THIRD Annual AZBDR
Discussion in 'Arizona' started by Sapnjack, Sep 14, 2020.
  1. Jan 25, 2021 at 11:51 AM
    #141
    MR E30
    MR E30 Well-Known Member
    Michael
    Wherever it's parked
    2021 Silver TRD OR DCLB w/ AluCab and All the Mods
    First mod I ever done did to this thing. Up behind the driver's taillight!
    xtremewlr[QUOTED] likes this.
  2. Jan 25, 2021 at 11:58 AM
    #142
    Sapnjack
    Sapnjack [OP] Well-Known Member
    Daniel
    Phoenix AZ
    2016 TRD-OffRoad
    Bilstein 6112/5160 Dakar EL096R Leaf Springs KO2 265/75/16 Tires OCF Rock Sliders Cali-Raised Hidden Lightbar Diamonback Cover HD KB VooDoo Premium Rack CVT Tent ARB Awning
    I haven’t gone around to that... know a places that does it? Or did you do it yourself?
    MR E30[QUOTED] likes this.
  3. Jan 25, 2021 at 12:12 PM
    #143
    MR E30
    Michael
    xtremewlr likes this.
  4. Jan 25, 2021 at 12:17 PM
    #144
    xtremewlr
    xtremewlr Well-Known Member
    Todd
    Tucson, AZ
    2003 4Runner V8 - 2012 b00sted XRunner
    I have mods
    Yup. Need just 2 or 3 feet of 3/8" rubber fuel line, that adapter and then reuse the current breather from the axle (the adapter replaces it) at the hose end wherever you put it.
    On my '99 Tacoma, I ran it to the fuel filler door and cut a hole in the plastic surrounding the filler cap. Not sure you can do that with 2nd/3rd gens tho. On the 4runner, I have it running up to an area behind the driver side tail light like @MR E30 has done on his Tacoma. Super easy to do.
  5. Jan 25, 2021 at 12:21 PM
    #145
    Sapnjack
    Daniel
    Phoenix AZ
    2016 TRD-OffRoad
  6. Jan 25, 2021 at 5:39 PM
    #146
    Ace115
    Ace115 Well-Known Member
    Andrew
    Tucson AZ
    '03 DBL CAB 4X4
    That looks like good luck to me. That’s exactly what would have happened to me if I’d have planned the trip.
  7. Jan 25, 2021 at 5:42 PM
    #147
    Ace115
    Andrew
    Tucson AZ
    '03 DBL CAB 4X4
    Im reluctant to say that there is a possibility the last time I installed this actuator, I may have completely missed the slot where the fork is supposed to ride. There was a spot last year that @chrslefty and I were messing around where I put it in 4x to crawl out of a crossed up section and it walked right out. I don’t think it would have done that if the front axle wasn’t engaging but who knows. I tested it today and my front end is definitely engaging so maybe I just F#%*ed up the last install.
  8. Jan 25, 2021 at 6:09 PM
    #148
    Atl-atl
    Atl-atl Well-Known Member
    Phoenix+Flagstaff
    2024 Ram Power Wagon
    Fox, Thuren, 40s, other stuff
    The moisture is good, this snow will be gone in time for the trip!
    xtremewlr and Phessor like this.
  9. Jan 25, 2021 at 6:24 PM
    #149
    chrslefty
    chrslefty Well-Known Member
    chris
    Mesa az
    01 trd
    Stockish
    I was in 4l going up that hill i don't think that you would have made it if the front wasnt working.
    Ace115 likes this.
  10. Jan 25, 2021 at 7:24 PM
    #150
    xtremewlr
    Todd
    Tucson, AZ
    I have mods
    Glad you got it fixed then! Maybe think about eliminating the ADD and put a solid shaft in there with manual hubs at some point? Just an idea. The ADD is the weak link in the system right now.
  11. Jan 25, 2021 at 7:31 PM
    #151
    Ace115
    Andrew
    Tucson AZ
    '03 DBL CAB 4X4
    My thoughts exactly. Which if that is the case, that means that at some point between then and now, the fork jumped the sleeve. Not sure how that can happen but I guess I’ll need to figure out how to eliminate it in the future. For now it’s working pretty good.
    Phessor and chrslefty[QUOTED] like this.
  12. Jan 25, 2021 at 7:33 PM
    #152
    Ace115
    Andrew
    Tucson AZ
    '03 DBL CAB 4X4
    I agree 100%. I’ve read a few different mods to do to keep the ADD out of the equation. The LT presents some issues to going with manual locking hubs but a few guys have figured out a work around. I’m open to suggestions as well.
  13. Jan 25, 2021 at 7:37 PM
    #153
    chrslefty
    chris
    Mesa az
    01 trd
    Stockish
    I thought the add tube was stronger. I know the axels are supposed to be.
  14. Jan 25, 2021 at 7:38 PM
    #154
    xtremewlr
    Todd
    Tucson, AZ
    I have mods
    Other way around from what I have been told.
  15. Jan 25, 2021 at 7:42 PM
    #155
    Ace115
    Andrew
    Tucson AZ
    '03 DBL CAB 4X4
    I’d heard(read) the same things. I believe it was @Blackdawg that was talking about the differences with the auto vs manual axle differences.
    The mod I like the best is to pull the actuator, slide the sleeve into the locked position, install a hose clamp or CV boot clamp to keep the sleeve in the locked position and then close it all up. There is a wiring mod that can be done to keep the dash light working as well. I may go this route if I have any more issues.
    chrslefty[QUOTED] and xtremewlr like this.
  16. Jan 25, 2021 at 7:51 PM
    #156
    Phessor
    Phessor Well-Known Member
    Just swap the outer tube and inner axle, you should be able to keep your LT axles.
    chrslefty likes this.
  17. Jan 25, 2021 at 8:18 PM
    #157
    Sixthelement
    Sixthelement Ran over a Yeti once, Texas, never again
    Flagstaff
    24 F150
    Fox 2.0
    And, I am on call the weekend of the trip. So, cant make it. Other than maybe meeting some of y'all if you stop by near Flag.
  18. Jan 30, 2021 at 12:11 PM
    #158
    Sapnjack
    Daniel
    Phoenix AZ
    2016 TRD-OffRoad
    Hey, anyone have any experience with sumosprings? They look pretty cool. I’m currently running an HD Dakar leaf pack but have a lot of rake with an empty bed. Considering taking out a leaf of the Dakar and adding sumosprings, thoughts?
    https://youtu.be/xfYFE0eWiQU
  19. Jan 30, 2021 at 12:37 PM
    #159
    Atl-atl
    Phoenix+Flagstaff
    Since youd be removing them to uninstall a leaf, just sell your Dakars and get Icon RXT leafs. Everyone seems to love them and they are meant to add/remove individual leafs unlike the Dakars which might have questionable results removing a leaf.
    https://www.headstrongoffroad.com/s...ft_Leaf_Pack_Replacement_-_PAIR_-_158505.html
  20. Jan 30, 2021 at 12:43 PM
    #160
    Sapnjack
    Daniel
    Phoenix AZ
    2016 TRD-OffRoad
    Oh the Dakar Heavy Dutys's are meant to be able to take one of the leafs out to make them medium duty.
