Thinking About Installing A Hydrofoil On My Boat
Discussion in 'Boating & Fishing' started by LTE, Aug 11, 2013.
  1. Aug 11, 2013 at 7:29 PM
    LTE
    LTE [OP] NRA Benefactor Member
    in my own little world
    07 SR5II; Longbed; FLyzeyes LED
    window tint, step bars, Flyzeye LED interior console light
    I have a Mercury 25hp (4 stroke) on my Tracker Pro Team 175.
    The front rides up extremely high and I would like for it to level out. What experience do you guys have with these? Any certain brand or type you recommend over others?
  2. Aug 11, 2013 at 9:09 PM
    Bendecco
    Bendecco Well-Known Member
    Warren
    North OC Southern Cali
    12 MGM Prerunner DCLB
    Wet Okole, Weathertech, TRD FJ Trail Team Wheels, 265-75-16 Michelin AT2, Nfab side steps, Blue Guy Console cover,Front billy 5100 coilovers, tailgate and bed hatch locks
    It should help but I think shifting weight or ward would help a lot more than a foil...
    Any pics of your boat?
    I have a foil on mine but I also have a 40hp 4 stroke on my 13ft boat and still have 40lbs of lead in the bow to keep it from pounding....
    How many rpms are you able to get at WOT with the 25?
  3. Aug 12, 2013 at 4:34 AM
    LTE
    Here's a stock picture of it. Everything is the same except the engine is a little smaller.
    Not sure what my rpm is at WOT
  4. Aug 13, 2013 at 7:08 AM
    jethro
    jethro Master Baiter
    Geoff
    Southern NH
    13 Access 4x4 TRD Offroad
    Empty gas tank mod
    The 93 Starcraft I just bought had a hyrdofoil on it when I bought it. It's awesome. Makes the boat jump on plane very quickly and ride very stable. They aren't very expensive, so definitely worth a try. I usually fish with one other person and when we motor up we both sit in the back and it still planes out perfectly.
  5. Aug 13, 2013 at 7:14 AM
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
    they work well for us here
    or get a big friend to sit up front
  6. Aug 13, 2013 at 7:20 AM
    BDJ
    BDJ Well-Known Member
    Brandon
    West Monroe
    2012 TRD OR 4x4 DBL Cab MGM
    I have a 25HP Mercury 4-stroke big-foot on a 1448 tracker Grizzly, and with any weight in the boat (ecspecially the rear) it would not plane out. I put a hydro-foil on it and it does push the back of the boat up out of the water quicker allowing it to plane out faster. But like stated above Weight distribution is key too. Also you have a lot of boat for a 25HP 4-stroke in my opinion.
  7. Aug 13, 2013 at 7:23 AM
    BDJ
    Brandon
    West Monroe
    Also I bought the Attwood brand. It claims to have less drag after getting the boat on plane due to the angle of the foils.
  8. Aug 13, 2013 at 2:09 PM
    pull n pony
    pull n pony New Member
    Jamie
    Mineral Point Mo.
    97 regular cab auto 4x4
    Does the boat have power trim? Where the motor is positioned while coming out of the hole and on plane will have alot to do with the attitude of the boat. Also the foil will help alot on hole shot then if the motor is set right it should be out of the water when on plane.
  9. Aug 13, 2013 at 7:10 PM
    LTE
    I took it out today and I can now provide more info.
    WOT RPMs is 5000. When I rise the prop up, the angle is worse. Weight is mainly in the rear of the boat with 2 batteries and the gas tank. These are non movable due to the structure of the boat.
    The prop is stock 3 blade from Bass Pro, so I'm not sure the exact specs.
    I agree, it is a lot of boat, but in my area, that's about the limit you can have for the majority of the lakes.
  10. Aug 14, 2013 at 6:40 PM
    Bendecco
    Warren
    Rpms are close but a little more would be better
    Do you have a pic of the motor on the boat from the side?
    Maybe you can raise it up a hole....that would bring up te rpm and drag less....
    Those numbers are super good for a 25hp....
