Third brake light leak warning.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Blazingbluesport, Jul 21, 2017.
  1. Jun 1, 2018 at 5:29 AM
    #61
    psmura
    psmura Well-Known Member
    Paul
    Syracuse, NY
    2018 TRD OR MT
    Anyone have this happen on an 18? It seems like the posters in this thread have 16/17's.
  2. Jun 1, 2018 at 7:34 AM
    #62
    twitchhero
    twitchhero ___YOU BOYS LIKE___ MEX-I-CO???
    North Carolina
    2017 Tacoma TRD Off-Road
    See Profile for a full list of Modifications: *Suspension* -Total Chaos Upper Control Arms -Total Chaos Lower Control Arms -Rock Rash performace welded spindle gussets -King EXT Coilovers with adjusters (front) -King Tundra EXT Shock with adjusters (rear) -Icon RXT leaf pack (Option 2) -Timbren active off-road bump stops (front) -Timbren active off-road bump stops with U bolt flip kit (rear) -DRT cab mount relocation -DRT Shackle hangers with DRT cross member -Dobsins front leaf greasable bolts -Polyurethane front body mounts *Performance* -AFE intake (noisemaker) -JLT oil catch can -OTT Tune -Stoptech stainless steel brake lines -Power Brake D-Line kit -Extended stainless steel rear brake lines -AGM Odyssey battery -Tacoma TRD Pro Exhaust *Interior* -Window Tint -Tacoma Door Sill Protectors -Clazzio (black leather seat covers) -Dashtop Single Mount -Sound deadening material -GATOR floor mats -Cup holder hero mats -Garmin mini front dash cam -JOYING Headunit -Tacoma Kicker tweeter upgrade -Kicker KS front and rear speakers -Rear USB -Meso Customs interior lights *Exterior* -Tacoma tailgate inserts -Mobtown offroad "No drill" Bolt-on rock sliders. -All-Pro Hi-Lift bed rail mount /w Hi-Lift -Rear Diff breather relocated -Alpha REX TRD Pro style headlights -Baja Design squadron sport (Amber fog lights) -Total Chaos Fabrication bed stiffeners -Window Deflectors (AVS) -TRD Pro Grille -Summit DAKAR (BRONZE) -Toyo Open Country R/T Trail (35x12.50 R17) -Sequential turn signals -Softtopper (black) -Toyota Bed Mat -Vinyl wrapped tail gate (black) -C4 high clearance fender liners -C4 High clearance Rock Runner rear bumper w/ Baja Designs S1
    Just took my 2017 into Stadium Toyota in Tampa. I ran my truck through the car wash and had water drizzling in the back of the truck. They said it was a known issue and covered under warranty, it took around 2 weeks to get the back light in and called before saying "The part is somewhere in galactic space on back order" and offered me a rental Tacoma. Pretty happy with the service over there. :)
    shakerhood likes this.
  3. Jun 1, 2018 at 8:36 AM
    #63
    K-Rocca
    K-Rocca Member
    2016 Black TRD Off Road
    Bed Mat, Weather Tech mats, Nerf Bars, AVS, Un-holey dash mount.
    Noticed mine leaking the other day after a torrential downpour here in VA. Keeping it undercover till I can get it back to the dealer. If its such a common problem WTH didn't they issue a recall?
    bdunna likes this.
  4. Jun 1, 2018 at 10:04 AM
    #64
    bdunna
    bdunna Well-Known Member
    2005 tundra access cab
    Mine was just "fixed" by the dealer. Will run through the car wash today to test out. They re-installed the gasket and tightened it to specs. Their water "specialist" stated it was not tight enough from the factory.
  5. Jun 1, 2018 at 10:16 AM
    #65
    brydav
    brydav Well-Known Member
    Bryan
    Austin, TX
    2015 Access Cab TRD SPORT 4x4
    Just got this one - it's a work in progress.....
    I had this happen, too. In addition to the brake light, I insisted they replace the headliner, too -- which they did without a fuss -- but I had to insist on it.
  6. Jun 5, 2018 at 12:39 PM
    #66
    DUCKSURF
    DUCKSURF Well-Known Member
    JOE
    Wayne PA
    2017 TACOMA DC SUPER WHITE
    Maybe there is no official TSB out yet and the service manager just used the wrong terms? But he definitely acknowledged it was a known problem and immediately said it was covered under warranty. I would take it to the dealership you purchased the truck from and talk directly to the head service manager.
  7. Jul 15, 2018 at 7:02 PM
    #67
    tacoma98042
    tacoma98042 Well-Known Member
    Does anyone know if there's an official TSB for this now??
  8. Jul 15, 2018 at 8:09 PM
    #68
    StoicBeau
    StoicBeau Well-Known Member
    Interesting. I literally had this EXACT same issue with my 2016 Ram 1500. Oddly enough that’s a known issue with those as well.
