Third Gen Coolant Bypass Pipe Fix
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Billy050302, Aug 25, 2025.
  1. Aug 25, 2025 at 5:50 PM
    Billy050302
    Billy050302 [OP] Member
    William
    2017 Tacoma TRD Sport
    I wanted to share my fix for the plastic Coolant Bypass Joint/pipe that is common to fail on the third gen tacomas. I came up with a different fix, because the plastic tube failed at 65k and I'm not one to leave things stock if there is an obvious design flaw. Aka. I'm not doing this again at 130k miles. Kudos to all the other threads that mentioned the Lexus pipe, otherwise I wouldn't have known there was something close that would work with "some" modification.
    1. Start with the aluminum Lexus Pipe PN: 16356-31080 and upgraded gaskets PN: 16341-31030 Qty: 2
    2. Pull large and small tubes out
    3. Drill & Tap large tube location for 1/2npt
    4. Drill & Tap small tube location for m10 x 1.0
    5. Plug 1/2npt with 90 degree brass fitting below. Angle the fitting so that it pointed slightly towards the middle of the engine. (Use red loctite or epoxy)
    6. Plug the m10x 1.0 hole with a blanking plug similar to the picture below.(Use red loctite or epoxy)
    7. Installed the 5/8 barbed fitting after the pipe was installed on truck (makes routing the pipe through the top of the engine easier)
    Installation took about 6 hours, and I got to the pipe from the top of the engine. Removed the upper intake and removed the transmission mount to jack the transmission up so the engine would rotate away from the firewall.
    Note: the only other difference between the Lexus and toyota part is the aluminum tabs and the big chunk on the right. I cut them off and relocated them, but that step isn't necessary. Those tabs are for a wiring harness, and you can just zip tie the harness back in place.
    jmneill, BabyBilly, mattm55 and 16 others like this.
  2. Aug 25, 2025 at 6:02 PM
    rtzx9r
    rtzx9r Well-Known Member
    Bueller
    2016 TRD Sport
    LS1 swap with nitros.
    Hell yeah that looks good! Do you have a pic of the finished component before you installed it?
    did the pipe on my 2016 a few years ago at 80k. Just did 120k service this weekend at home and the coolant expansion tank was at the “low” level. Too scared to look at that dreaded pipe again.
  3. Aug 25, 2025 at 6:09 PM
    Billy050302
    William
    Added.
    Please let me know if I missed any details.
    JmsWms and rtzx9r like this.
  4. Aug 25, 2025 at 6:22 PM
    4x4spiegel
    4x4spiegel Well-Known Member
    good write up !! let us know how it goes as the miles go by .
  5. Aug 25, 2025 at 6:31 PM
    MGMDesertTaco
  6. Aug 25, 2025 at 7:10 PM
    blu92in99
    blu92in99 Hates everyone, equally
    Justin
    Elk Grove, Ca
  7. Aug 25, 2025 at 7:40 PM
    BarRedAmateur
    BarRedAmateur Well-Known Member
    2017 TRD Off road
    Will be replacing mine eventually. Your modifications seem easy enough I may have to copy this. Hoping it holds up better than the plastic.
    Toy_Runner likes this.
  8. Aug 25, 2025 at 9:05 PM
    ChevyJ7
    ChevyJ7 Member
    Bill
    2021 Trd Offroad
    Lift, 488 gears, OTT tune
    on the final product looks like you cut off or ground off excess aluminum protrusions on the right side to clean up the final product. I was wondering about the hole on the right side that does't appear to be closed or tapped.
  9. Aug 25, 2025 at 10:40 PM
    Billy050302
    William
    I did remove the excess material, but that was just a preference.
    The hole on the right is for a temperature sensor, which you can reuse the one currently on the truck. It's just held in place by a wire clip.
    Ngneer likes this.
  10. Sep 8, 2025 at 7:29 AM
    ScaryVersion
    ScaryVersion Well-Known Member
    Lancaster, PA
    2017 Cement PRO DCSB
    Any concerns with the brass being effected by the lower pH of the coolant?
    I wonder if stainless would be a better option. Thanks for the write up I have been dreading doing this and putting a plastic part back on but this is a great option!
    Thanks again!
  11. Sep 8, 2025 at 9:04 AM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly a 1998 SR5 PU, 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    Looks good! I’m not very familiar with that part, what did you do with the inlet shown here?
  12. Sep 8, 2025 at 9:21 AM
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    Thats
    this is a location of the coolant temp sensor. Suppose to move one from the old assembly
  13. Sep 8, 2025 at 9:27 AM
    slater
    slater Well-Known Member
    San Diego
    24 white Tacoma TRD Sport 2wd
    Ford have a plastic tstat housing on the 4.0sohc ranger / explorer, with 2 push in temp sensors similar to this...
    Everytime someone just swaps them over without replacing them as you can just service the rubber oring, no oem part for oring only.
    Ends up leaking every time...
    Install a new sensor, especially if its challenging to get to,
    Some guys tried using generic orings without success.
    Not worth the risk...
  14. Sep 8, 2025 at 9:43 AM
    denimdan73
    denimdan73 Well-Known Member
    2022 TRD Off Road DCSB
    Pro Skid Plate - Lone Star Knock Off Trail Edition Lift - DIY - Toyota Parts Cooper S/T MAXX 255/85/16 Body Armor Sliders
    Very cool fix!
    Thanks for sharing!
  15. Sep 8, 2025 at 10:15 AM
    Billy050302
    William
    @ScaryVersion I was originally trying to use all aluminum fittings, but the brass had lower profile ones that help save space. Most coolant sensor fittings, and freeze plugs are brass so I am not concerned.
  16. Sep 8, 2025 at 2:01 PM
    OnHartung'sRoad
    Just another question- did you relocate the harness mount you cut off by gluing it onto the left side rib of the pipe? If so, with epoxy?
    This thread needs to be a sticky!! Great job, Billy!
  17. Sep 8, 2025 at 2:55 PM
    Billy050302
    William
    @OnHartung'sRoad Yes sir, I used high temp epoxy. However you could also just use zip ties.
    Ngneer and OnHartung'sRoad like this.
  18. Sep 8, 2025 at 5:58 PM
    Vlady
    Issy, WA
    I would not know. I successfully avoided Ford products all my life and mcgyvering critical system of the engine in my cars
  19. Sep 8, 2025 at 6:59 PM
    cord
    cord New Member
    2023 Tacoma SR5 Icecap
    Is the metal part missing the groove for the O rings? The plastic part appears to have a grooves for an O ring.
    Did you have any troubles getting it to seal?
    JmsWms likes this.
  20. Sep 8, 2025 at 7:25 PM
    slater
    San Diego
    im just trying to point out, reusing that sensor if its old, or even if its not old, may result in the sensor leaking due to the ring is compressed.
    Principal is the same, regardless ford or toyota...
