Thinking about investing in a pool for the house
Discussion in 'Off-Topic Discussion' started by thestrangebrew, May 24, 2010.
  1. May 24, 2010 at 10:25 AM
    thestrangebrew
    thestrangebrew [OP] AlphaPlanner
    Brian
    Dos Palos CA
    TRD 4x4 Rugged Trail Edition
    Black Badges, Black Center Console
    As the title says. What things should I look for in terms of financing, contractors etc. How does financing typically work for a pool. I'm looking for an in-ground one, not very big, but it will be irregularly shaped (ie it'll have to be L-shaped to go from a portion of my backyard to the sid of my house due to lot constraints). Any tips or advice?
  2. May 25, 2010 at 12:36 PM
    techgeekwill
    techgeekwill Well-Known Member
    Spring, TX
    18 Inferno TRD OR DCSB
    I've not done it, but I did look into it. Budget for at least $40k for a basic pool. Depends on the wall material and other things.
    I'd call around and get several quotes of course, ask for references and check contractors against the BBB. A lot of pool contractors will take your money and deliver a poor product or nothing at all.
    I decided to forget about it for now. The cost was too high, and I didn't feel like getting into debt any more than I was. It would add value, but you have to deal with the construction and everything else. What you budget for $40k will easily go up to $50k+.
    I'm planning on just buying a house with a Pool already built in the next year or so.
  3. May 25, 2010 at 12:50 PM
    paulm09tacoma
    paulm09tacoma Well-Known Member
    paul
    connecticut
    09 access cab trd
    imo- the pool is more of an investment to you and family then to your house and real estate value. they are a ton of work but a lot of fun. also homeowners ins can go up with an inground pool.and like techgeekwill said' 40k is probably a starting point. good luck.
