Thinking about buying a receiver hitch....
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacoNH, Aug 8, 2010.
  1. Aug 8, 2010 at 10:56 AM
    TacoNH
    TacoNH [OP] tat daddy
    Nü Hampshire
    07 Blue Tacoma 4.0/6speed
    887s, 5100s, Light Racing UCAs, Nitto 285s, Leer Cap.
    Any suggestions on receivers? Should I buy used? New? Certain make or model? What is the best bang for my buck?
  2. Aug 8, 2010 at 11:09 AM
    larryde09
    larryde09 Well-Known Member
    Larry
    Rochester, NY
    (Traded-in) 06 2.7L 5-spd SR5 4x4
    K&N Intake, Magnaflow Cat-back Exhaust, Altezza Tail Lights, Pop&Lock Tailgate Lock, Extang Trifecta Tonneau Cover, PIAA foglights with stock switch, DrawTite Hitch, OBX Shift Knob, Hood Protector, Vent Visors, DIY step bars/sliders/running boards, DIY Bed Lights, DIY Running Board/Ground Lights, DIY Tailgate Electrical Box (12V socket, voltage and current gauges), DIY Internal Lighting (coming soon), Aftermarket switches in stock dash blanks, Sony Head Unit, Illuminated 4x4 switch mod
    In my opinion, new receivers are fairly cheap and you never know how old a used one is...i.e. rust, been in accident, etc. Hidden Hitch and DrawTite are the same manufacturer, and Uhaul has a hitch, but I don't remember who the manufacturer is.
    I don't recommend universal fit hitches...most manufacturer websites have a vehicle selector to tell you which hitch will specifically fit your truck and they are typically about the same price as a universal fit. Furthermore, there are plenty of bolt-on options that don't require cutting and/or welding.
  3. Aug 8, 2010 at 12:33 PM
    Primersinmyshoe
    Primersinmyshoe Old Sheepdog
    St. Louis, MO
    gray, shiny, dependable
    Glock 36, spare mag
    U-Haul fixed me up with a receiver hitch on an old truck I used to have.
  4. Aug 8, 2010 at 1:18 PM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    BSP '10 4x4 TRD Off-Road DC
    See build thread in signature
    You can probably get a stock Toyota factory hitch in Buy/Sell/Trade pretty reasonable. A lot of people sell them after getting a high clearance bumper.
  5. Aug 8, 2010 at 1:46 PM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    What are you driving and what to intend to tow? Weight of the trailer determines if you'll need a class III or IV. I put a Hidden Hitch class III on mine, very easy install and good for up to 5,000 lbs.
  6. Aug 8, 2010 at 4:29 PM
    Rocketball
    Rocketball If The World Didn't Suck, We'd All Fall Off
    Scott
    Westminster, MD
    08 Speedway Blue DC Sport 4x4
    Pioneer head unit, PAC steering wheel control modual, Hard wired Sirius radio, Hard wired radar detector, Hella Supertone horns, Blacked out badges, Smoked Tails, BHLM (color matched Speedway Blue), T-Rex Eyelids, Black Powder Coated Billet Grill, Color Matched Engine Cover, Lund in channel vent visors, FJ Cruiser wheels, Leer 100XQ shell, OEM bed mat, Piezo beeper for locking doors, Tinted front side windows, Black Westin bull bar, Aires tube steps, Mini Maglite Mod, D-Cell Maglite Mod, Weathertech Digifit Floor Mats
    If you have deep pockets, buy OEM, but I can tell you with certainty that it will cost you right around $1,000. :eek:
    I just had mine replaced as part of a collision repair, and the parts for the OEM receiver really did cost that much.
    If you don't mind doing the install yourself, you should be able to get a new Class II hitch for less than $150.00.
  7. Aug 8, 2010 at 6:14 PM
    larryde09
    Larry
    Rochester, NY
    I think Hidden Hitch/DrawTite only sell a class III/IV for the Tacoma. I looked into similar Class II's for my 4-cyl, but they aren't common because most towing is done by the V6 and therefore there's a bigger market for a Class III/IV. Besides, a class III/IV costs about the same as a II, so it makes sense to just get the bigger more capable hitch. Easier to sell/trade in the future too.
    I installed my DrawTite class III/IV without any big problems.
  8. Aug 8, 2010 at 6:29 PM
    larryde09
    Larry
    Rochester, NY
    x2...that's right, I couldn't remember.
