Thinking about BDS 6" lift and 35s
Discussion in '3rd Gen. Tacomas (2016-2023)' started by foster35, Mar 30, 2017.
  1. Mar 30, 2017 at 5:24 AM
    foster35
    foster35 [OP] Well-Known Member
    Foster
    Morrisville, NC
    Stock 2017 Tacoma TRD Off-road
    N/A
    I have a stock 2017 Tacoma DCSB TRD Offroad....
    I really like the look of a 6" lift and the added ground clearance / approach angle / departure angles
    I already have a brand new set of 35x12.50r18 nitto trail grapplers just sitting in my living room left over from my tundra that I ended up trading in for the tacoma.
    I looked at two different BDS 6" lifts, the regular one for about $1900 and the Coilover one for about $3600. Wanted to match it with some new wheels with the right offset and my 35s that I already have.
    Was wondering if this is how you would spend the money... or if there was a better 6" configuration... what else would I need to spend to make this 6" lift work properly?
    authorized dealer/installer of BDS quoted me $1000 labor to install the lift and $1850/$1950 for the regular 6" BDS lift w/o the coilovers.
  2. Mar 30, 2017 at 6:21 AM
    DNasty777
    DNasty777 HEATMISER
    Dave
    Rochester, NY
    '16MGMDCLBTRDS4X4
    In before the bashing of drop crossmember lifts.
    That being said, save yourself the thousand dollars on install and do it yourself. Put it towards the kit with the coilovers.
  3. Mar 30, 2017 at 7:47 AM
    Doggman
    Doggman Well-Known Member
    Alabama
    2017 TRD OR MT
    Do you understand how the 6" BDS lift works? If so, rock on. If not I'd do some research. You have to cut a large section out of the cross member of your frame. Furthermore, actual suspension performance is less than the 3" lift alternatives that consist of coilovers and control arm/s. That being said if your main goal is to fit the 35s then the 6" may be the easiest route. Fitting 35s even on a LT 3" lift requires lots of trimming and new fenders.
  4. Mar 30, 2017 at 7:50 AM
    AtxLakeTaco
    AtxLakeTaco Texas Toyota Coalition
    Tres
    ATX
    Black DCSB Prerunner
    5100's,887's,etc.
    DUDEEEEE, TW is about to start bashing the fuck out of you. Mods lock this one down before it gets out of hand. (also OP are you trolling or serious?)
  5. Mar 30, 2017 at 7:52 AM
    greeneggsnspam
    greeneggsnspam ಠ_ಠ
    Houston, TX
    .gif
    Too poor to list anything interesting.
    Just remember that true ground clearance comes from your wheels, not the lift.
    photogr4x4 and reidkm like this.
  6. Mar 30, 2017 at 8:05 AM
    foster35
    Foster
    Morrisville, NC
    N/A
    I'm seriously considering it - I like the look of 6" and that it can fit 35s. I figured BDS is a good lift kit.
    SPIN Offroad, Deertay and rlx02 like this.
  7. Mar 30, 2017 at 8:09 AM
    AtxLakeTaco
    Tres
    ATX
    5100's,887's,etc.
    It's not a bad route brother, it will work fine. All the guys on here are about 3 inch lifts. They're gonna try to steer you away from it but its your truck your money. Nothing partcularly wrong with a 6 inch lift. Also try checking out bulletproof suspension they make a high quality kit as well.
    SPIN Offroad and rlx02 like this.
  8. Mar 30, 2017 at 8:11 AM
    AtxLakeTaco
    Tres
    ATX
    5100's,887's,etc.
    Just be prepared these guys on here will bash the fuck out of it. But I'm more of a to each their own kinda guy, if you like it go with it. I do know as far as 6 inch lifts go BDS is one of the better companies (stay away from rough country and other cheap lift companies). I'd either go with BDS or Bullet Proof Suspension.
    SPIN Offroad and Deertay like this.
  9. Mar 30, 2017 at 8:12 AM
    AtxLakeTaco
    Tres
    ATX
    5100's,887's,etc.
    Whichever you do go with the coilover, in the long run it will save you money on chewed up CV's, and other parts that wear and tear because of spacers.
