thinking used tacoma..needing information
Discussion in '2nd Gen. Tacomas (2005-2015)' started by looking, Feb 20, 2019.
  1. Feb 20, 2019 at 10:56 AM
    looking
    looking [OP] Well-Known Member
    Doug
    Lancaster, Ohio
    2014 Sport DCLB 4x4 Barcelona Red
    Looking at used Tacoma's in central Ohio. I have a Dodge Dakota 2005 2 WD with 143,000 miles. I am starting to see rust issues and thinking it is time for a different truck. I have owned it since Feb 2008 when it had 6500 miles.
    Thinking 2010 and newer. Not sure if I would go 4 WD this time. Looking for information on years and or mileage levels to avoid. Or which ones would be a must look at. It would have to have some kind of tow package and likely a 6 cylinder. I like the looks of TRD trim.
    Thanks for any information!
    Doug
  2. Feb 20, 2019 at 11:14 AM
    Jaypown
    Jaypown Well-Known Member
    Justin
    NE Ohio
    2020 Tundra SR5 Crew Max TRD Sport 4x4
    2010 or newer gets you out of the majority of frame rust issues. But being a fellow Ohio driver, frame condition is huge. 4x4 is very convenient but not a true necessity. These trucks are very capable in just 2wd. Look for TRD Pro's or sport's. Someone correct me if i'm wrong but I believe 2012 is the refreshed look. Don't worry about high mileage. Just be cautious with something older with very low mileage. I.E. 2010 with 24k miles.
    Start searching around on the forums and you'll find a ton of information on these trucks.
  3. Feb 20, 2019 at 11:34 AM
    Rick's 2012
    Rick's 2012 Well-Known Member
    Rick
    Costa Rica
    2012 Double Cab 4x4 Grey with leather
    Stock
    I guess one question is. Did you ever once wished you had 4wd while you owned your Dakota?
    If you did, then get a 4wd.
    Better to have it and not need it. Then need it and not have it!
    I feel it's better to have a truck that's been driven. Than a truck that's spent a lot of time sitting. Sitting is hard on vehicles too. Sometimes it can be harder.
    I bought my 2012 Double Cab Short Box just over a year ago. It had (129,000kms) or 80,000 miles on it. That's nothing. These things can run forever.
    Just make sure you first decide on what you want to get, and start searching from there. You don't want to habe regrets after its yours because you settled for that great deal that you came across.
    Beware of frame rust issues. I think that applies to every vehicle where they dump a billion tons in salt on the road for 6 months a year. But earlier 2nd gens have that issue involving their frames. So inspect.. inspect..inspect!
    Confirm that the truck you are looking at is legit, and not misbadged for something that it's not..ie someone putting TRD stickers on a truck that's not. Check the VIN..
    Maintenance during its previous ownership is important with any vehicle really. See if you can confirm. what has and hasn't been done.
    I can go on and on. But when you decide exactly what you want. Search for any issues or concerns with the year and options.
    Good luck and Welcome to TW :thumbsup:
    Keep us posted.
  4. Feb 20, 2019 at 11:49 AM
    15TACOSPORT4X4
    15TACOSPORT4X4 Well-Known Member
    Stan
    2015 Black Tacoma TRD Sport 4x4
    3" lift on 33 inch Nitto's with 18" Fuel wheels. N-Fab step bars. Husky floor liners.
    I would stay in the 2010-2015 ( gen 2) range myself. They have the 4.0 V6 not the 3.5 v6 of the newer gen 3's. I have a 2015 TRD Sport 4x4 with the 4.0 and if you tried to give me a brand new 2019 for it I would turn it down. I guess it depends on what you plan on doing with the truck. I use mine for huntin and pull a bass boat 3 or 4 days a week. If its just a daily driver you might be ok with a gen 3.
