Thinking about using mirror power for dual USB- dashcam and GoPro
Discussion in '3rd Gen. Tacomas (2016-2023)' started by dirtybad, Apr 17, 2023.
  1. Apr 17, 2023 at 4:41 PM
    dirtybad
    dirtybad [OP] Active Member
    Central TX
    20 OR DCLB 4WD, 08 OR DCSB
    Anyone out there tried powering 2 USB devices from the mirror using something like the Dongar adapter? I'd like to avoid pulling panels and running wiring but I'm not sure how much wattage/amperage that mirror is getting.
  2. Apr 17, 2023 at 4:59 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Determine what fuse the mirrors run off. Then are the mirrors powered when the key is ACC.
  3. Apr 17, 2023 at 6:20 PM
    caribe makaira
    Caribbean, Puerto Rico
    Use the sliding roof circuit.:burp: Always ON.
  4. Apr 17, 2023 at 9:19 PM
    dirtybad
    Central TX
    is that wiring in place even if I don't have a sliding roof?
  5. Apr 17, 2023 at 9:20 PM
    dirtybad
    Central TX
    I'm ok with the power being switched, the dashcam has a supercap and I don't need the GoPro to run full time. I use it for time lapse on road trips.
  6. Apr 17, 2023 at 9:22 PM
    caribe makaira
    Mmm...yes:burp:
  7. Apr 17, 2023 at 9:25 PM
    dirtybad
    Central TX
    sweet, thanks!
  8. Apr 17, 2023 at 9:59 PM
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    should likely be fine on both of those. I run a dash cam with no problem before. I would assume both run very minor draws. worse case you blow the fuse and remove both.
