Thinking about re-gearing
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Georgeth1022, Mar 10, 2022.
  1. Mar 10, 2022 at 9:56 PM
    TacoTuesday1
    SD CA
    but youtube said you just have to do the yellow paint mark and make it look like a comet tail
    Satxoi and GlitterGulch like this.
  2. Mar 10, 2022 at 9:57 PM
    socalexpeditions
    socalexpeditions IG: @socalexpeditions
    We all wish it was that easy :rofl::frusty:
  3. Mar 10, 2022 at 10:14 PM
    Jason TRD OR
    Jason TRD OR SIBI BUILT LLC
    Sibi Built LLC Placentia, CA
    16 Tacoma TRD Off Road 4X4
    King suspension w/ compression adjusters custom valving and 700# coils. Icon DJ uca. Icon RXT leafs Option #3. Durobumps. Demello rock sliders. Demello 30” Light Bar Baja Hoop bumper with Smittybuilt X2O winch w/ Amber baja design fogs w/ single row Baja Designs S8 amber light bar. Brute force Fab HC rear bumper. Behind Grille Light bar. TRD Pro Skid plate. Pelfrey Mid and Transfer case skid. TC spindle and cam tab gussets. Pop and lock. Method NV wheels 16”. SpiderTrax 1.25” wheel adapters. Yokohama Geolandar M/T (315/75/16). CMC. Radiator core reinforcement. Pro grille. Tailgate inlays. Baja Designs A pillar Ditch lights. Leer 100 XQ shell w/ power locks. In bed mounted spare. Blacked out emblems. Bed Mat. Bed Stiffeners. K&N air filter. Black Headlight Mod w/ LED projectors. Wrap Armor Anti glare hood and bedside decals. American flag decals. Northstar 24F AGM Pro battery. Differential breather relocate to rear tail light. Prinsu Designs Cabrack and Cap rack. OVTUNE Sibi Custom performance 4.88 91 fuel AGM . Nitro Gear 4:88 gears. Mountain hatch tailgate insert. In bed mounted Krazy Beaver shovel with Relentless quick fist bedrail mounts. MESO ultimate turn signals. AJT Designs Quicksand Key Fob. ECGS front needle bearing bushing replacement. Tepui LoPro 2 RTT.
    Hey I know those guys :)
    nattykanari and Georgeth1022[OP] like this.
  4. Nov 20, 2022 at 8:34 AM
    Jason TRD OR
    @Georgeth1022
    How’s everything been after 6 months of enjoying the gears?
  5. Nov 20, 2022 at 9:16 AM
    Stelcom66
    Stelcom66 Well-Known Member
    2007 2.7L 5MT 4WD
    I'm curious - what rpms would a 4.0 V6 automatic with stock gears/tires be at 65-70 mph? Maybe that's a loaded question as the different models like TRDs and/or Off Roads may be geared differently.
  6. Nov 20, 2022 at 9:57 AM
    Danke5305
    Danke5305 Well-Known Member
    2013 tacoma prerunner
    For what’s it’s worth, ECGS is something to look into the have complete 3rd members and front diffs assembled. I went through them and the only thing is you have to reuse your old flange for the 3rd member
    https://eastcoastgearsupply.com/
  7. Nov 20, 2022 at 10:09 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    I'm gonna say at least in the low 2k rpm range. Been a while since I had stock tires
  8. Nov 20, 2022 at 10:38 AM
    Stelcom66
    2007 2.7L 5MT 4WD
    Ok - I have heard of a few being just under 2k rpm. Not sure if those were stock. My 2.7L 5 speed manual is only around 2350 rpms at 65 mph. I say only because every other 4 cylinder manual vehicle I've had was geared shorter, for a higher rpm. I found out that my truck doesn't have the stock tires after seeing the label on the door, has 265 70R/16s while stock is P245/75R16. I always thought it was a bit too tall, then I saw that could be due to the slight tire diameter increase of the 265s.
  9. Nov 20, 2022 at 10:47 AM
    MurderedTacoV2
    MurderedTacoV2 Booty Admirer
    Adam
    Hudson, New Hampshire
    06 Taco TRD OR
    3 inch lift, B110’s, Dakars, Dirty5’s, Dual Locked
    I am on 35's, armored front and rear with skids and a rtt. 4.56's are best if you do highway driving, 4.88's rev too high in my opinion, 4.88s with 37's maybe. at 70 im at like 2400 rpms, 75 2650 rpms, anything past that is just wasting gas.
    Its_Taconie likes this.
  10. Nov 20, 2022 at 10:48 AM
    gil_S
    gil_S Well-Known Member
    Seattle, WA
    Same year and tire size as OP. Recently went to 4.56 through ECGS. Very noticeable increase in torque and faster acceleration. Shift points feel more natural and the engine isn't revving like crazy to get up to speed. Truck is generally much more fun to drive again. Kind of forgot how it was supposed to drive after slowly adding more weight and accessories over the years.
  11. Jun 26, 2023 at 7:29 AM
    Its_Taconie
    Its_Taconie Well-Known Member
    Nelson
    North Hollywood
    2007 Tacoma DCLB PreRunner
    Fox Racing 2.5 (F); 2.0 (R), Archive Garage Leaf Springs, hanger/shackles, shock relocation, U-Bolt Flip Kit PLM P37 (TE37 Knockoffs) Bronze wheels, Nitto Ridgeline 35s, C4 Overland Bumper, Total Chaos Uppers, Outgear Solution HC Swingout, OTTune 4.88 Nitro Gears
    Reviving this thread instead of starting another.
    This comment is what I was looking for. Im jumping to 37s at the end of the year. I have a rear bumper on order and a front sitting in the garage and couldnt find a solid answer to regearing with full armor. I am torn between 4.88 and 5.29 but leaning more towards 4.88.
  12. Jul 4, 2023 at 1:00 PM
    MurderedTacoV2
    Adam
    06 Taco TRD OR
    I would do 4.88's then especially if you daily/do a lot of highway. Also, a big factor is tire weight. I just switched out my regular wheel with maxxis bighorns for toyo MT's with beadlocks, easily added 30 pounds per corner and i can feel that especially uphill.
    Its_Taconie[QUOTED] likes this.
