Thinking of Buying??
Discussion in '1st Gen. Tacomas (1995-2004)' started by cactus52, May 22, 2007.
  1. May 22, 2007 at 6:40 PM
    cactus52
    cactus52 [OP] New Member
    Hi all:
    I am new to the tacoma market and I was looking at a 2003 dual cab with 85000 miles. It has the 4 cyl 2.7 and that has me worried a little because of lacking power. It is a 2wd and I don't plan on towing anything just going to work and taking the kids places. Is there any other things I need to look for?
    Thanks in advance
    Cactus52
  2. May 23, 2007 at 6:42 AM
    greenrig
    greenrig Member
    what are you normally driving? i personally love the look of the 4 door prerunner but if you are used to the power of some v8 or v10 then your up for a small transition. although they sould have some zip off the start but with any kindof load you are going to want the v6. just take it to a good toyota shop for some tests. most sellers wont mind unless they have 14 frantic buyers trying to throw cash at them which is usually what happens when someone sells a tacoma!!
    good luck!
  3. May 23, 2007 at 6:57 AM
    cactus52
    Thanks for the reply.
    I am driving a volvo 960 wagon now so power is not something I am use to. But I found a Great looking tacoma at the right price so I thought I would check to see if the 4 banger is problematic in comparison with the 6.
    thanks
    Cactus52
  4. May 23, 2007 at 7:13 AM
    greenrig
    greenrig Member
    well i think that there is 2 different 4 cyl . i would think to carry the prerunner suspension that it is equipt with the beefer one..please tech guys help out here this is also a question of mine. what year volvo? my girlfriend had a newer v70 or 90 and was very fast.
  5. May 23, 2007 at 11:24 AM
    cactus52
    My Volvo is a 97 960 wagon, it has 180,000 mile on it. I think that it rust faster than it goes. It needs a new tranny and some other work to bring it up to par. It has been a fantastic car, and I hope to send it to college with my daughter this fall.
    Cactus52
  6. Jun 1, 2007 at 4:18 PM
    jrallan26
    jrallan26 Well-Known Member
    Iowa
    2004 White D-Cab TRD
    A Double-cab with a 4cyl. motor? All Tacoma dbl. cabs come with a 3.4 V6 and automatic.
  7. Jun 2, 2007 at 4:48 AM
    maverick491
    maverick491 Towing Guru
    South Jersey
    07 4x4 Access Cab, TRD off road, 6 cyl, 6 spd
    Activator III brake controller, Extang Fulltilt toneau, Factory bed mat, Extra D-rings in the bed, 2ndary air filter removed, Garmin Ique GPS, Eco-2, AFE Pro Dry-s filter, USASPEC PA12-toy, Pioneer 3-way speakers, SG II on Blendmount, Gulf States Alarm added.
    All 4x4 double cabs had the V6 and auto trans, a 4x2 (pre-runner) came standard with the 2.7 L 4 cyl. (since you are new to this I figured I'd explain that when the other guys say pre-runner they are talking about the truck you are looking at.)
    For what it's worth, I had a 2004 Xtracab, with the 2.7 engine and the manual tranny. The only time I wanted for more power was after we bought our travel trailer, or in the absolute dead of the summer with the air on.
    Since you are not planning on towing, that should not be a factor. I am not saying that with the air on it was a total dog, just that I felt it had a noticible lack of power then.
    Hope this helps.
  8. Jun 2, 2007 at 10:50 AM
    twoarezee
    twoarezee Well-Known Member
    esco, ca
    00 Dropped Mini
    rims,tires,3"/6" drop, 4x4 front end, 01 tails and corners, prerunner buckets,tenzo r steering wheel w/ momo hub, b&m shifterw/ jdm trd knob, alpine system, tint, 3 3/4" autometer tach, jardine cat back, k&n, debaged, hellwig rear sway bar, kyb monomax shocks, tundra v8 oil filter w/ mobil 1 in ever
    the 3rz (2.7l) is a very stout engine. w/ 85,000 miles that thing is barely broken in, it still has a couple hundred thousand miles to go. as long as you do proper maintanence it will be bullet proof and should not be problematic at all. if you need more power you can supercharge it.
  9. Oct 21, 2007 at 10:08 AM
    willi156
    willi156 New Member
    i had a 2003 2.7L 4 cyl 4x4 and it was the best truck i ever owned, great gas mileage plenty of power not fast but got on the freeway and up hills just fine, i live in LA and people drive fast and crazy definetly a great little truck. i would be concerned about room in the cab if you have multiple kids it might be a little bit tight, but short drives no problem
