Third Gen Beds
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 2020Taco, Nov 4, 2019.
  1. Nov 4, 2019 at 3:47 PM
    2020Taco
    2020Taco [OP] Member
    2020 Off Road Cement
    Can someone please clarify if any of the third gen beds have changed from 2016 through 2020? I'm asking because I ordered an E-max Extang cover for 2016-2019 and it's not fitting my 2020 for several reasons. As far as I know the bed has not changed from 2016-2020 with the exception of the drivers side storage bin being removed after 2018.
    Thanks in advance,
    Pete
  2. Nov 4, 2019 at 3:51 PM
    Tacospike
    Two Trucks
    New to me. I would think dimensions would be the same as fit and finish besides the cubby
  3. Nov 4, 2019 at 4:00 PM
    rblalliance
    rblalliance let the wookie win
    08 TRD OR DCSB 4X4
    The beds should be the same size. What's the issue with the fit i.e. to small, mounting hardware doesn't work, etc.?
  4. Nov 4, 2019 at 4:14 PM
    glenmonte
    glenmonte Well-Known Member
    2020 Tacoma TRD Off Road
    What are the problem areas? May be good to know- I was about to order a cover so it’s ready when the truck is delivered. Maybe I’ll hold off now.
  5. Nov 4, 2019 at 4:16 PM
    2020Taco
    • The bed rail assembly has a tapered v gasket on the side that mates to the truck bed rail, this tapered shape makes the rail angle down and the slam latches can’t reach them, it also makes the sliding clamp assembly incredibly tight
    • The slam latch assembly cable is too short and the latches don’t even come close to the bed rail assembly
    • The bed rail mounted clip for the tail clamp has to be installed partially off the end of the rail to get the tail clamp assembly to line up with it
    • It also came with an extra bracket that's roughly the width of the bed but is not referenced in any of the instructions and makes no logical sense for being needed
  6. Nov 4, 2019 at 4:24 PM
    rblalliance
    08 TRD OR DCSB 4X4
    Wow! There are a lot of things that aren't right. Have you made sure that they shipped you the right cover? According to their site it looks like this is the part#72830 for the e-Max cover.
    GreyBaldTaco likes this.
  7. Nov 4, 2019 at 4:25 PM
    2020Taco
    image.jpg image.jpg Pics for reference of side rail issue and slam latch cable being too short
  8. Nov 4, 2019 at 4:29 PM
    2020Taco
    Yup I was on the phone with a tech this morning, the cover is the right number and fits the bed but l'm not sure the hardware is correct and/or manufactured correctly. The cable being too short makes no sense since the only way it would work is if the truck had crazy wide bed rails. I've installed about six Extang bed covers in my life and this is the first one that I couldn't figure out because so much is wrong.
  9. Nov 4, 2019 at 4:34 PM
    2020Taco
    I got an email reply from another tech who told me to remove the tapered gasket and install it the other way, I responded saying that this would just create a similar issue in the bed rail assembly pointing up as my bed rail sides are vertical. He said to wait for the other tech l was on the phone with to respond.
  10. Nov 4, 2019 at 5:44 PM
    rblalliance
    08 TRD OR DCSB 4X4
    At this point I would agree the that the mounting hardware could be the issue. If the second rep doesn't help you solve your issue I would just return it. I don't have the extant cover, but with mine once I installed the brackets on the bed rails it was just making sure everything lined up and then securing the cover in place.
  11. Nov 4, 2019 at 5:53 PM
    glenmonte
    Thanks for the photos and explanation! I was on the fence about this one, but your issue made up my mind about just going with one of the cheapest covers.
  12. Nov 5, 2019 at 4:58 PM
    2020Taco
    Good call, I still have no answers and am getting frustrated. $500 and this is what I get.
  13. Nov 11, 2019 at 6:05 AM
    2020Taco
    So after a week of going back and forth with Extang they have decided that my cover is defective, I destroyed it by cutting out a section of the vinyl cover and emailed a photo of the cutout to them. Replacement cover will be sent, hopefully it’s correct this time.
    rblalliance, Stoked and Grossomotto like this.
  14. Nov 17, 2019 at 4:50 PM
    2020Taco
    Cover is finally on, the replacement came with the wrong hardware but l used the hardware from the first one.
    Stoked likes this.
  15. Nov 17, 2019 at 4:51 PM
    2020Taco
    Works well
  16. Nov 17, 2019 at 6:23 PM
    TacoSale
    TacoSale Member
    Looks good
  17. Nov 18, 2019 at 4:27 PM
    rblalliance
    08 TRD OR DCSB 4X4
    Glad they sent you a replacement and you were able to make it work :thumbsup:
  18. Nov 29, 2019 at 2:21 PM
    glenmonte
    Just put a Gator ETX on. Seals ok, but I noticed gaps around the hinges. I guess I'll have to see how it holds up in the rain (or garden hose).
  19. Nov 29, 2019 at 3:09 PM
    dansflhti
    dansflhti Well-Known Member
    Nova Scotia
    24 TRD Sport +.16 Mustang GT. 14 Street Glide
    This week I installed an extang trifecta 2.0 on my 2020 orsb and everything fits.
  20. Nov 29, 2019 at 3:45 PM
    glenmonte
    The Gator came from Realtruck via Amazon, and they are looking into it. But the Extang was the runner up along with Tonno Pro. Thanks for letting me know the fit works on the Extang.
