Third Brake Light Issues
Discussion in '3rd Gen. Tacomas (2016-2023)' started by overlandozzy1, Dec 9, 2022.
  1. Dec 9, 2022 at 11:44 AM
    overlandozzy1
    overlandozzy1 [OP] Well-Known Member
    Jonathan
    2016 WHITE DCLB
    16 DCLB, ADS, 5.29s, 35s, RCI Skids, Baja Designs
    I have a 2016 with a Leer Camper Shell. I have my third brake light for the shell tapped into my drivers side brake light. The 3rd brake light works on the shell fine, but when I turn on my headlights, my drivers side brake light does not work when the brakes are depressed. Any and all help would be appreciated. Such a small issue but it drives me crazy.
  2. Dec 9, 2022 at 11:47 AM
    Tacospike
    Two Trucks
    Is this a problem that just started and was working fine before?
    Chew likes this.
  3. Dec 9, 2022 at 11:48 AM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    :popcorn:
    blu92in99 likes this.
  4. Dec 9, 2022 at 11:51 AM
    overlandozzy1
    Jonathan
    2016 WHITE DCLB
    No, my brake lights have always worked fine until I recently wired up my shell, and somebody told me it wasnt working.
  5. Dec 9, 2022 at 11:52 AM
    overlandozzy1
    Jonathan
    2016 WHITE DCLB
    If I disconnect the third brake light from my camper shell, the brake lights work just fine with and without the headlights turned on
  6. Dec 9, 2022 at 11:54 AM
    HondaGM
    James
    South-Pole, Alabama
    2023 access cab V6
    you positive your wired to the brake light and not the taillight?
  7. Dec 9, 2022 at 11:54 AM
    overlandozzy1
    Jonathan
    2016 WHITE DCLB
    Yeah I wired to the lower harness which is the brake light on the third gens
  8. Dec 9, 2022 at 11:58 AM
    HondaGM
    James
    South-Pole, Alabama
    2023 access cab V6
    how is the light on the shell grounded?
  9. Dec 9, 2022 at 12:00 PM
    overlandozzy1
    Jonathan
    2016 WHITE DCLB
    inside the bed on one of the screws, I took a grinder under where the head of the screw and grounded it there. Which makes me wonder even more because all the brake lights work properly when the brake is depressed when my headlights are turned off. When I turn my headlights on is when the drivers side brake light doesn't work when the brake pedal is depressed
  10. Dec 9, 2022 at 12:03 PM
    HondaGM
    James
    South-Pole, Alabama
    2023 access cab V6
    so you have the positive wire (one wire)run to the left rear tail light?
  11. Dec 9, 2022 at 12:05 PM
    overlandozzy1
    Jonathan
    2016 WHITE DCLB
    Its ran to the tail/brake light. THe top bulb is for blinkers and tailights, the middle bulb is the tail/brake light and the bottom bulb is for reverse. I tapped the blue wire on the bulb with the positive from my third brake light inside the shell
    HondaGM[QUOTED] likes this.
  12. Dec 9, 2022 at 12:08 PM
    Fatback17
    Fatback17 Masshole
    Billy
    South of Boston, Massachusetts
    2020 TRD Pro MGM
  13. Dec 9, 2022 at 12:10 PM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
  14. Dec 9, 2022 at 12:10 PM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    Post pics of the wiring job.
    shakerhood and HondaGM like this.
  15. Dec 9, 2022 at 12:12 PM
    HondaGM
    James
    South-Pole, Alabama
    2023 access cab V6
    :popcorn:
  16. Dec 9, 2022 at 12:16 PM
    Tacospike
    Two Trucks
    HondaGM likes this.
  17. Dec 9, 2022 at 12:47 PM
    overlandozzy1
    Jonathan
    2016 WHITE DCLB
    Now that I've made 3 trips to the store and discovered it may be a bulb issue. I've replaced the bulb 3 times and same issue. Brake light bulbs have 2 fillaments and only one is illuminating when I press on the brakes. I have completely disconnected the third brake light from the camper shell. My brake light does not work with my headlights lights turned on
  18. Dec 9, 2022 at 1:00 PM
    BLtheP
    Plano, TX
    Brake bulbs have two filaments and one should come on (dim) when headlights are on and the other should come on brighter when brakes are on.
    Camper 3rd brake needs to be wired to whichever wire corresponds to the bulb filament that is brighter and for braking. I don’t know if blue is that one.
    you probably need a better ground than a bed screw. At the very least test that screw for continuity with a known ground point so you have confirmed good ground. The best idea would be run your ground back to one of the tail light bulb grounds.
    As already requested, pics of your work would help. The problem as it’s being explained really does not make a lot of sense and the info provided makes me kind of question where to begin helping.
  19. Dec 9, 2022 at 1:40 PM
    HondaGM
    James
    South-Pole, Alabama
    2023 access cab V6
    only one filament should work with brakes....the other filament is taillights...
    check for 12volts with brake pedal depressed...is there 3 wires on that plug,one is ground,.....one is taillights and the other is brake?
  20. Dec 9, 2022 at 5:01 PM
    overlandozzy1
    Jonathan
    2016 WHITE DCLB
    Only one filament is lighting up even when the brakes are depressed. The light is significantly dimmer when brakes are pressed on drivers side than on passenger side. Not sure if its a bulb issue or issue with voltage
