Third brake light leak warning.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Blazingbluesport, Jul 21, 2017.
  1. Oct 25, 2019 at 10:41 AM
    #101
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    Get the @MESO 3rd brake. Drill the old one out from the exterior. No headliner removal needed.
  2. Oct 25, 2019 at 8:02 PM
    #102
    Kingair84
    Kingair84 Well-Known Member
    Wisconsin
    2016 Double Cab TRD Off Road 6 speed MT
    Rad Industries skid plate, trd pro grill, rigid DOT Fogs
    I’d maybe find a different dealership. I think the job can be done for $500 tops and that even seems high, if I’m not mistaken that’s what I was quoted originally when mine needed fixing. I would also assume that the price that corporate is willing to reimburse you for is probably close to the price it should cost to fix. I doubt they would just come up with an arbitrary number.
  3. Oct 25, 2019 at 8:16 PM
    #103
    4x4yotaphan
    4x4yotaphan Well-Known Member
    SoCal
    SOLD: 2016 White TRD Sport DCSB 4x4
    Exterior: King suspension w/compression adjusters Icon billet UCAs Icon 3 leaf expansion pack Timbren rear bump stops w/U bolt flip kit Wheeler’s Offroad front superbumps BFG KO2 285/70/R17 on SCS Ray 10 17” wheels w/black wheel lock lug nuts TRD Pro grill TRD Pro taillights TRD Pro skid plate Demello Offroad front bumper Smittybilt XRC 9.5 comp winch w/Factor 55 fairlead and Flatlink E RCI LCA skids Beast Fab rock sliders 4 Extreme LED 4” pods Baja Design Squadron SAE LED amber fog lights Relentless Fab bedrail mount w/KC Flex dual amber chase lights AVS vent visors Interior: TRD Pro shift knob OEM instrument switch panel conversion (from 3 to 5 slots) Taco Garage DMM with Scosche Magicmount Upgraded Kicker sound system Husky X-act floor liners Performance: Airaid cold air intake system Pedal Commander w/Bluetooth
    I was able to swap it out myself with only dropping the back half of the headliner and not the entire headliner. It did make a pain to get both nuts off but it helps to use a strong magnetic tool to hold everything in place to get everything back on. Did it this way since I was dropping the nuts and almost lost it to the back of my seats. Very simple but tedious. Just take your time. Not worth paying the dealer $400-$500 imo. Good luck!
    Grossomotto likes this.
  4. Oct 29, 2019 at 12:20 PM
    #104
    Glenn247
    Glenn247 Well-Known Member
    Lynchburg VA
    2016 DCSB Manual TRD Sport 4x4
    Update: I spoke with my local dealer parts dept. and was told the third brake light gasket/seal can't be purchased separately and I would have to buy the whole third brake light assembly for about 150 bucks, which supposedly includes the seal (although he wasn't certain of that)
    I checked online for aftermarket seals and could only find seals that fit other models (Access Cabs, older model double cabs, etc.) I could not find anyone selling an aftermarket seal to fit a 2016-2019 Double Cab.....
    Does anyone know if the seal can be purchased separately from Toyota or if there is an aftermarket option out there that my google skills can't locate?? Thanks!
  5. Oct 29, 2019 at 12:39 PM
    #105
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Gawd. There's never an easy way out.
    You could get some double sided waterproof gasket material and cut your own. Make a pattern with paper, transfer it, and murder it with scissors and an exacto? Something like 3M VHB:
    https://www.amazon.com/VHB-Adhesive-Automotive-Mounting-Industrial/dp/B00LXLHU9O
    I don't know if that size is long enough? But you get the idea.
    There's no way that I'd shell out $150 of even their money to just get the gasket.
  6. Oct 29, 2019 at 1:20 PM
    #106
    Glenn247
    Lynchburg VA
    Well said, Sir. This is a nightmare. Granted, my leak doesn't seem to be too severe but I want to fix it asap. I may be leaving the truck stored outside without using it for long periods of time so I won't be able to air it out to dry it out. Plus the humidity in Florida which is where I'm likely going soon will make it worse...
    Anyone have any idea if the gasket is available by itself through Toyota or aftermarket????
    tonered[QUOTED] likes this.
