thinking about trading in my 2.7 for a v6
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mcleod90, Apr 17, 2011.
  1. Apr 17, 2011 at 1:25 AM
    mcleod90
    mcleod90 [OP] 150,000 miles and counting
    sean
    modesto ca
    05 double cab
    i knew my truck doesnt have much power but i didnt know it didnt have ANY power. i was heading to the bay area and i was going up the altamont, i had to floor it just to make it up the hill going 60 mph, or when i go to pass a car i again have to floor it and the speedo barely moves. ok enough bitching.
    i was thinking of trading in my truck for an used access cab or double cab. i have found 3 that seem pretty good for me.
    here is the first one i found http://modestotoyota.com/preowned/i...oublecab_prerunner/vehicle/5TEJU62N35Z108429/
    it is a double cab which isnt really important now but i figure it will be when the time to comes to crank out some little mcleod90s, black is always a plus, has all the features my base model doesn't have.
    the bad about it is obviously the ridiculous high miles. i drive maybe 1000 miles a month and that is pushing it.
    this one is probably way to high for my budget http://modestotoyota.com/preowned/i...sr5_double_cab_v6/vehicle/5TELU42N86Z277196/#
    the other one is http://www.pleasantonauto.com/detail-2005-toyota-tacoma-used-6893796.html
    the good it has less miles, its a 4wd
    the bads its not a double cab.
    and what is a good website to look at your trade in value? i kbb and it said mine in good condition is $17,070 :confused:
  2. Apr 17, 2011 at 4:30 AM
    Tepidy
    Tepidy Well-Known Member
    Ted
    upstate NY
    11 tacoma 4x4
    Toytec Coil Overs 3.00" DSM UCA's (Desert Products) TSB 4 Leaf w/AAL by Pro Comp Bilstein 5100 rear 1"ToyTec SwayBar Drops 1" diff drop Detroit Trutrac Rear Diff Nitro 4.56 Gears Doug Thornley Header MagnaFlow Cat Back Exhaust Custom Built Rear Plate Bumper Custom Built Front Plate Bumper 4X Innovations Rock Sliders ATO Front Skid BAMF Rear Diff Skid Uniden 510XL Pro CB Raceline Renegades BF Goodrich Mud Terrains KM2's 265x75x16 WeatherTechs Rear Diff breather Relocate Intake Resonator Removed Yellow Wire Mod
    my truck has plenty of power I can cruise all day at 80mph and jumps up to 100 with no issues. I have a 5 spped - never tried an auto
  3. Apr 17, 2011 at 4:39 AM
    Drogers
    Drogers Well-Known Member
    Derek
    Sayville, NY
    2010 Reg Cab 4X4 5sp manual
    Leer 100XR Topper, Re-wired interior dome light, Shaved front mud flaps, Rebadged flat black, Avid offroad light/bull bar, Yellow OEM Fog Light Mod, 265/75R16 Nitto Terra Grapplers, stock 16 steelies painted flat black, K&N air filter
    Yeah, the key is having 5 sp manual in the 2.7. You can make the most of your power. You can downshift while climbing those hills and make the climb with ease. Good luck with your decision.
  4. Apr 17, 2011 at 4:39 AM
    rancher 420
    rancher 420 Well-Known Member
    Adam
    north east ohio
    2011 plain jane 4x4
    aftermarket fogs with HID LEER 100R cap pioneer head unit tinted windows silverstar reverse lights tow hitch cobra 75 c.b. vent visors new recovery hook in the front camping set up in the back ( rug, air mattress, fan, and heat)
    when i was test driving the 2011 tacomas, i ended up with a standard, because the auto's were way worse then the standards as far as power. there also in my opinion was an issue with it switching back and forth from 3rd, and 4th gear in the auto
  5. Apr 17, 2011 at 5:27 AM
    jpmorrisvb
    jpmorrisvb Well-Known Member
    Jimmy
    Virginia Beach
    2014 Barcelona Red TRD Off-Road PreRunner
    Clazzio seat covers, KB Voodoo Powder Coated Tailgate Cap, OEM running boards, ImMrYo Rear-View Mirror Lift Bracket, 35% Tinted windows, EGR window vents, color matched door handles and tail gate lift, WeatherTech FloorLiners, OEM bed mat, sound dampening on rear wall and rear doors, on anytime foglight mod
    My '10 AC AT has plenty of power and accelation in my opinion. Just this morning on an empty divided road I was sitting at 60 and with little or no effort was at 85 with more to spare.
    It is not the arrow, it's the Indian ..... :cool:.
  6. Apr 17, 2011 at 5:34 AM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    The 6 have all the power you'll ever want but it comes at a cost they are not exactly easy on gas.
  7. Apr 17, 2011 at 6:16 AM
    bigcoffinhunter
    bigcoffinhunter Well-Known Member
    I did the same move. My 2.7 got bogged down and lugged terribly when loaded with people and gear. Downshifting doesn't work when you're in first! lol
    I get 19-20mpg with the 6 auto, not a bad trade off from the 22-23 I got with the 2.7. Well worth it I think.
