thinking of purchasing a rolled tacoma
Discussion in '2nd Gen. Tacomas (2005-2015)' started by xaceofspades999x, Mar 30, 2010.
  1. Mar 30, 2010 at 9:52 PM
    xaceofspades999x
    xaceofspades999x [OP] Arrogant Bastard
    San Antonio, TX
    2002 4runner Sport Edition
    so im thinking of purchasing a rolled 2006 tacoma i saw on CL... I sent the guy an email and will call tom to get the details of cost but it looks to have damage on almost all sides and am wondering if this is worth it if i can get it cheap enough. Plz tell me if u would buy it and how much u think i should negotiate for?
    This is what his ad says:
    parting out tacoma sr5 4x4 pre-runner truck rolled plenty of parts runs an drives, clean title,seats, motor v6 30k miles,, auto trans, wheels tires compelet front end,, call mike 214-729-4005
  2. Mar 30, 2010 at 9:56 PM
    SlurpeeBlueMetallic
    SlurpeeBlueMetallic FFFFFFUUUUUUUUUUUUUUU...
    Yikes... do not want. I might take parts from the interior but wouldn't want to take it as is for my daily driver. However, are you looking at it for off-road use? That might be worth checking into if it's really cheap, although the "4x4 Pre-runner" statement is mutually exclusive and needs to be clarified before any price can be set. If I see the pic clearly enough it appears to have Pre-runner badging on it.
  3. Mar 30, 2010 at 10:06 PM
    xaceofspades999x
    San Antonio, TX
    ya i plan to use it for offroad and maybe some DD if its fixable... I have a 2002 4runner 2w with a 3" lift that is my DD but figured if i could pick this up for cheap and fix it up for less then a used tacoma then itll be worth it to have a truck and a 4x4.
  4. Mar 30, 2010 at 10:11 PM
    nvdeserted
    nvdeserted Well-Known Member
    Reno, NV
    2009 Tacoma TRD OR Access Cab
    Electric Dynolock tailgate, TrailGear Slides, , 285/75-16 Yoko Geolanders on Wheelers Type B, SAW 2.0 front and back, Camburg b/j UCA, 1.5" AAL, Ubolt flip, ARB bump.
    It depends on what you want to do with it: if you want to restore it-it better be real cheap; if you are using it as a base for an offroader go for it!
    It looks like it did 1 rotation... check axles, LCA, UCA, etc and where those mount to the frame, leafspring mounts etc for damage, bending/breakage. There is a real good chance everything but the body is fine too. Spend a good hour going over it.
    If the price is right and you know what you're doing I'd say go for it. At 30kmi alot of those parts are essentially new.
    Also true on the "4x4 Prerunner", Prerunners are 2x so look into that.
  5. Mar 30, 2010 at 10:24 PM
    xaceofspades999x
    San Antonio, TX
    ya ill look into the pre-runner badge and ill look over the truck thoroughly but im thinking bout trying to restore it but add a 6" lift.
  6. Mar 30, 2010 at 10:30 PM
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Lusby, MD
    '07 TRD Sport 4x4
    Build thread in sig...
    my trd sport 4x4 had a prerunner badge on it (untill i took it off) don't knwo if that helps
  7. Mar 30, 2010 at 10:32 PM
    xaceofspades999x
    San Antonio, TX
    actually i think that does... haha thnx for the info.
  8. Mar 30, 2010 at 10:41 PM
    nvdeserted
    Reno, NV
    Part out everything you can and go straight axle on it. Go fiberglass fenders etc. You could have alot of fun with building that one depending on the base cost and only have to 'restore' the doors.
  9. Mar 30, 2010 at 10:46 PM
    xaceofspades999x
    San Antonio, TX
    SAS is a little out of my price range right now but would be a great to have once i get my degree and make some real money... Im thinking of fixing wat i can then replacing the rest and possibly paint it black. IM not a huge fan of white bc my mom and dad and sister all have white toyotas (2009 tacoma, 2006 sequoia, and 2000 camry)
  10. Mar 30, 2010 at 10:56 PM
    nvdeserted
    Reno, NV
    I hear ya. If only I had time, space, and loot... there would be a sweet SAS'd flat bed double cab in my sig.