  7. Oct 29, 2019 at 1:44 PM
    #107
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    You might want to check with @MESO since he has 3rd brake light mod kits. Although, he is supposedly busy prepping for the SEMA show. But, folks in one of his brake light threads might be able to get you some details?
  8. Oct 29, 2019 at 1:47 PM
    #108
    Glenn247
    Lynchburg VA
    Thanks for that advice; I'll fire off a couple messages; worth a shot
  9. Oct 29, 2019 at 1:50 PM
    #109
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    :hattip:
    You're welcome!
  10. Nov 8, 2019 at 12:23 PM
    #110
    Kingair84
    Wisconsin
    So guess what....mines leaking like a sieve again!! Been replaced once already I wondered why my truck was smelling musty this summer. Total BS.
  11. Nov 8, 2019 at 12:58 PM
    #111
    Glenn247
    Lynchburg VA
    So you had it repaired by Toyota and it is still leaking?
    My leak has never been repaired it but it seems relatively minor and I plan to use some sealant around the outside of the brake light to try to stop water from seeping in...
  12. Nov 8, 2019 at 1:59 PM
    #112
    Kingair84
    Wisconsin
    Yup they replaced the whole thing about a year ago. Now I have to go get it looked at again. WTH I’m going to put black silicone around it after they fix it the next time. Such a pain in the butt sitting at the dealer for hours.
  13. Nov 13, 2019 at 12:28 PM
    #113
    Kingair84
    Wisconsin
    So brought it in and they say it’s not covered under the extended warranty, even though they replaced it once already and it has a TSB. So apparently the additional cost of a Tacoma is $700 every 2 years to keep your roof from leaking lol! Hopefully I can get somewhere with the service manager when he gets back. If not, I’ll fix it myself and stop buying Toyota’s. I love this truck but I’ve never had a vehicle at the dealership as much as this thing. It’s stupid and a waste of time and energy.
  14. Nov 19, 2019 at 8:57 AM
    #114
    Haleylujah13
    Haleylujah13 Well-Known Member
    Haley
    Washington
    17 TRD Off-Road DCSB :: @fsht4co_pnw
    V1 GFC #769
    Well crap, just noticed the musty smell this morning and looked behind rear seats and noticed water....along with damp seats. I am bringing it into the dealer tomorrow for hopefully some quick response, 2017 with ~ 12k miles
  15. Nov 19, 2019 at 8:59 AM
    #115
    Kingair84
    Wisconsin
    yours most definitely should be covered under the TSB. Don’t take any crap and get your headliner replaced If it’s ruined.
    Haleylujah13[QUOTED] likes this.
  16. Nov 19, 2019 at 3:28 PM
    #116
    Kingair84
    Wisconsin
    Well the service manager called me today. Toyota is going to fix mine for free again. I guess it pays to have a good dealership.
    shakerhood and THE_KiRRAx like this.
  17. Nov 20, 2019 at 8:56 AM
    #117
    Haleylujah13
    Haley
    Washington
    V1 GFC #769
    Dropped the truck off at the dealership this morning, waiting to hear back on outcome and timing :fingerscrossed:
    *Update - they are fixing ASAP at no cost, will be ready tomorrow as they are waiting on a part from Portland. Told them to do a thorough search for mold/mildew. Luckily I think I caught it early
  18. Jun 16, 2020 at 4:43 PM
    #118
    Karlyrie
    Karlyrie Well-Known Member
    Northern New England
    2016 Blue Tacoma,DC SB,V6,4X4
    How well did this work for you? Mine leaks,$400 to fix,warranty wont cover it.
  19. Jun 16, 2020 at 5:02 PM
    #119
    Grossomotto
    Grossomotto Complete 3rd Member
    39.9526° N, 75.1652° W
    2017 4WDV6LB6MT
    Well I didn't have a leak, just used it to seal up the outside. I'd try finding a whole new light assembly with gasket and install yourself, it's fairly cheap.
  20. Mar 3, 2021 at 11:09 PM
    #120
    krzysnwbrdr
    krzysnwbrdr Well-Known Member
    Masaki
    2016 Black Tacoma TRD Sports DCLB
    where is this leak happening mostly?
    body-housing? or housing-light cover?
    DarkestCon likes this.