  8. Apr 17, 2011 at 6:30 AM
    PSJ
    PSJ Prerunners Work
    Sebastian Inlet
    09 Access Cab Prerunner
    Rear Leaf spring TSB, Bilstein 5100's all around w/ front set at 1.75", 265/75R/16 Mickey Thompson Baja STZ's, Trailer hitch w/custom wiring, AFE drop in dry filter, Rear Diff breather mod, Debadged truck, customized stock TRD wheel center caps, added factory fog lights, bed mat, door sills, tinted windows
    If your making many trips in hilly conditions and it bothers you to not be able to rip up the hills, then ok. But if this is an occasional thing, you may want to think about it...
    I do have the 2.7L with the manual, and have had no need for more power or speed in traffic thus far. ( I did not say desire :D )
  9. Apr 17, 2011 at 6:51 AM
    shawnd2
    shawnd2 Well-Known Member
    Shawn
    Toronto, Ontario, Canada
    08 Tacoma Access Cab 4x4 TRD Offroad
    I had a 96 Tacoma with the 2.7l 5sp manual and sold it for a 08 access cab v6 auto.
    Man! What a difference!
    My 08 is much more enjoyable to drive, and to be honest I don't really notice a difference in fuel economy as I always had my 2.7l to the floor, and I'm not that fast of a driver as the max speed limit here is 60mph (I would TRY to cruise around 70).
    I can only imagine a 2.7l 05+ tacoma is worse as it is a bigger and heavier truck then the previous tacomas despite the slight increase in hp.
    Don't get me wrong, I love toyota's 4 cyl as I have had a 84 4runner, 85 4runnet, 86 camry and a 96 Tacoma. All with 4 cylinders and all were great vehicles.
    Having said that I don't regret it at all moving up to the 4.0l, and I'm sure you won't either providing you find one at a good price.
    Just my two cents....
    Shawn
  10. Apr 17, 2011 at 7:40 AM
    DPR921
    DPR921 Well-Known Member
    Dylan
    Cheshire, MA
    08 SR5 4x4 2.7
    I just bought a 5 speed 2.7 access cab 4x4 about a month ago and to tell you the truth the day i bought it i was tempted to drive back and get a 4.0 since it felt so slow! Especially after trading in a 13 second car for this truck. Anyways after getting used to the power and how to drive it i love this truck! Especially i love the fact of getting 24 mpg. Especially when im dropping $4 bucks a gallon on gas and driving 140 miles a day. Now that im used to the truck i wouldnt trade it for the world! I love this truck, the 4 banger keeps me out of trouble and is also extremely fun for wheeling since it seems to be rather torquey and since im used to driving jeeps as well. Anyways regardless of the prices of everything i would still rather drive my 5 speed 2.7 over a 4.0. Also since about all the 4.0s are autos and i beileve autos are reserved for the females.. anyone can drive one of them whats the fun in that??
  11. Apr 17, 2011 at 7:40 AM
    fajitas21
    fajitas21 XMF - Extreme Mexican Food fo Life!
    Lee
    Orange, TX
    2017 Tacoma DCSB Off Road
    I put peanut butter on it.
    I tow several times a month, 3000 - 5000 # loads, so the 4 cyl wasn't an option for me...but if all I did was drive the truck around I think I'd go 4 cyl.
    However, just a thought about gas mileage.
    I bought my wife a '11 equinox with the 4cyl eco-drive whatever engine (marketing crap). It claims 32 MPG highway. I normally get 28 Hwy and I drive very conservative and keep the truck unloaded. I think Chevy is very liberal with their MPG numbers.
    On the other hand, my Taco said 21 Hwy with the v6, and I've gotten as good as 26MPG with a wind at my back doing 65 on the HWY. I can easily hit 20 - 22 all day long. Numbers are very "real world'.
    With all that said, I drive my mom's v6 equinox around, and I feel the MPG is about the same if not sometimes better than my 4cyl equinox. It's a heavy crossover vehicle and I think the 4 is struggling to move it.
    That's why I think the v6 taco is the best choice for me, and I dont' think my fuel mileage is bad considering I have that extra power when it's tow time, but everyone's needs are different. If I lived in they city and didn't have access to a trailer, and didn't need one. I think i'd have got the access cab 4cy, so I could have a longer bed (I have the short bed DC), and better city MPG.
    But seriously, don't get hung on gas prices. I put 91 in my truck and it's about $4 / gallon, which works out to about an average tank price of $65 bucks with today's prices. That's really only a $15 - $20 / tank increase from when I had my first taco in 2006 buying $2.00 gas. Considering I drive about 2500 - 3000 miles a month for work, that's working out to be around $100 - $125 bucks more a month in gas withv~ 8 fillups. Most people don't drive nearly that much.
