Thinking about getting bump stops from sumo spring
Discussion in '3rd Gen. Tacomas (2016-2023)' started by christianhle, Jan 15, 2023.
  1. Feb 28, 2024 at 5:38 PM
    #41
    Tacoma091919
    Tacoma091919 Well-Known Member
    Tim
    2019 OR DCLB
    Get the 612-40 version. 610-40s were made for 2nd Gen. I have Deaver stage 2 springs with about 2-2.5” lift and the 612-40s are have some clearance to allow for articulation, but will engage if needed for heavy loads. You don’t want to be bouncing off of them all the time, they are stiffer than springs. Before I upgraded my suspension I added them because I was squatting with factory leafs with my topper etc. I could definitely feel it when I would go over a bump, it was a little jarring.
    FergBoi93 and bkhlrTaco's like this.
  2. Feb 28, 2024 at 6:16 PM
    #42
    FergBoi93
    FergBoi93 Active Member
    Cragan
    North Carolina
    2025 Toyota Tacoma TRD Off-road iForceMax
    Thank ya. I’ll keep that it mind.
  3. Feb 28, 2024 at 8:42 PM
    #43
    Max8
    Max8 Thinking Outside The Box until they close the lid
    23 SR5 DCLB stock
    2012 ARE DCU contractor cap, Transmission aftercooler kit (Iconic Fabrication & Hayden 698), Bed Stiffeners (Kwikfab LLC), Firestone airbag leaf springs, wye connector and pressure gauge, Tailgate security mod (mfgr. by Christian06 on TW), OEM mud flaps, OEM tailgate electronic lock, Tow-Pro Elite Electric Brake Controller, Anytime Backup Camera hardwired 42 ft to camper, RCI Alum. Skid plates & cat covers, 2WD LO mod (BB Tuning), Fumoto oil drain, ECT Always-On Mod (hardness by Funman1steve), 6awg DC DC tow charger wiring, inline 60 amp breakers & battery terminals, Kill switch, KJTO driver side grab handle, Hood hold open gas struts, Scangauge III, Seat Covers (Seat Covers Unlimited... wearing poorly),
    Sumo springs, blue, on 2012 and now 2023 tacoma for towing. They take up the former free air bounce and seem to help on major bumpiness. Easy install on rental lift.
  4. Feb 28, 2024 at 8:50 PM
    #44
    FergBoi93
    Cragan
    North Carolina
    I’m about to use the auto shop on my base and rent a bay to install 1.5” AAL pack on the rear and add sumo bump stops with a ubolt flip kit.
  5. Feb 29, 2024 at 12:28 AM
    #45
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    I have a one inch rear lift and not touching the bumps.
    FergBoi93[QUOTED] likes this.
  6. Feb 29, 2024 at 2:46 AM
    #46
    faawrenchbndr
    faawrenchbndr Til Valhalla
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    I have the 612-40 blue set on a relatively stock 23 Sport. No lift, stock suspension. There is about 1/4” free space when bed is empty. The do contact with large bumps or big road dips.
    I will see how they preform when I do some towing this spring. Will take a 9 hr trip to pick up a car on a trailer from a shop.
    FergBoi93 likes this.
  7. Feb 29, 2024 at 6:55 AM
    #47
    FergBoi93
    Cragan
    North Carolina
    Do you have the spacer under the sumo? If so, how much space do you have between the frame and top of sumo?
  8. Mar 1, 2024 at 2:07 AM
    #48
    VaToy
    Parts Unknown
    No spacers, the bumps do not touch front and rear. I'm lifted 2/1 on 5100s and when driving and slights bumps that I hit prior to the install re way better now. We have some roads with some issues, small pot holes and man hole covers, these new bumps have really helped as my ride feels great!
  9. Mar 1, 2024 at 6:09 AM
    #49
    FergBoi93
    Cragan
    North Carolina
    Nice. About how much space do you have between the top of the sumo and the frame?
  10. Mar 1, 2024 at 6:35 AM
    #50
    faawrenchbndr
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    Think of it this way, with the blue SumoSprings there will be right at 1/4” of clearance with stock suspension. Add a lift and the clearance will increase the same amount as the lift.
  11. Mar 1, 2024 at 6:47 AM
    #51
    ridefreak
    ridefreak Well-Known Member
    NM
    2006 DCSB TRD
    minor tweaks
    I have the blue sumos on my G2, no lift, new recall springs and 5100s. On mine they barely touched the frame all the time from day one, called sumo and they said that's normal w/ no lift. I love them when there's a couple hundred pounds in the bed like my dirtbike but the unloaded ride was a little harsh over joints in the road and small bumps. I recently put on a topper on and the added the weight was all that was needed to take that harshness out. I still have the stock sway bar, I noticed the sumos also reduced body roll, it wasn't bad before but it's noticeably better with the sumos. I didn't really care for the Sumo's ride on a stock height truck unloaded but they absolutely improve things when you add a little weight.
    PooTaco and FergBoi93 like this.
  12. Mar 1, 2024 at 6:50 AM
    #52
    stuttgart1
    stuttgart1 Well-Known Member
    2019 TRDOR
    I have the blue Sumo bump stops in the rear. Stock suspension with the exception of rear Hellwig helper springs. With my 850 lb Four Wheel camper the Sumo springs are barely touching and cushion the ride nicely. I prefer this set up as I did t want my truck riding like a F350 when the camper wasn’t mounted.
  13. Mar 1, 2024 at 6:51 AM
    #53
    OZ TRD
    OZ TRD Well-Known Member
    Central Coast CA
    6sp Manual TRD PRO - Lunar Rock '21
    Evo A SmartCap, Cali Raised Sliders (0 degree), 2WD low Mod, Puddle Pods, 3 switch overhead panel, 8 slot middle console panel, Custom driver's switch panel, Rek Gens, 265 75 16 Falkens, lil B Bed Stiffeners, All new Speakers, Diff Breather, AC Drain, Many interior bits...
    @jgr81
    How did the 'stubbies' perform? Did they hold-up post chop?
    (Let me know if they atre still availablr...)
    Ive added bumps in the front, and Im looking for something for the rear - not load-bearing. Only as a softer bump...
    Is your set-up better now?
    Has anyone haf any issues withe the added bumpstop heights in the rear?
    jgr81[QUOTED] likes this.
  14. Mar 5, 2024 at 1:12 PM
    #54
    jgr81
    jgr81 Well-Known Member
    Jen
    Summit County CO
    16 Tacoma TRD OR Access Cab, 03 4runner v8
    Yeah they worked great, never had any issues at all with them falling apart or anything. My german shepherd stole the top donut part for a chew toy and she hasn't been able to destroy them either!
    They are probably still in the same place buried in my shed, I'd be happy to poke my head in there tonight or tomorrow and see if I can find them if you are interested in them!
    The ubolt flip and superbumps are better for sure, I rarely contact them from what I can tell, prob because I have the HD OME springs on my access cab and they are pretty stiff unless I'm loaded down or towing.
    I wouldn't call the sumo springs a softer bump really, but compared to the harsh bottom out of the stock bumps I guess that could be considered softer in a way. The sumos were pretty harsh at full height before I was lifted for sure, but kept the truck from sagging under load which is what I was looking for at the time.
  15. Mar 25, 2024 at 1:13 AM
    #55
    PooTaco
    PooTaco Well-Known Member
    Utah
    2020 Tacoma Access SX 4x4
    This is exactly a what I was hoping. :thumbsup:
