech floor mats, Kicker 12" sub, Kenwood 500W RMS amp, Relentless Fab front and rear bumpers, 4.88 gears, custom flatbed with swing out tire carrier
    Parts and labor is about $700 per axle.
    4.88s with 33s on a 4cyl here. I love it. Before the gears, there were times I was burning up the clutch offroad and on road going up steep hills from a stop.
  17. Apr 3, 2011 at 9:23 PM
    jmar04
    jmar04 New Member
    Juan
    San Diego
    09 regular cab 4x4 manual
    285 discover cooper tires, american racing atx wheels, K&N intake, magna flow exhaust, re-geared, 3" icon/total chaos front suspension, 3" fox 2.0 remote res rear
    just got my truck re-geared from stock to 4.11 and it was the single best improvement i've made to the truck. I run 285's with a 3" lift on a 4 cyl reg cab and the transformation after re-gearing was incredible. I recovered all the power i lost. I bet the majority of guys have V-6's but if you're looking to get that scrappy tacoma feeling back then save up and do it, great investment.
  18. Apr 3, 2011 at 9:27 PM
    mattg43
    mattg43 Well-Known Member
    Texas
    08 Prerunner SR5 DC
    SwingCase, driver side. PVC Bike rack. Aftermarket stereo.
    No experience in a Tacoma, but I had an 88 Jeep Cherokee with 33s (stock size was about 28" tall) and 4.56 gearing (3.55 stock). At the same time I had my daily driver 99 Cherokee, with stock gearing and running 30" AT tires. The 88 with 33" BFG M/T tires actually had better acceleration, and would still get about 17-18MPG highway (drover from PA to TX), where my 99 was only getting about 18.5-19 highway.
    Proper gearing made a huge difference in all aspects of driving, not just offroad, or at slow speeds. The locker sucked though... :D
  19. Apr 3, 2011 at 9:27 PM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    ok lets take 33s (285s) and 35s (315s) and compare them. Besides the extra surface area the 35s have over 33s, according to tire rack, for example km2s there is only a 4 pound difference. Where is the added stress coming from. Im not trying to argue the 35s will not have much difference over 33s but im wondering why its such a big deal.
  20. Apr 3, 2011 at 9:27 PM
    afd23a
    afd23a Well-Known Member
    The Dynamo of Dixie
    05 Access Cab 5 Lugger
    Factory Fog Lights, Removed Secondary Air Filter, Metra Ipod Adapter, Int Wiper Stalk, Wet Okole's, URD Short Shifter, Scanguage II w/Blendmount, Fat Bob's 2.75" spacer lift, ARE topper, SP Performance Pads & Slotted Rotors, 4.10 gears
    You might want to check out Zuk's website. I don't think he does regearing anymore, but his site has many, many documented (with pics) regearings of toyota third members including a few elockers.