  10. Mar 30, 2017 at 8:17 AM
    foster35
    Foster
    Morrisville, NC
    N/A
    I looked up bullet proof says they only have a 10-12 inch lift
  11. Mar 30, 2017 at 8:21 AM
    AtxLakeTaco
    Tres
    ATX
    5100's,887's,etc.
    That may be right, all i know if they make a stout kit, wasn't sure on sizes.
  12. Mar 30, 2017 at 8:32 AM
    foster35
    Foster
    Morrisville, NC
    N/A
    I'm not sure if I like cutting the cross members on the 6" lift. If I get a 3" lift then I wouldn't need to do that right? Plus on BDS 6" lift with coilovers it's $3600 and on the rear it's just on some blocks. The 3" lift kits that I look at use the add-a-leaf etc. seems like it's much more stable / better ride/performance than just blocks on the rear from the 6" bds kit.
    http://bds-suspension.com/product?ma=12&mo=45&ty=1&yr=2016
    Thunder Fist likes this.
  13. Mar 30, 2017 at 9:11 AM
    Doggman
    Alabama
    2017 TRD OR MT
    Correct. You do not need to cut the cross member for a 3" coilover lift. AAL is better than blocks but full leaf pack replacements are better yet. E.g. dakars or deavers.
  14. Mar 30, 2017 at 9:14 AM
    Radioactiv
    Radioactiv Well-Known Member
    Georgia
    2015 DCLB 4X4
    If you go 3" just get coilovers , AAL , and UCAs and you could still be close to 2k-2.5k installed. and it will ride much better than a 6 and factory.
    BKtaco13, bobrown14 and brich999 like this.
  15. Mar 30, 2017 at 9:17 AM
    Doggman
    Alabama
    2017 TRD OR MT
    JoeCOVA likes this.
  16. Mar 30, 2017 at 11:29 AM
    bobrown14
    bobrown14 Well-Known Member
    Bob
    Philadelphia
    Gen 3
    bunch of stuff - Bro Pro style
    Hey Bro... 35's on a Gen3... you'd be the first .... go bro go... I think it will look pretty bad ass.
    Gonna need to save money cause new gears... just sayin.
    THE real question should have been:
    "How much lift do I need to fit 35s on my truck?"
    Answer....35s wont fit, bro.
    Sell the 35s .... the Taco is a much smaller truck than the Tundra.
  17. Mar 30, 2017 at 11:44 AM
    Cold_Toad
    Cold_Toad Well-Known Member
  18. Mar 30, 2017 at 11:55 AM
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    Sell the 35's and get a real lift for your Taco. Going over 3" is just not worth the headache of everything involved.
    Most people running 35's around here are running 3" lifts with HEAVY trimming.
    If you want 35's that badly I would look at Allpro, Baja, or Total Chaos Long Travel kits
    marinemonkey and RIDERED67 like this.
  19. Mar 30, 2017 at 12:10 PM
    TacoRD16
    TacoRD16 Well-Known Member
    Houston, TX
    2016 Tacoma TRD Off Road 4x4
    Fox 2.5 RR C/O Fox 2.0 RR Rear Dakar leaf Pack Headstong Brakeline Extension Bracket 16"Konig Countersteer wheels BFG's KO2 285/75r16 All-Pro UCA 1.25" All-Pro APEX Slidders Unided CB w/ Firestick II Lamin-X fog Lens 1" Diff Drop OME 1/2" CB Drip OME Mobtown 3/16" Skid plates: Front, Trans and Transfer case Relentless Hood Brackets AuxBeam Ditch Lights DBCustons Grill "Recolored" Matt Black Relentless High Lift Mount Softopper Diff Breather Mod Tail Gate Inserts HondoGarage Tablet Vent Mount Weather Tech Floor Liner
    I believe the drop bracket route has less ground clearance then a regular lift with the same size tire.
    Dont want to thread jack but why do I always see drop bracket kits with the lower arms flat? Can they not be pushed any further down to gain more ground clearance? Or is that the differenct between a 4" lift vs a 6" lift with the arms pushed further down? Some times I wish I went the drop bracket lift to fit 37" eventually but once I start off roading and leaning 30+ degrees I'm glad my center of gravity is lower. I'll just stick to my 3" lift with eventually 35" tires.
    sdsurfer likes this.
  20. Mar 30, 2017 at 12:36 PM
    bobrown14
    Bob
    Philadelphia
    Gen 3
