Third bad center support bearing. Replace whole drive shaft?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by gnomesteel, May 11, 2019.
  1. May 11, 2019 at 1:17 PM
    gnomesteel
    gnomesteel [OP] Active Member
    Texas
    05 PreRunner V6 SR5 6-Speed Manual
    2005 V6 Prerunner with 185k miles and manual transmission.
    Third time my center support bearing has gone bad. Toyota paid for the last two, but said no this go around. Driveshaft was rebalanced last time. I’m considering buying a whole new driveshaft with the CSB. Seems easier than trying to salvage the current one.
    How hard is replacing the driveshaft? I’d likely buy a driveshaft assembly from Rock Auto. I’m handy, but haven’t done a driveshaft replacement before.
    Anybody done this before? Suggestions?
  2. May 11, 2019 at 8:12 PM
    6 gearT444E
    Deep South
    Herculiner Hootus
    perhaps they used the wrong P/N on the replacement, do you have the truck lifted? That could be causing off angles at the rear driveshaft.
    To replace the whole thing is simple, 4 bolts at the differential flange, two bolts for the pillow block bearing and it will slide out of the transmission.
  3. May 11, 2019 at 8:16 PM
    NYCTaco52
    NYCTaco52 Half man, half goat
    Somehow known as Stewart, but named Ben
    Ft Lauderdale, FL
    2022 Subaru Ascent
    Yeah what he said, those go bad, but normally never that fast. Find out what caused it before you just replace it and end up with the same issue soon.
  4. May 11, 2019 at 8:17 PM
    tacofish
    tacofish Well-Known Member
    N NJ
    14 ext cab 4x4
    3/1 lowrange spacer lift 285/70/17 wildpeaks
    there was a recall on early 2nd gen drive shafts I think.
    Anyone??
  5. May 11, 2019 at 8:19 PM
    mynewtoy
    mynewtoy I like men
    greg
    Mississippi
    09 double cab 4x4
    Detriot locker rear ARB air locker front 4.56 gears OME 3" lift, SPC uca's , moto metal 951 wheels 315/75/r16 Treadwright guard dogs, homemade front plate bumper with smittybilt 9.5k winch, homemade skids, homemade Bed bars, Mobtown offroad high clearance rear bumper with tire carrier, Homemade rock sliders , U-bolt flip, Wheeler's super bumps, BORA 1" wheel spacers , Black headlight mod , black tail lights, Satoshi Grill , autoPage C3 RS-665 alarm with remote start, flowmaster 40 series exhaust, cruise control,bed/ground effect lights, wet okole seat covers, tinted,windows, weather tech floor mats, AVS vent shades, debadged, hidden cobra 19 cb, 7" offroad lights behind grill, rear diff breather relocate, abs kill switch
    edit I see you have a prerunner It won't fit mine
  6. May 11, 2019 at 8:34 PM
    gnomesteel
    Texas
    Truck isn’t lifted.
    I’ll have to check the P/N. It is odd that it’s happened again. My assumption is that rebuilding the driveshaft was a bad call last time.
  7. May 12, 2019 at 3:11 AM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    Stock rear springs are too soft and cause the rear to wrap and change the driveshaft angle probably causing the junky Toyota 2 piece shaft center bearing to go bad. You can buy a new 1 piece shaft for under $500 and be done with that Toyota junk shaft. Many posts on this. Do a search and you will see many online manufacturers for a 1 piece and a simple measurement under the truck and they will make and send you one. I talked to Tom Woods and got mine years ago and Dakar springs and never a problem again - no vibration, no rear sag towing, no worries.
    HokieHT07 likes this.
  8. May 12, 2019 at 3:18 AM
    AlbertaSparky
    AlbertaSparky Self Made Hundredaire
    Cam
    Sundre, AB, Canada
    '08 BSP DCSB Sport
    Just changed my support bearing trying to chase a noise and minor vibration I'm having as well. It was no where near as bad as this bearing looks. The rubber was still intact, just a little soft. Put and SKF bearing in so we'll see how it does bit seeing this gives me little faith. Wish I'd read about the single piece shaft first as well. Probably the way I'll go if I end up with problems.
  9. May 12, 2019 at 6:38 AM
    gnomesteel
    Texas
    Huh, I had read about using a single piece shaft but assumed I’d need a lifted truck. Figured that the one piece would reduce ground clearance. I’ll look into it.
  10. May 12, 2019 at 6:41 AM
    gnomesteel
    Texas
    There was a TSB and Toyota already has replaced the CSB about two years ago. The new one is now bad.
    tacofish[QUOTED] likes this.
  11. May 12, 2019 at 7:26 AM
    buyobuyo
    buyobuyo Read The Fucking Manual
    Jeremy
    Camden, AR
    08 PreRunner SR5, I4, Manual, Silver
    A thing or two...
    Did you find the P/N for the bearing that they installed? The prerunner CSB is softer to allow the driveshaft to move since the slip joint is at the transmission. The 4x4 CSB is stiffer because the slip joint is after the CSB.
    Prerunner CSB: 372300K040
    4x4 CSB: 372300K030
    Tom Wood won't do a prerunner 1-piece driveshaft. He'd have to find someone else to build one.
    BassAckwards likes this.
  12. May 12, 2019 at 7:30 AM
    gnomesteel
    Texas
    Doing some more research this morning. Will go out and measure my truck later, but I'm pretty sure this is the one I'll get. Dorman 936728 Need to find a repair manual, but I'm fairly certain installing the new driveshaft assembly is something I can do myself.
    Swapping to a one piece sounds like overkill to me. I don't have a lift, and haven't had issues with vibrations. Just shitty center support bearings.
  13. May 12, 2019 at 11:13 AM
    buyobuyo
    Jeremy
    Camden, AR
    A thing or two...
    That Dorman driveshaft won't work. That's for a 4x4 truck. You need a slip yoke on the transmission end.
  14. May 12, 2019 at 1:32 PM
    gnomesteel
    Texas
    Son of a...
    Just noticed that after crawling under the truck to measure things. Having a hard time finding one for a PreRunner / V6 / Manual Trans / Ext Cab. Let the hunt begin.
  15. May 12, 2019 at 1:36 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    just rebuild with a new CB. take the driveshaft to a driveshaft shop to have balanced and a new CSB put in and call it good. Better yet, get your stock 2 piece setup with a slip joint after the CSB, and switch to a ford ranger CSB.
    buyobuyo likes this.
  16. May 12, 2019 at 1:49 PM
    gnomesteel
    Texas
    Guess I'll be calling around to driveshaft shops tomorrow. Anyone know a good one in Fort Worth, TX?
  17. May 12, 2019 at 2:38 PM
    buyobuyo
    Jeremy
    Camden, AR
    A thing or two...
    This looks like the correct one from Cardone. https://www.rockauto.com/en/moreinfo.php?pk=10615584&cc=1431544&jsn=407 It looks like it's out of stock everywhere, though.
    No reason for him to go all that trouble being on the stock suspension.
  18. May 12, 2019 at 3:27 PM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    Super easy to replace.
  19. May 12, 2019 at 3:28 PM
    lynlan1819
    Tacoma
    Lifted
    This ^ and they will warranty the work.
