Thinking About Some 5100s
Discussion in 'Suspension' started by Worstbullet, Sep 3, 2014.
  1. Sep 3, 2014 at 12:38 PM
    Worstbullet
    Worstbullet [OP] Well-Known Member
    Hunter
    Franklin,TN
    09 PreRunner SR5
    Pelfreybilt hybrid front bumper, Allpro rear bumper, OME 3" lift, Goodyear Wranglers
    So I took my truck in the other day for an oil change and got a call saying my rear shocks are have a small leak and my fronts are old. So I now have an excuse to get better shocks. I know I want to get 5100 because that's what everyone on here has said to get. I'll be using the factory springs because I'm on a budget and they are compatible. So I have a few questions that I haven't been able to find the answer to. I'm wanting to set the 5100s at 2.5 inches.
    1. To set the 5100 at 2.5 inches will I need new UCAs? I've read you have to and you don't have to.
    2. Could I get away with 2" lift blocks in the rear? Would that make the truck sit level? My taco has 3 leafs (not sure if that is relevant).
  2. Sep 3, 2014 at 11:18 PM
    Friedtacolover
    Friedtacolover Well-Known Member
    Travis
    Ontario, Ca
    2017 DCSB Off Road 4x4
    my build tread: https://www.tacomaworld.com/threads/socal-no-shame-poser-build.513084/
    My shop measured my truck and 1.75 in front made me sit level. I did nothing to rear so if u do max 2.5 and then raise rear in theory youd be back where u started but a quarter inch off level? Right??
