Thinking of putting Cooper Rugged Trek or KO2s
Discussion in 'Wheels & Tires' started by Limited_23, Jan 14, 2023.
  1. Jan 14, 2023 at 3:44 PM
    Limited_23
    Limited_23 [OP] Active Member
    2023 Limited 4x4 long bed, wind chill pearl
    None
    Ok I am new to the forum, I have a 2023 Tacoma Limited 4x4 Long bed, in wind chill pearl.
    Thinking of putting a set of all-terrains on, possibly Cooper Rugged Trek or K02s. I am not going to lift it now. Any thoughts?
  2. Jan 14, 2023 at 3:48 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    See forums: “wheels and tires”
  3. Jan 14, 2023 at 3:52 PM
    mushroom_man7
    mushroom_man7 Well-Known Member
    has been discussed thousands of times, nothing has changed, nothing new to talk about
  4. Jan 14, 2023 at 3:58 PM
    Limited_23
    None
    Glad you read all the thousands of posts. And thanks for being helpful. Great advice couldn’t have made a decision with out it.
  5. Jan 14, 2023 at 4:04 PM
    J Williams
    J Williams Well-Known Member
    Jeff
    Central MN
    2021 TRD Pro
    Welcome to TW! I’m not familiar with the Coopers, but have read good things about them. The K02’s are a solid choice.
    Limited_23[OP] likes this.
  6. Jan 14, 2023 at 4:11 PM
    Mr.Gea
    Mr.Gea Well-Known Member
    Gea
    Lancaster, PA
    2020 TRD Sport Cement
    1 thing I will say is that, with all terrains tires and K02's your truck will be much noisier.
    I put a set of Toyo tires open country R/T on my Sport and it is much noisier than stock, city and highway.
    If you don't mind the noise then go for it. If it was me, I'd keep it as quiet as possible especially on the Limited trim.
  7. Jan 14, 2023 at 4:11 PM
    Limited_23
    None
    Thank you. Yea I agree seems like KO2s are the best choice. Not sure if it is going to look good with no-lift though.
  8. Jan 14, 2023 at 4:16 PM
    Limited_23
    None
    You maybe right just keep the regular Michelins on for now. They ride amazing. This Tacoma is my first mid-size truck. Always had a full size truck.
  9. Jan 14, 2023 at 4:23 PM
    ColoradoTJ
    ColoradoTJ Retired cat herder Moderator
    Colorado
    3500 Duramax, Roush Mustang, Jeep Crawler
    Welcome to the site. Sorry some people forget that once they were new on here and probably asked some repetitive questions.
    Definitely check out the wheels and tires subforum. Lots of good information and pictures to help out in your decision.
    https://www.tacomaworld.com/forums/wheels-tires.15/
  10. Jan 14, 2023 at 4:35 PM
    BC Hunter
    BC Hunter Well-Known Member
    Kootenays, British Columbia
    2022 Black AC OR MT w/all TRD goodies
    TRD: Lift, Exhaust, Air Intake, Skid Plate & "Beadlock" wheels. Batman sticker. 255/85R16 Toyo MTs. Debadged. H9s.
    The Limited comes with 18"x7.5" rims (with 30 mm offset), so your choices are somewhat reduced, but the BFG AT K02 comes in a LT255/70R18 which could be a real sweet spot. 32.1" OD, so just a smidgen bigger OD but narrower than the 265/65/18 that everyone knows will work. Load Range "D" so a bit softer than the "E" series.
    This link is helpful, but doesn't address the skinnier options unless you scroll endlessly... https://www.tacomaworld.com/threads/largest-tacoma-tire-sizes-on-stock-suspension.67550/
  11. Jan 14, 2023 at 4:39 PM
    Limited_23
    None
    Thanks definitely like the KO2s. Do you think the size you recommended will rub? Or good to go?
  12. Jan 16, 2023 at 5:09 AM
    atc250r
    atc250r Recovering Ram Owner
    Orange County, NY
    2022 Tacoma SR5 - DC/LB
    LED interior, license plate, and fog lights. More to come.
    I just put the Rugged Treks on my SR5 a few weeks ago. Definitely a bit noisier than the stockers but what little I got to use them in snow they were very good. Seem good in the wet too. Also, they offer several in 18" that are SL (standard LOAD) and XL (extra load) so you won't have to go with an E or D range LT tire. Plus they're probably a bit cheaper than the BFG.
    https://coopertire.com/en-us/find-tires/all-tires/discoverer-rugged-trek
  13. Jan 16, 2023 at 6:05 AM
    TailHook
    TailHook Oh, what shall we do with a drunken sailor?
    Alan
    Southern UT
    2018 TRDOR 4X4, 2007 Sequoia 4X4
    Welcome aboard...
    I run the Rugged Treks on my Sequoia...great tire that performs well.
  14. Jan 16, 2023 at 8:37 AM
    fourfourone
    fourfourone Well-Known Member
    2015 TRD sport(sold) 2023 Tacoma
    except the fact that the rugged treks are a new tire that has barely been discussed....
    TacoZmtn and Limited_23[OP] like this.
  15. Jan 16, 2023 at 8:47 AM
    maxus
    maxus Well-Known Member
    2017 TRD OR DCSB V6 MT
    Running KO2s right now, in 6 ply (C-load). Have 35,xxx miles on them, and they still have some tread, but not a ton. I'm looking at the Toyo Open Country a/t 3, the Open Country R/T Trail and the Rugged Trek. Leaning toward the A/T 3, but with the trips planned this year, a more aggressive tire might be a better option.
    Don't want to go 10 ply, because I'm old and grumpy, and don't want it to ride like a potato wagon. Still mulling that over.........
