thinking of this setup?
Discussion in 'Suspension' started by outlaw7, Jan 11, 2010.
  1. Jan 11, 2010 at 8:22 PM
    outlaw7
    outlaw7 [OP] Well-Known Member
    Brandon
    PacNorWest
    2010 trd sport
    i just got the tsb done today so im thinking i will start to collect my parts for my suspension upgrades. im thinking of getting the toytec 1.5 tsb aal for the rear, bilstein 5125 for the rears, 5100's up front set at .85 with some eibach lift springs and some 285 on 17's. i know i might have to do some shims or drop kits and trimming but any of you guys have any positive feedback or negative with this setup or would change it in any way? i want to keep a slight rake in the front so im not looking to make it completely level and my 87 toy takes the hit on most of my offroading urges but this one will see dirt now and again.
  2. Jan 11, 2010 at 8:25 PM
    jodiddly33
    jodiddly33 Well-Known Member
    Jonah
    DFW
    2010 Golf TDI
    I'm not sure you'll be able to fit 285s with just .85 up front but I'm not positive :confused:
  3. Jan 11, 2010 at 8:29 PM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    Lots of trimming for that tire on that lift. Get good backspaced wheels and overkill on the 5125, you don't need them
  4. Jan 11, 2010 at 8:38 PM
    outlaw7
    Brandon
    PacNorWest
    2010 trd sport
    cool so 5100's on all fours what if i set the fronts at 1.5 with the eibach springs?
  5. Jan 11, 2010 at 8:42 PM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    the springs will give you like 1.5" of lift, so those with the .85 on the shocks you should be hok with minor trimming.
  6. Jan 11, 2010 at 8:48 PM
    outlaw7
    Brandon
    PacNorWest
    2010 trd sport
    i was hoping to get 2.5 inches in the rear after everything has settled and about 2 in the front with the lift springs and coilovers. so will the fronts settle to around 2 inches or will they stay higher if i set them at .85? if they do settle will i still be able to fit 285s with trimming?
  7. Jan 11, 2010 at 8:54 PM
    08pretaco
    az
    What's your budget? Why not just get the toytec ultimate lift kit and call it a day?
  8. Jan 11, 2010 at 9:06 PM
    ajohnson
    ajohnson Glamour Shot
    Andy
    Charlotte, NC
    07 DCLB TRD Sport Prerunner 4x4
    Things and stuff and such
    That setup should work good for you, except I think you could get away with 5100's in the rear. You can get front and rear 5100's from downsouthmotorsports.com. My 5100's, Eibach springs, 1/4" taco lean shim, 1.5 toytec aal's, and carrier bearing drop are waiting to be installed.
  9. Jan 12, 2010 at 7:12 PM
    Ridingontrd
    Ridingontrd Well-Known Member
    Richard
    Laughlin,N.V
    trd sport 4x4 w/towpkg
    aFe prodry,Dynomax ultra flo ss,Scangauge2,Demello front bumper,BudBuilt skids,sliders(local)AllPro rear bumper,Wet O's cobalt blu,w/halfpiping,TRD logo in gold,R/L hood struts,5150's@10"aal 3 pack,T/C uca,Light racing c/o,1"diff.drop,de-badged,
    I had the same setup in the back.The 5100's max out (travel)at 2 inches over (lift) stock height.Go with the 5125's @10" of travel.Now my bump stops will hit before the shocks bottom does.
  10. Jan 12, 2010 at 8:41 PM
    08pretaco
    az
    ^ how do you get 2.5" in the rear without going custom or the ome 2.75" pack? if you do go over 2" i agree with the 5125's
  11. Jan 12, 2010 at 9:56 PM
    Ridingontrd
    Richard
    Laughlin,N.V
    tsb leaf spring pack nets you just under 1" after it settles.(at least mine did):D ToyTec aal @ 1.5" more.
  12. Jan 12, 2010 at 10:51 PM
    spiceman
    spiceman Well-Known Member
    Hawaii
    '07 4x4 DC OR, Desert Sand Mica
    Window Tint, Sockmonkey bed decals, Eibach 1.6" coils, 5100s front (set @ .85) / rear
