Thinking there is something wrong with my truck
Discussion in '1st Gen. Tacomas (1995-2004)' started by slickyd, Mar 18, 2011.
  1. Mar 18, 2011 at 3:12 PM
    slickyd
    slickyd [OP] Well-Known Member
    David
    Talladega, AL
    03 PreRunner SR5
    My truck has a kind of gas smell coming from the exhaust it puts out white smoke from the exhuast pipe even after the motor has warmed up. And there seems to be a lot of water coming out of it too. My engine is making a "rattling" or like something is loose sound. It was a lot quiter when I first got the truck. thanks for looking.
  2. Mar 18, 2011 at 3:13 PM
    Jester243
    Jester243 all I wanted was a god dang picture of a hotdog...
    Dan
    Spokane, WA
    2016 Trail Premium 4Runner w/ KDSS
    some of this, a little of that
    How is your coolant?
  3. Mar 18, 2011 at 3:20 PM
    joerussell610
    joerussell610 When all else fails read the directions
    Him
    Making myself at home in your house
    2005 DC Sport Edition 4x4
    K&N, fog light mod, remote rear halogen fogs mounted under rear bumper, TRD skid plate, Flux Capacitor, Mr. Fusion upgrade soon
    Check coolant? Check to see if any oil in it? Check to see if coolant and water mixed? HMMMMMM???? Check to see what your credit score is?
  4. Mar 18, 2011 at 3:21 PM
    slickyd
    David
    Talladega, AL
    03 PreRunner SR5
    its full no fuild loss
  5. Mar 18, 2011 at 3:21 PM
    Jester243
    Dan
    Spokane, WA
    yes
  6. Mar 18, 2011 at 3:21 PM
    Jester243
    Dan
    Spokane, WA
    does your oil seem to have any coolant mixed in it?
  7. Mar 18, 2011 at 3:23 PM
    Rucas
    Rucas 1st gen
    Lucas
    1st gen. 4x4
    Custom Aluminum Camper
    lol at the credit score comment...
  8. Mar 18, 2011 at 3:27 PM
    slickyd
    David
    Talladega, AL
    03 PreRunner SR5
    I'll check it put I just changed it a month ago and it didn't seem that way then. How do I need to check the oil. Can you tell by looking on the dip stick if it has water mixed in?
  9. Mar 18, 2011 at 3:37 PM
    Bloodhound
    Bloodhound Banned from the Pics Thread
    Greg
    East Moline, IL
    '10 TRD O/R DBL-CAB
    Floor-mats, Running Boards, Shorty Antenna, AFE Pro Dry Air Filter, AVS In-Channel VentVisors, Beer cans in the bed
    Normally if water has mixed with oil it will look similar to chocolate milk or "Yoo-Hoo".
  10. Mar 18, 2011 at 3:39 PM
    slickyd
    David
    Talladega, AL
    03 PreRunner SR5
    Ok just checked doesn't seem to be mixed the engine didn't sound that bad just then
  11. Mar 18, 2011 at 3:41 PM
    slickyd
    David
    Talladega, AL
    03 PreRunner SR5
    Looks like motor oil
  12. Mar 18, 2011 at 3:44 PM
    slickyd
    David
    Talladega, AL
    03 PreRunner SR5
    oh yeah I forgot I haven't been getting the gas mileage I use to get either
  13. Mar 18, 2011 at 6:33 PM
    MapleMoose
    MapleMoose Drunk Canadian
    Ian
    West Kootenays
    1996 Tacoma SR5
    3" Eibach Coils, 3" AP Springs, AP 6" Shackles Toytec Diff drop, BAMF Sliders, Deck plate mod,Volt meter, Highbeam mod, PIAA fogs, 18" Magnaflow, LED dash swap, Color matched Satoshi Grille, Custom Rear Plate Bumper
    Hey! Just figured it out i think. Its your head gasket. Same problems with the '90-95. Apparently the engines for those years ran too hot and caused the gaskets to go. The water would mix in with the oil and cause your exhaust to blow white smoke. Also check your oil, if its starting to turn milky then thats the problem. And head gaskets are a BIG job! You have to take apart the engine. How this helps.
  14. Mar 18, 2011 at 7:05 PM
    slickyd
    David
    Talladega, AL
    03 PreRunner SR5
    Ok just really paid attention to it. The smoke starts after the motor is warm and its not much or very thick but it is constant.
  15. Mar 18, 2011 at 7:43 PM
    MapleMoose
    Ian
    West Kootenays
    1996 Tacoma SR5
    Is your engine running fast? Because broken gasket seals will cause your engine to run fast and hot. And that will cause water to get into your engine. That would also cause the white smoke and water coming out of your exhaust. Run your engine for a while and then check your oil or even change it. If it is milky or anything resembling water, your head gasket is probly blown. If thats the case dont drive anymore you could blow your engine.
  16. Mar 18, 2011 at 8:09 PM
    slickyd
    David
    Talladega, AL
    03 PreRunner SR5
    Idon't think its the hg from everything I have been reading. I smelled the water that is dropping from the exhaust it just smells bad there is no sweet smell to it. I don't know why the exhaust smells so bad but that doesn't have a sweet smell either. And my oil looks good it has to be something else.
  17. May 3, 2012 at 12:26 AM
    SandyEggo
    SandyEggo Member
    So Cal
    2013 Prerunner SR5 access Cab
    did you find the issue?
  18. May 3, 2012 at 12:32 AM
    Taco me elmo
    Taco me elmo Here, Eat some paint. Drink some Bleach.
    Tophat bobcat
    North of South, East of West
    Slow polished TuRD
    Anti theft 5-Speed
    Sounds like a blown out cat converter.
  19. May 3, 2012 at 1:04 AM
    slickyd
    David
    Talladega, AL
    03 PreRunner SR5
    No and neither did the dealership. I dont know what the problem is.
  20. May 3, 2012 at 2:54 AM
    stewartx
    stewartx Well-Known Member
    Huntsville AL
    2012 Silver DC SB TRD Off-Road
    Winch, front hitch, step bars, bed extender, bed step, gull-wing toolbox, tailgate lock, security system, cb radio, etc.
    Okay, here's a real long shot. Make sure your gas cap is properly tightened. My wife's minivan had similar problems (gas smell, engine slightly rough, small puffs of white smoke, etc). I couldn't find anything until the check engine light eventually came on after about two weeks. The first item in the troubleshooting checklist related to that was the gas cap, which was indeed loose. She simply screwed the gas cap down until she felt resistance, never going beyond that until the cap clicked. I tightened the gas cap and the problems & check engine light went away after driving a couple of miles.
