Thinking About Changing my 17" stockers to a 16" wheel - I have a couple of questions
Discussion in 'Wheels & Tires' started by greenrustic, May 25, 2012.
  1. May 25, 2012 at 6:36 PM
    greenrustic
    greenrustic [OP] Well-Known Member
    NY
    2012 DCLB 4x4 TRD SPORT
    Access LTD Tonneau Cover, Weather Tech Digital Fit Mats, Weather Tech Rain Guards, 35% Tint up Front, AFE Dry Power Intake Filter, Debadged, GrilleCraft, OME 884x, OME 9000 NitroChargers, Icon 3 Leaf Progressive AAL
    As the title says I am thinking about changing my stock 17" TRD sport wheel to a 16" wheel and then running 265/75/16 tires. My questions are as follows:
    • Do I just take the TPMS out of the stock wheels and put them in the new ones?
    • Do I need to replace my stock spare wheel and tire too?
    • Is there anything else I should be considering?
    The reason for wanting this change is I prefer the look of a smaller wheel and 16" tires are less expensive and look bigger/more aggressive.
    Any help is appreciated...Thanks!
  2. May 25, 2012 at 6:43 PM
    Johns Taco
    Johns Taco I'm not 4x4, and have an open diff. So i'm 4x1
    Albuquerque, NM
    05 DSM Base SR5 Slug Taco
    Full custom stereo, onboard air compressor, train horns, spacer lift, 30" tires, optima yellow top, rear slider window & tailgate anti-theft mod, pop & lock, class 3 tow hitch, lights in bed, Ultra Gauge, Weather Tech mats, yellow fog lights, camper top, air lift rear airbags, rear diff breather mod, soon to be more...
    16" wheels will not clear the rotors.
  3. May 25, 2012 at 6:51 PM
    TacoDawgfan
    TacoDawgfan Hunker Down You Hairy Dawg!
    Georgia
    2011 Silver 4x4 TRD Sport w/JBL
    5100's at 1.75, Rear leaf TSB, Moto Metal 951 16x8, BFG TKO2 265/75/16, AFe Stage 2 CAI w/pro dry filter, Kenwood DDX374BT installed with Idatalink Maestro kit, Access Loredo tonneau cover, N-Fab steps, Tinted windows, EGR in channel vent visors, UGA drink coasters in the front cup holders, and a Graco car seat in the back seat
    Worked on my 2011. 16x8 Moto Metal 951 4.5 bs 0 off set. Unless there is something different on the 12's then it should work pending the wheels. Some 16's wont work and some will from what I've read.
  4. May 25, 2012 at 6:59 PM
    Johns Taco
    Albuquerque, NM
    Certain year tacomas have very close clearance. I once mounted stick on weights on the inside of the rim and the calipers were hitting the weights, ( I used to work for Toyota) this isn't all tacomas but some have a lot of clearance and some almost have none. Not sure why.
  5. May 25, 2012 at 6:59 PM
    greenrustic
    NY
    I'm pretty sure I won't have an issue with clearing the rotors. I don't think the rotors on a TRD sport are any different then the TRD OR and the OR comes stock with a 16" wheel.
  6. May 25, 2012 at 7:00 PM
    krimson
    krimson Nothin
    TRD Off Road
    OME 3" lift with 885 coils. OME Shocks with TSB 1.5 AAL. 285/75/16 KM2s. XD Hoss 16" wheels. DDM Tuning 6000K HIDs, H10 6000K Fogs. BHLM. Debaged. 20% tint on front windows.
    My 16" XD's did :notsure:
  7. May 25, 2012 at 7:01 PM
    greenrustic
    NY
    This is what I'm looking at a 16x8 4.5 (0 offset)
  8. May 25, 2012 at 7:07 PM
    TacoDawgfan
    Georgia
    You have to be careful though, I remember a thread on here where someone ordered the same specs on a different wheel and they didn't clear. It depends on the particular wheel. When I got mine I knew many on here already had these so I knew they would work.
  9. May 25, 2012 at 7:08 PM
    06tacomakev
    06tacomakev Well-Known Member
    Kev
    Victoria BC
    2003 tacoma 4x4 dblcb
    It's not the rotors that give you problems. It is the calipers. Tough finding a 16 that will fit. make sure it is a spoke design. Good luck
  10. May 25, 2012 at 7:10 PM
    Slimwood Shady
    Slimwood Shady I love your mom!
    Linwood
    Hampton, VA
    '17 Tundra; '16 Odyssey; ;14 A4
    On off rd, came with 16 and now have 16" 7089 with a 0 offset
  11. May 25, 2012 at 7:18 PM
    Schwinn
    Schwinn Well-Known Member
    Jamie
    Georgina, ON
    2012 TRD Sport with Trail Teams package
    Did you price out the tires? On my old car, I went with a smaller rim only to find out later there was about a 5-10 bucks difference per tire.
  12. May 25, 2012 at 9:12 PM
    06tacomakev
    Kev
    Victoria BC
    It is so touchy. I just sent back some 17's that had the same offset. I tried forever to find 16's that worked. Gave up and am now looking for seventeens. Got the duratracs for 17's. Just got to find the wheels. Very frustrating as I thought I had it beat with some 17 inch Daytonas, but they stilll hit the caliper.
  13. May 25, 2012 at 9:25 PM
    KenLyns
    KenLyns 8-in. Third Member
    Belly of the Beast
    4x4 TRD Off Road Full-Auto
    All-Pro Bumper, CBI Sliders, Icon Coilovers, BudBuilt Skids, aFe Intake, Icon VS Rear Shocks, Timbren Bumpstops, All-Pro UCAs, JDM Steering Wheel, ViAir Compressor, Klearz LED 3rd Brake Light, Pop-N-Lock Tailgate Handle, Husky Front Flaps
      Yes, the stock TPMS will work... most of the time. When I switched wheels, the OEM TPMS sensors wouldn't seal properly against the new wheel, causing air leaks, so I bought new sensors. Others with the same wheel reported the OEM sensors fit fine.
      The spare would be 1" smaller, not an issue for short-term use. Stay in 4x2 and disable VSC when running the spare.
      Brake caliper clearance as others have mentioned. Stick with wheels that others on TW have fitted successfully. I took some pictures after installing mine:
      http://www.tacomaworld.com/forum/bu...nig-countersteer-offroads-40.html#post4586183
      You may need new lugnuts. Aftermarket wheels tend to require conical seat lugnuts. The OEM wheel studs are short to save weight. Depending on the specific wheel pad thickness, extended-thread lugnuts may be required to grab onto a sufficient number of threads.
      265/75-16 tires may rub the mudflap depending on wheel offset. Husky makes mudflaps that provide greater clearance.
  14. May 26, 2012 at 8:02 AM
    TacoDawgfan
    Georgia
    My tpms worked just fine with my aftermarket wheels. Discount Tire mounted mine up, only had to buy the "rebuild kit" for them.
  15. May 26, 2012 at 6:17 PM
    greenrustic
    NY
    Thanks for all the insight...