  9. Aug 1, 2018 at 2:37 PM
    #69
    shamrockgar
    shamrockgar New Member
    T-SB-0055-18 Parts are on Back order and no idea when the part is coming in. My Tacoma is 2016 with 41K miles on it. Local Dealer will not cover it and $412.00 to replace the light. My headliner is badly stained. Dealer will try to clean it, but no guarantees. Went back to Dealer I bought and he said that it wouldn't be covered under the original warranty because it is a wear item(gasket). Opened up a claim with Toyota Customer Care. Should have received a call back today but nothing yet. Also had purchased a extended warranty though the dealer but found out it he set it up with a third party and they will not cover anything.
  10. Aug 1, 2018 at 2:43 PM
    #70
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Wow that sucks, 3rd party extended warranties are a joke, hopefully the claim you opened up will cover it.
  11. Oct 17, 2018 at 1:33 PM
    #71
    Sallylou
    Sallylou New Member
    2017 Toyota Tacoma double cab
    My 2017 Tacoma double cab is leaking at the 3rd brake light. Almost $700 and I’m 1,000 out of my warranty. What can I do to get Toyota to recall this error so I can get my money back??
  12. Oct 17, 2018 at 1:40 PM
    #72
    Captqc
    Captqc Well-Known Member
    Tigard, OR
    2017 Tacoma 4x4 TRD AC Off Road
    File a complaint with corporate. Insist that this is a know factory design/installation flaw.
    TRDPro916, shakerhood and Kingair84 like this.
  13. Oct 30, 2018 at 7:43 PM
    #73
    4x4yotaphan
    4x4yotaphan Well-Known Member
    SoCal
    SOLD: 2016 White TRD Sport DCSB 4x4
    Exterior: King suspension w/compression adjusters Icon billet UCAs Icon 3 leaf expansion pack Timbren rear bump stops w/U bolt flip kit Wheeler’s Offroad front superbumps BFG KO2 285/70/R17 on SCS Ray 10 17” wheels w/black wheel lock lug nuts TRD Pro grill TRD Pro taillights TRD Pro skid plate Demello Offroad front bumper Smittybilt XRC 9.5 comp winch w/Factor 55 fairlead and Flatlink E RCI LCA skids Beast Fab rock sliders 4 Extreme LED 4” pods Baja Design Squadron SAE LED amber fog lights Relentless Fab bedrail mount w/KC Flex dual amber chase lights AVS vent visors Interior: TRD Pro shift knob OEM instrument switch panel conversion (from 3 to 5 slots) Taco Garage DMM with Scosche Magicmount Upgraded Kicker sound system Husky X-act floor liners Performance: Airaid cold air intake system Pedal Commander w/Bluetooth
    Question for those that had the leaks. Was it prominent in the center?? Crazy thing is I have a leak but it’s at the headliner on the sides and dry in the middle which makes me think it’s the roof rack. I unbolted the roof rack bolts (didn’t remove the roof rack) and poured silicone in the hole then bolted it backed up and still a leak when I go through the car wash.
  14. Oct 31, 2018 at 7:36 AM
    #74
    savin yours
    savin yours Well-Known Member
    Bryan
    SE Tx
    2018 TRD Off Road
    What does TSB stand for?
  15. Oct 31, 2018 at 7:41 AM
    #75
    Invid
    Invid Well-Known Member
    New Braunfels, Texas
    2016 Tacoma Limited
    Technical Service Bulletin
  16. Oct 31, 2018 at 7:41 AM
    #76
    4x4yotaphan
    SoCal
  17. Oct 31, 2018 at 11:32 AM
    #77
    savin yours
    Bryan
    SE Tx
    2018 TRD Off Road
  18. Nov 10, 2018 at 7:54 PM
    #78
    Lightsped
    Lightsped Well-Known Member
    David
    Acworth/Kennesaw, Georgia
    Basic 2wd RC 5 speed
    I have a 2017 TRD OR with 7900 miles. I haven't noticed any leaking, but I have noticed a lot of condensation on the inside of the windows. I would like to take it to my dealer, but with no leak I am sure they won't fix the 3rd brake light....
  19. Nov 10, 2018 at 7:58 PM
    #79
    xguntherc
    xguntherc Taco Time
    Cory
    East Dallas
    11 TRD Off Road - Black
    Icon Stage 5, Nexen Roadian MTX, Fuel KB43 Block wheels, Baja Design XL 80s, Baja Squad Pro WC fogs, TacoVinyl grill, "dudebro" lights, Prinsu rack, trail rash pinstripes, BAMF hybrid bumper, sliders, and LCA skids, and a few other things I can't think of.
    wait wait wait wait... I have a 2011 DCSB.
    A few weeks back... at the car wash I noticed water inside my cab on the rear middle seats and the sliding window. I thought maybe the sliding window wasn't shut all the way or somehow water got in. But now I'm wondering if it was the 3rd brake light.
  20. Nov 10, 2018 at 10:58 PM
    #80
    Flash1034
    Flash1034 Well-Known Member
    N/W Montana
    2023 Toyota Tacoma TRD Pro, Solar Octane, Automatic
    MESO Stage 1.5 LED Taillights Falken Wildpeak AT3W Tires in 265/75-16
    I’ll keep an eye on mine. So far the truck has been flawless.