    I waste alot more money than ~ $100 a month of stupider things like junkfood and electrnoic's purchases than I do on gas that I need to go from point A to B.
  12. Apr 17, 2011 at 7:52 AM
    Dustyroades
    Dustyroades Well-Known Member
    Ontario
    '09 MGM AC 4x4 SR5 2.7L 5spd
    Front Bilstein 5100s at 1.75", rear 1.5" AAL w/ TSB and OME N182s, P265/75R16 Hankook A/Ts
    Are the autos really that bad in the 2.7? I can downshift to 4th or even 3rd in the situations mentioned by the OP and have power to spare. Are we driving the same engine??
  13. Apr 17, 2011 at 8:21 AM
    jking3002
    jking3002 Well-Known Member
    Jonathan
    Kentucky
    Scion tC
    Ricer muffler, window tent, trd shift knob.
    Depending on how hilly it is the 2.7 really is pretty weak. On level ground my 5-speed works great, and on most good sized hills (small mountains) a downshift to 4th is all that is needed to maintain highway speed. In most of those cases I could probably maintain my speed by slamming the pedal to the floor in 5th, but who wants to do that?
    There has been a time or two I have had to downshift to third to maintain 70MPH going up some mountains in WV. I could see how living in the rockies and having the auto would suck pretty bad...
    I agree with most of these people though, when you trade in a truck you still owe on you VERY rarely come out ahead. Especially after taxes, dealer fees, etc. BTW, you won't get anything close to 17k for a five-lugger on trade. Even if the thing is CHERRY... they are like 16k new... I'd say you're looking more around 12k-13.5k as a reasonable trade-in amount.
    Also, you really want to give up something with less than 20,000 miles (assuming) for something with almost 100,000? Sure, Taco's last, but how long do these second gens really last on average? Nobody knows... In any event, that 80,000 mile difference or more is about 5 years worth of driving...
    Why do you need a 4x4? Is the 2wd not doing something you need it to do? Maybe you could trade it for a prerunner v6 instead of a 4x4? Could save yourself thousands on that alone...
  14. Apr 17, 2011 at 8:21 AM
    travelingman
    travelingman What would Scooby do?
    Brian
    Ohio
    07lb4x4DC
    ticking eng.mo,ventvisors,locking tailgate,wheelmasters ss spare tire inflation line,weathertech mats
    Also since about all the 4.0s are autos and i beileve autos are reserved for the females.. anyone can drive one of them whats the fun in that??[/QUOTE]
    If you can walk and chew gum you can drive a manual.Nothing special about that.I drove a manual for 25 yrs. And I would much rather drive an auto. I can still pick what gear I want if need be.
  15. Apr 17, 2011 at 8:35 AM
    AndrewFalk
    AndrewFalk Science!
    The North East
    2010 5 speed 5 lug
    It's all about the 5 speed with the 2.7 I-4. I haven't been in a situation where I truly NEEDED more power. I've hauled 1700+ lbs. without issue.
  16. Apr 17, 2011 at 8:38 AM
    mcleod90
    sean
    modesto ca
    05 double cab
    Thanks for all the responses. Gas prices aren't really a big deal to me. I live 2 miles from work and right across the street from the gym. And right now I'm getting about 21 mpg so a few less isn't going to hurt me for the extra power.
    The problem could be that I have an auto. Or it could be that I am 250 lbs ;). Either way it bothers me enough to consider trading it in.
    I am going to go look around today and test drive a v6. If I don't like the numbers that come up then I'll just walk and still have a great truck with no balls.
  17. Apr 17, 2011 at 8:39 AM
    mcleod90
    sean
    modesto ca
    05 double cab
    And I was planning on riding my bike to work soon anyways.
  18. Apr 17, 2011 at 8:48 AM
    ColtsTRD
    ColtsTRD .....
    Scott
    AZ
    2005 TRD DCSB
    x2
    Especially with gas prices lately...I'd just stick with the 4 banger
  19. Apr 17, 2011 at 8:50 AM
    05RedTaco
    05RedTaco Nom Nom Nom
    Tony
    Scottsdale
    2000 Tacoma XtraCab 2.7L 4x4
    I have 4 banger and I run 31's with stock 3.33 gears. Ya I gotta shift a lot, BUT never felt like I want more power. Just different gears maybe 4.10 or 4.56...
    The 5speed makes all the difference. Auto combined with small engine and a truck just sucks...
  20. Apr 17, 2011 at 9:02 AM
    kirkofwimbo
    kirkofwimbo Say no to Bro
    Clayton
    Wimberley, TX
    ‘17 TRDOR DCSB
    OP, out of the 3 trucks you listed, I'd have to go with the last one. Looks like you'll save about 4 grand getting an access cab instead of a double. Plus with the way these trucks hold value, if you really needed to step up to a double cab down the line, it wouldnt be such a big deal
