Thinking About an Engine Swap. Who Has Experience?
Discussion in '1st Gen. Tacomas (1995-2004)' started by TACO in SC, Jun 20, 2016.
  1. Jun 20, 2016 at 5:10 PM
    TACO in SC
    TACO in SC [OP] TuRD
    Andrew
    Greenwood, SC
    '03 Tacoma Ex Cab 4x4 V6 5-Speed
    Pretty well stock
    Okay, don't flame me. I know some guys will say "get a new truck before you yank that V6 out of there". And they are probably right. It has 135,000 miles and doesn't give me any trouble.
    But.... I have driven this truck for 13 years and it has never failed me but it would be fun if it was more powerful. I keep pondering the possibility of replacing the V6 with some small V8. I would like to retain the 4x4 and all the creature comforts but improve power. I see the 1UZ Lexus LS400 engines are available for $1,000 to $2,000. A stock 1UZ could give me about 300 HP and 300 ft lb torque. My present is 190 HP and 220 ft lbs torque.
    http://www.ebay.com/sch/i.html?_fro....H0.X1uz+engine.TRS0&_nkw=1uz+engine&_sacat=0
    Google searches don't give me much info as to the degree of difficulty of this swap. Ideally it would bolt up to my V6 motor mounts and then to my 5-speed bell housing then I would connect everything, but that is likely not even close.
    Does anyone have links to where someone has successfully performed such a swap? I could consider another V6 or V8 engine if the ease of install was greater. Some of today's V6's have 300 HP, such as those in the new Camaro and other Chevy products.
    In the end I might not do it. But at least I can still dream about it.
  2. Jun 21, 2016 at 1:36 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Each engine swap has it`s own challenges If you want to build a truck why not get one with a bad engine for your project .
    Unless you already have several vehicles
    We put a 1UZ in a Mita so a truck would be no problem
  3. Jun 21, 2016 at 2:22 AM
    moab4x432
    moab4x432 Well-Known Member
    Tacoma wa
    2016 4Runner trd pro quicksand
    Why not find a used trd supercharger for your 3.4 and run yours until it blows up , then think about doing the motor swap ?
    I've seen some 3.4's with the s/c that were pretty quick and they seem to last forever.
    I always thought it would be fun to drop a tundra 5.7 in one or go the gm route with an Ls-6 but it always seemed like too much work and hassle with emissions inspections in my area
  4. Jun 21, 2016 at 2:38 AM
    superorbital
    superorbital Well-Known Member
    2015 White TacoMama TRD
    Why not just build your present engine? It would probably be way easier.
    Bxnanaz likes this.
  5. Jun 21, 2016 at 3:39 AM
    Clearwater Bill
    Billy
    Largo Florida
    Define build. And please quote specific successful results with these motors, including costs.
  6. Jun 21, 2016 at 5:28 AM
    TACO in SC
    Andrew
    Greenwood, SC
    Pretty well stock
    This. My searches show that no one is building these engines for performance. If I could add a cam and headers and get up to ~ 250 HP that might be a good option. I can find nothing that supports this option.
    Oh, and the engine doesn't need rebuilding. I replaced the timing belt at 120,000 miles so it is good to go for a while longer.
  7. Jun 21, 2016 at 6:33 AM
    bldegle2
    bldegle2 OldPhart
    San Francisco, Ca.
    2009 Prerunner TRD AccessCab
    New Navigation DVD/CD/TV/AV/Bluetooth Stereo and seat mod spacers, 1" hubcentric spacers, seat heaters....
    I have 301,000 now, 3.4, runs great, only problem right now is slight oil leakage from rear of intake, got to block out some time to get to it as the intake has to come off to get to it....treat them right, they will last a long time...
  8. Jun 21, 2016 at 6:37 AM
    TACO in SC
    Andrew
    Greenwood, SC
    Pretty well stock
    I would consider an FJ engine with 4x4 tranny, again if the swap was minimal fitting for minimal down time. 260 hp and 270 torque. I do have an extra vehicle in the meantime.
    moab4x432 likes this.
  9. Jun 21, 2016 at 8:05 AM
    superorbital
    I mean build it as in high performance cams, pistons, rings, headers, computer chip if available. I am new to these trucks so I am not sure what is possible/available. You are starting with a great base. Now build it up.
  10. Jun 21, 2016 at 3:06 PM
    Wyoming09
    New Tripoli Pa
    Super Springs
    Some time ago I heard putting gaskets on the valve covers and oil pan was rebuilding .
    Things must really have changed I need to get out more
  11. Jun 22, 2016 at 3:09 PM
    cruxofthebisquit
    cruxofthebisquit Well-Known Member
    Orange Texas
    2000 TRD
    OME and worth every penny.
    If it ain't broke....
  12. Jun 22, 2016 at 3:18 PM
    Clearwater Bill
    Billy
    Largo Florida
    I actually knew what 'build' meant.
    Which is why I added "And please quote specific successful results with these motors, including costs."
    Was hoping you'd dig around a little. Unfortunately I think you'll find the expense for the gain is a losing proposition.
  13. Jun 22, 2016 at 3:43 PM
    superorbital
    Whenever you put money into high performance engine parts you put a lot of money in and don't get nearly the same out in horsepower gains. You sound like you already knew that though.
  14. Jun 22, 2016 at 4:26 PM
    Wyoming09
    New Tripoli Pa
    Super Springs
    As long as it is faster then a team with a wagon I am happy