  5. Feb 20, 2019 at 11:50 AM
    Tacosail
    Tacosail Well-Known Member
    Jerry
    Hermanville Heights, Ohio
    '13 white ACLB
    '17 wheels,int. Wipers , bed mat , relocate trailer plug , husky floor liners , Lund nerf bars, wet Okole seat covers- heat & lumbar.
    I believe 2012 had some emission pump issues, but other years from 2010 on up are good. I live near Wooster, Ohio. Make sure you check for rust on frame by both cat converters. Two wheel drives are a lot cheaper than 4wd. Tacoma aren't cheap, if the price seams to low compared to similar trucks, be highly suspicious. There are no free meals at the taco wagon. Watch out for flooded trucks brought back to life.
    The drivers door arm rest is known to crack under the padding, not a big deal, just a bargaining chip on the price. Check all the electrical systems, make sure all the buttons work on the steering wheel, make sure all the speeds work on the heater fan. If the truck is lifted, find out what kind of lift, how much . Spacer lifts are not held in high regard on this forum. Check for funky tire wear patterns, lifts can cause alignment problems.
    Most used tacos sit a little lower on the drivers side when you look from the back of the truck. This is normal from the battery, gas tank and driver all being on that side. Welcome, and good luck
  6. Feb 20, 2019 at 11:53 AM
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
    I’m suprized living in OH you aren’t adimate you want 4WD.
    I won’t buy a truck without it.
    You can check for frame rust but... what does it matter? You live in OH. Your frame is going to rust. Fact of life.
    The 2011-2015s should have a frame replacement program down the road like all other trucks.
    To me that is not a reason to not buy the truck.
  7. Feb 20, 2019 at 11:55 AM
    MattCowsmasher
    MattCowsmasher ( -_・)ᡕᠵ᠊ᡃ່࡚ࠢ࠘⸝່ࠡࠣ᠊߯᠆ࠣ࠘ᡁࠣ࠘᠊᠊ࠢ࠘
    Temple, Tx
    O3 Rubicon wrangler
    I have a 15 sport 4wd with 101xxx miles on it. No issues cept self induced ones hasn’t left me stranded. Stock I was avg 18-20mpg now with a bunch of stuff 14-15.
    Imho the 4.0 has enough power an it’s comfy enough for long trips. So far best truck I’ve ever had the pleasure to own.
  8. Feb 21, 2019 at 5:19 PM
    looking
    Doug
    Lancaster, Ohio
    Thanks for all the suggestions. This is a great forum with fast replies.
    Wow!
    I will keep you posted.
    MattCowsmasher likes this.
  9. Feb 21, 2019 at 5:29 PM
    Clearwater Bill
    Billy
    Largo Florida
    Be extra careful if the frame is undercoated with the black rubbery stuff and looks fairly clean.
    Could be lipstick on a pig.
    Personally I'd look for a '13-'15 SR5 Access Cab 4wd. But that's just me. You might like more OE gizmos.
  10. Mar 12, 2019 at 10:25 AM
    looking
    Doug
    Lancaster, Ohio
    Update...Still looking and finally able to drive some used Tacomas last week. I drove 3 - 2015 or 2017 with double doors, 6 cylinder, ride really nice. I have
    been searching for used 2010-2017 Tacomas online. I am now settled on getting 4x4. I was thinking I wanted Access cab but those vehicle numbers are severely less than the double doors. New is out as I am trying to keep initial outlay lower than new would be.
    Some questions. I am using autotrader.com; cars.com; and cargurus.com for searches. I notice quite a few times that the description will say TRD Sport or TRD
    Pro. Yet, the pictures don't display those words at the rear of the bed.
    1. How do I tell by looking at the truck if is a Sport or Pro when the bed does not show those words?
    2. In reading some threads, I see to run a vehicle inquiry report with the parts department. Is such a report only going to be available at Toyota dealers?
    It makes me think I would only want to buy used vehicles from Toyota dealers. Still looking.
    Thanks for any help as well as your prior comments!