    I'd have to disagree with the black paint, it doesn't hide that NVpinstriping as well, but you're not in NV so no worries.
  11. Mar 30, 2010 at 10:59 PM
    xaceofspades999x
    San Antonio, TX
    lol ya ive always wanted a black vehicle. My first and only vehicle is my 2002 4runner that is a goldish silver. Official name is thundercloud and im in constant envy of the dudes with black ones...
  12. Mar 30, 2010 at 11:09 PM
    csuviper
    csuviper Moderator Moderator
    Brian
    Broomfield, CO
    2012 Tundra Rock Warrior 5.7L 4x4
    3" Toytec Ultimate Lift, 315/70R17 Duratracs, RW Wheels, Grillcraft Grill, Toyota "Raptor" Lettering and more
    Buy it if it has a good engine block and frame and if it is a good price. Check for cracks in the block or bends in the frame. Worthless if it has either of these. Otherwise you can find the doors, hood, bed and other parts from a local junk yard, piece it together slowly and then get it all painted up. Figure $100-$200 per door and main body section. A full bed should be $500 if found in junk yard or used might be $1000. Your looking at probably $5,000 to get it back to good condition depending on the engine, stearing and driveline components. If purchased cheep enough you should have a good deal. Figure that the person parting it out had insurance and purchased the truck back from the insurance for around $5,000. Keep that in mind when you haggle.
  13. Mar 30, 2010 at 11:14 PM
    csuviper
    Brian
    Broomfield, CO
    Let us know what he is selling it for. Im interested to know.
  14. Mar 30, 2010 at 11:14 PM
    xaceofspades999x
    San Antonio, TX
    ok thnx for the insight... ill check all that hopefully tom. Ill give him a call tom after my classes and schedule a time to check it out if starting price is reasonable
  15. Mar 30, 2010 at 11:25 PM
    nvdeserted
    Reno, NV
    And he claims it "runs and drives", take it for spin and have a buddy follow you; see if the rear tracks with the front, if it looks like the rear is swayed off to one side it could be anything from a cheap broken shackle to a bent frame. See how many of the sensors are freaking out on the gauge cluster too.
    Keep it updated on here, lots of folks will have good input to help your decision, pictures are king.
  16. Mar 30, 2010 at 11:52 PM
    gusotto
    gusotto gusotto
    Gary
    Iowa
    2001 Tacoma 4X4 SR5 Extended Cab
    What kind of a title?
    Probably going to have a salvage title and that isn't a plus!
  17. Mar 30, 2010 at 11:55 PM
    xaceofspades999x
    San Antonio, TX
    says clean title in the ad description but even if its a salvaged title i think i could live with that. My sister's camry has a salvaged title and she has no probs with anything ...
  18. Mar 30, 2010 at 11:59 PM
    gusotto
    gusotto gusotto
    Gary
    Iowa
    I know it says "clean title" but if it does have anything like a salvage title attached to it, resale suffers!
    Future sales or trades to a dealer suffer.
    It'll show up on Carfax and that's never a plus.
  19. Mar 31, 2010 at 12:56 AM
    05sctaco
    05sctaco Well-Known Member
    Ken
    Santa Cruz
    Some states will give you a clear titles after you fix it up. In reality it's totaled. I thought about the same idea of getting a totaled tacoma and just swaping in and out my parts with a 4x4.
  20. Mar 31, 2010 at 5:32 AM
    WNYTACOMA
    WNYTACOMA Well-Known Member
    Clarence, New York
    09 Metalic Grey TRD OFF ROAD
    Toyota Nerf steps Bugflector 2 Tool box Weathertech floor liners Wet Okole F/R - Bk/Char
    Thats beyond the 'tipping point' if you ask me. I'm sure he would be thrilled if you took it off of his hands. It would be like Christmas all over again, for him.
    Bottom line, i would advise against it.