  9. Aug 9, 2010 at 4:06 AM
    TacoNH
    Nü Hampshire
    Thanks for all the advice so far. I'm driving a 2007 v6, I plan to tow a two place snowmobile trailer (which is not very heavy at all). I'll also use it when wheeling pulling people out, etc, so I want it to be durable in abusive situations. I however cannot afford a $1,000. A couple hundred and I can install myself, I just do not feel comfortable cutting anything under the truck and I guess I could weld it, but do not really want to. I'm looking for a easy bolt on option. Is the hidden hitch going to cause issues to my bumper if I'm using a shackle/d-ring and trying to pull someone out? I don't want to cause damage to my bumper because the receiver sits to far under the truck.
    Any more advice is appreciated, and I'd buy one on here but shipping would be far to high because I split my time between Maine and NH and NO ONE on here is ever from the great northeast.
  10. Aug 9, 2010 at 4:09 AM
    TacoNH
    Nü Hampshire
  11. Aug 9, 2010 at 4:16 AM
    Logically Insane
    Logically Insane Well-Known Member
    Wes
    TN --- USA
    2010 PreRunner Access Cab
    Kobalt toolbox mounted with J-Hooks, Locks on storage compartments in bed, Window Visors, Toolbox LED Lights, Underbody Lights, More to come.
    Yeah, I have one on mine.. Its a class 3 hitch, and a fairly easy install.. I put it on by myself... did have to take off the bumper, but eh...Good hitch though...
  12. Aug 9, 2010 at 5:13 AM
    larryde09
    Larry
    Rochester, NY
    I put on my drawtite by myself. It is completely bolt on and utilizes the bumper bracket bolts and cost only a couple hundred (including the wiring). The directions say that you can slip the hitch on behind the bumper by simply loosening the bolts, but it fit so tight on my truck, I had to remove the bumper and use a mallet to pursuade it into position. Regardless, I did it myself (but I recommend a friend if available).
    Not sure where you're planning on putting your recovery strap/shackle, but they sell shackles that slip into the hitch receiver. Otherwise, there really shouldn't be a problem if your attaching to the frame.
  13. Aug 9, 2010 at 6:28 AM
    Fire931
    Fire931 Well-Known Member Vendor
    VA
    00 4Runner
    i might have a stock one i can fix you up with. its the original one that came on my truck which was removed looooong ago. just a thought.
    ohh and i've shipped several of these hitches already and its not quite as pricey as you'd think.
  14. Aug 9, 2010 at 6:36 AM
    Pugga
    Massachusetts
    F-150 Mod
    I installed a Hidden Hitch laying on my back in a parking lot in about an hour. No need to remove the bumper and no drilling, cutting or welding required. I got it through either Autoanything or JCWhitney, they were running a free shipping deal. I was in the $150 range for the hitch, shipped plus another $30 for the 4-prong wiring harness that connects to the tail lights. No wire splicing required, just plug and play.
    The Hidden Hitch should not cause any problems using a shackle to pull someone out. I'm not sure what sort of problems you're talking about but the Hidden Hitch should not cause any problems using a shackle to pull someone out. I have a '07 so if you'd like me to check a dimension or take a picture, let me know, I'll post it up tonight when I get home.
  15. Aug 9, 2010 at 6:37 AM
    98SR5Red
    98SR5Red Well-Known Member
    Justin
    Maine/New Jersey
    98 SR5
    Sway-Away racerunners up front, Downey leafsprings (5 pack) and Bilstein 5125's in back, 2" body lift, K&N/AEM air intake, Energy Bushings, Nology plug wires, Custom front/rear bumpers and sliders. Downey header and custom exhuast from there back.
    Not related, but cheers to a fellow Northern New Englander! I'm not in the area as of now, but will be back to Maine shortly I hope!
  16. Aug 9, 2010 at 7:22 AM
    scottri
    scottri Well-Known Member
    Scott
    Tigard Oregon
    '10 Sport DC TRD Sport PreRunner
    Cover King Seat Covers, WeatherTech Liners, PopNLock, storage bin locks, N-Fab Step bars, and G4 Elite Tonneau cover.
    I had one of the UHaul hitches on my old truck and it bolted right up with no problems. I towed boats and trailers with it and it always did the trick and it was pretty cheap as well. I bolted it up myself.
  17. Aug 9, 2010 at 7:24 AM
    Pugga
    Massachusetts
    F-150 Mod
    Haha, with a name like Farva, who'd have ever guessed you were from New England? There's actually a quite a few of us on here but we're definitely outnumbered.