    Doug
  11. Mar 12, 2019 at 10:32 AM
    squeaky
    squeaky Well-Known Member
    Wisconsin
    2014 MGM DCSB Sport 4x4
    It can be hard to tell with the mods that many of us do to our trucks. Generally, the Sport will have a hood scoop. The Pro will have the Pro grill and the TRD Pro black wheels. To my first point however, many folks add the Pro grill and wheels to their TRD Sports.
  12. Mar 12, 2019 at 1:57 PM
    taco_rhyno
    taco_rhyno Well-Known Member
    06 DC 4x4 Sport
    A sport will have a hood scoop. An off road will have an electric locking rear end (button in cab). From the factory an offroad will also have yellow and blue bilstein shocks
  13. Mar 18, 2019 at 7:37 AM
    looking
    Doug
    Lancaster, Ohio
    Doing price comparisons with Pro, Sport, and Off-road. Am I seeing things correctly that similar miles and model year that the
    Sport would be the most expensive of the three? Again this would be for used Tacomas 2012-12015?
    Any input would be greatly appreciated!
  14. Mar 27, 2019 at 11:57 AM
    looking
    Doug
    Lancaster, Ohio
    I see the information below on a 2010 Tacoma currently for sale (copy and paste from carfax) in Cincinnati, Ohio. Is this some kind of rust
    fix on this truck? Is this something to avoid when I see this on the carfax?
    Is this model year and or others something to avoid?
    Thanks!
    Doug
    08/28/2017 Toyota Motor Sales, USA, Inc. Manufacturer Service Campaign issued
    Campaign #H0F LIMITED SERVICE CAMPAIGN H0F -
    REMEDY NOTICE CERTAIN 2005 - 2010 MODEL YEAR
    TACOMA CERTAIN 2007 - 2008 MODEL YEAR TUNDRA
    CERTAIN 2005 - 2008 MODEL YEAR SEQUOIA FRAME
    CORROSION RESISTANT COMPOUND (CRC) APPLICATION
    Status: Remedy Available
    Campaign expiration date: 05/21/2019
    Locate an authorized Toyota dealer near you to schedule an appointment
  15. Mar 27, 2019 at 12:11 PM
    BINK05TRD
    BINK05TRD Well-Known Member
    Massachusetts
    TRD OR AC SILVERSKY 15
  16. Mar 27, 2019 at 6:18 PM
    looking
    Doug
    Lancaster, Ohio
    I have been doing searches on www.cars.com. There was a central Ohio 2009 with 28K miles. It caught my eye for a few moments. Then I looked at the carfax. Truck sat for nearly two years
    with less than 60 miles. Oil changes done at both intervals.
  17. Mar 27, 2019 at 6:24 PM
    Jaypown
    Justin
    NE Ohio
    Yeah that one would scare me after sitting so long. A lot of moisture collecting underneath and rotting out everything (unless garage kept)
  18. Mar 27, 2019 at 6:35 PM
    looking
    Doug
    Lancaster, Ohio
    Justin, stupid question about your avatar. I am just a beginner with no Tacoma in the garage yet, be easy on me.
    What does the "DCSB" stand for in your avatar?
  19. Mar 27, 2019 at 6:55 PM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    Low mile 2015
  20. Mar 27, 2019 at 6:58 PM
    BigJimmyP
    BigJimmyP Well-Known Member
    Jimmy
    St. Louis, MO
    2011 Pyrite Mica. 4 Doors. 4 Wheels. 4x4.
    17x9 MT Classic III, 285/70/17 Terra Grappler G2, oem int. wipers, fog light install, window tint, W.T. visors and floor MATS, OME lift front and back.
    DCSB - double cab short bed
    All good advice. Like every truck it has some quirks. I completely agree with everyone about model years, check the frame, find something with service records if you can. Obviously you're buying a truck with the miles and age that will need fluids changed and maybe shocks or tires. Get one with the tow package from the factory. Become a part of Tacomaworld and let us help you spend your money!
