Think You Don't NEED to re-gear?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by GSK9 B1T3, Apr 3, 2011.
  1. Apr 3, 2011 at 9:28 PM
    PWhite13
    PWhite13 Well-Known Member
    Prescott
    Southern California
    06 Silverado Crew Cab 5.3
    Regearing should be done with 35's no matter what. 33's with street use are fine but 33's with a lot of wheeling should heavily consider it.
  2. Apr 3, 2011 at 9:29 PM
    singlefin
    singlefin Well-Known Member
    Hood River, OR
    Syncro
  3. Apr 3, 2011 at 9:29 PM
    afd23a
    afd23a Well-Known Member
    The Dynamo of Dixie
    05 Access Cab 5 Lugger
    Factory Fog Lights, Removed Secondary Air Filter, Metra Ipod Adapter, Int Wiper Stalk, Wet Okole's, URD Short Shifter, Scanguage II w/Blendmount, Fat Bob's 2.75" spacer lift, ARE topper, SP Performance Pads & Slotted Rotors, 4.10 gears
    larger diameter tire = harder to turn
  4. Apr 3, 2011 at 9:33 PM
    especk
    especk Nothin' Special
    Erik
    Redding, CA
    2010 Tacoma Reg Cab 4x4
    3" OME lift with 885 coils on nitrocharger 90000 shocks with 5mm trim packer on driver's side, TC UCAs, Rear OME Dakar leafs with nitrocharger shocks, All-pro U-bolt flip kit and 3* Toytec shims, extended rear brakelines, 16" Raceline Rockcrusher 887 wheels with 3.6" backspacking, BFG KM2 305/70/16 tires, Doug Thorley header, Doug Thorley catback exhaust, Volant CAI with ram air, Weathertech floor mats, Kicker 12" sub, Kenwood 500W RMS amp, Relentless Fab front and rear bumpers, 4.88 gears, custom flatbed with swing out tire carrier
    regeard to 4.11s. I dont think so considering you already had 4.10s
  5. Apr 3, 2011 at 9:39 PM
    especk
    Erik
    Redding, CA
    Crawl box, now that's the shit right there. What does that cost?
  6. Apr 3, 2011 at 9:46 PM
    PWhite13
    Prescott
    Southern California
    Sounds like you went to Wally World.
  7. Apr 3, 2011 at 9:49 PM
    PWhite13
    Prescott
    Southern California
    Rollback FTW
  8. Apr 4, 2011 at 7:23 AM
    anethema
    anethema Well-Known Member
    J
    Dawson Creek,BC
    08 TRD OR Access cab 4x4
    ARB Bumper,OEM Roof rack modded for access cab, Allpro Rock Sliders,Icon Adjustable coilovers,More Tie Downs in bed, Firestone Airbags in rear,Block heater
    Heh you guys had me going, I was almost certain my 4x4 4L had 3.73, but saw 4.11. Ha. Ya according to Toyota, it IS 3.73 even on the MT for the v6.
  9. Apr 4, 2011 at 7:52 AM
    GSK9 B1T3
    GSK9 B1T3 [OP] Well-Known Member
    Another One
    Washington
    TRD Rugged Trail ED
    Toyotec Ultimate 3" TC UAC 305/70 R16 Breather Mod Front fender Mod Steel Brake Lines All around
    Gotta catch a flight but wanted to drop a line so I am not the Troll ;). Thanks for all the replies. I will read them ASAP.
    SIDE NOTE - I am stating an opinion and seeing what people think pretty much isn't that what forums are for?
  10. Apr 4, 2011 at 7:57 AM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    Driving with a locker in the snow is a great way to end up in a ditch if you're not being careful.
    Open diff in 4x4 is much safer driving in the snow.
    As for regearing. I suppose with a 4cyl and 285's regearing would be more beneficial. However I have a v6 w/ 285's and although its a little slower, it's not that bad.
  11. Apr 4, 2011 at 7:57 AM
    macgyver
    Brad
    Canton, GA
    6th = worthless on the highway :( Thanks Toyota.
  12. Apr 4, 2011 at 8:01 AM
    macgyver
    Brad
    Canton, GA
    I'm pretty sure you would be redlining :D
  13. Apr 4, 2011 at 8:04 AM
    macgyver
    Brad
    Canton, GA
    The ground would give way... Cause I sure could use a vacation.
  14. Apr 4, 2011 at 8:07 AM
    jspadaro
    jspadaro Well-Known Member
    Jim
    Knoxville, TN
    Former Tacoma Owner
    Blue Oval Mod
    Your 09 4x4 4-popper has 4.10 gears? :confused:
  15. Apr 4, 2011 at 9:29 AM
    #35
    especk
    Erik
    Redding, CA
    I know this question is not directed at me but, yes they do.
  16. Apr 4, 2011 at 9:32 AM
    #36
    jspadaro
    Jim
    Knoxville, TN
    Former Tacoma Owner
    Blue Oval Mod
    I miss-axed. The guy to whom I was responding said he went to 4.11's, but he already had 4.10s. I was confused by his statement.
    I know they have 4.10's though, because I have them too. :D
  17. Apr 4, 2011 at 9:40 AM
    #37
    jandrews
    '09 FourDubDee TRD OR
    Need to find out the cost difference between gearing my current e-locked rear end and going to an 8.4 with an ARB and exchanging the core.
  18. Apr 4, 2011 at 9:43 AM
    #38
    JLee
    JLee The Man! Vendor
    Jerry
    Grass valley CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    Well I have 4.10 gears and they do fine with my 33's when i go to 35's I will be re gearing most likely 4.88's but I'm not sure yet if i just want to go 4.56. Ive got time seeing on my 33's are still pretty new
  19. Apr 4, 2011 at 9:48 AM
    #39
    especk
    Erik
    Redding, CA
    Im confused by his statement too
  20. Apr 4, 2011 at 3:39 PM
    #40
    Tacoyota
    Tacoyota senile member
    North of Cali, South of Canada
    08 4wd
    4.56 gears, rear trutrac,DT header, 235/85r16 Duratracs, 2nd filter pulled, inter.wipers, Cruise control, Factory alum. whls/winter tires(2nd set), Afe pro Dry-S , Dumbo eared flaps cut down.
    Yea, the snow was offroad 3" or so on some worn rock in that situation. one other reason i didnt get the locker on that rig was the onroad driving i was doing.
