Third gen spare tire/wheel
Discussion in '3rd Gen. Tacomas (2016-2023)' started by JDR07, Feb 1, 2018.
  1. Feb 1, 2018 at 4:43 AM
    JDR07
    JDR07 [OP] Well-Known Member
    Colorado
    2016 DCSB TRDOR
    Duct Tape
    This should probably be in the wheels/tire section but I wanted input from 3rd gen owners.
    I recently bought an aftermarket set of wheels. I am debating whether to buy a 5th or not.
    I do not have an aftermarket rear bumper so the 5th rim will be under the bed. Do you guys think it will get damaged there?
    Also, if I put a tpms sensor on the spare will the 3rd gen taco recognize it? Or will it only recognize the four mounted?
    Thank you for your time.
  2. Feb 1, 2018 at 4:45 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I don’t think it would get any more damaged than the other four wheels that are on the truck, exposed to the elements.
    As far as TPMS, I don’t think the truck can handle any more than the 4 sensors.
    shakerhood, Forge and JDR07[OP] like this.
  3. Feb 1, 2018 at 4:51 AM
    JDR07
    Colorado
    2016 DCSB TRDOR
    Duct Tape
    See I didn't know cuz prior to 2008 the tacos use to come with 5 tpms's.
    EatSleepTacos[QUOTED] likes this.
  4. Feb 1, 2018 at 4:58 AM
    Weekend TRD
    Weekend TRD Member
    Ohio
    2016 TRD Sport
    The truck can only read 4 sensors at a time. I just had this talk with my dealer.
    I was going to get A 5th, but put it on my spare rim.(under the truck) I'm running 265/70/17 K02
    JDR07[OP] likes this.
  5. Feb 1, 2018 at 5:00 AM
    Skidog1
    Skidog1 Well-Known Member
    Chicagoland
    2016 Black TRD 4x4 Sport DCLB
    Does your truck recognize sensors from cars parked nearby?
    specter208, crazychris4124 and Hobbs like this.
  6. Feb 1, 2018 at 5:05 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Kheiron, Cudgel, redeckert and 8 others like this.
  7. Feb 1, 2018 at 5:10 AM
    JDR07
    Colorado
    2016 DCSB TRDOR
    Duct Tape
    Did your sport come with a 17" Steelie under the bed?
  8. Feb 1, 2018 at 5:13 AM
    Weekend TRD
    Weekend TRD Member
    Ohio
    2016 TRD Sport
  9. Feb 1, 2018 at 6:04 AM
    JoeyDel
    JoeyDel Well-Known Member
    Joe
    South Jersey
    2003 Off Road AC and '16 AC Sport Silver Sky Metallic
    I put after market wheels on and bought a fifth for the sole reason being that they used different lug nuts. Normally you would think this is fine but I wanted to avoid the odd chance of someone other then me driving my truck and getting a flat and using the wrong lug nuts which would be really bad.
    I know this doesn't answer the OP's question but I thought it might be worth putting it out there.
    nartmot and JDR07[OP] like this.
  10. Feb 1, 2018 at 6:32 AM
    Friedtacolover
    Friedtacolover Well-Known Member
    Travis
    Ontario, Ca
    2017 DCSB Off Road 4x4
    my build tread: https://www.tacomaworld.com/threads/socal-no-shame-poser-build.513084/
    Op I put a 285/70r17 spare under my 17’ . Fits with zero issues and the way the wheel goes up it goes up nice side up so no damage should be expected. Its not an issue do it. Gen 2 you had to hammer and pry this truck you dont
  11. Feb 1, 2018 at 7:06 PM
    JDR07
    Colorado
    2016 DCSB TRDOR
    Duct Tape
    i thought about this as well...i also thought about the stock 17" steelie having the same BS to clear the UCA's
  12. Feb 1, 2018 at 7:07 PM
    JDR07
    Colorado
    2016 DCSB TRDOR
    Duct Tape
    do you think there would be space up there for a 295/70/17?
  13. Feb 1, 2018 at 7:09 PM
    jerzsubbie
    jerzsubbie Well-Known Member
    Davidson, NC
    ‘13 GX460
    Thanks for this info. I was curious if a 255/75/17 would fit, figured it was pretty likely. I just need to get a 17" steelie now.
  14. Feb 1, 2018 at 7:13 PM
    JDR07
    Colorado
    2016 DCSB TRDOR
    Duct Tape
    seems like the other posters agree with buying a 5 aftermarket rim...any reason why you are still going with a steelie? I'd like to bring different perspectives into the conversation
  15. Feb 1, 2018 at 7:20 PM
    ElGatoLoco
    ElGatoLoco Well-Known Member
    '17 DCSB TRD Sport
    I bought a 5th for my spare but haven’t mounted it on a tire yet. Still need to do that
  16. Feb 1, 2018 at 7:21 PM
    jerzsubbie
    Davidson, NC
    ‘13 GX460
    Cost, scarcity of SCS wheels, and the slim probability that I'll actually need to use my spare. Even if I do need to use it, I'll still need to go to a shop to get the TPMS swapped, so I may as well just get the damaged tire repaired or replaced, at which time I'll have 4 matching wheels again.
    I'm all about value, utility, and practicality, so this path makes the most sense to me.
    JDR07[QUOTED][OP] likes this.
  17. Feb 1, 2018 at 7:28 PM
    MikeyMcFly
    MikeyMcFly This is heavy, Doc.
    I'm a Masshole
    2016 TRD Off-Road 6MT / 2021 WRX STI
    Building a Broja
    I purchased a 5th wheel when I got my set, but it wasn't for a spare, it was concern if one of the four I had on the truck was damaged, I'd have a replacement and I wouldn't need a new set of wheels.
    I did buy a matching tire when I went to 265/75 on my old truck, which I mounted on the steel wheel. I also had a separate Sport alloy with a stock sized tire to match my snow tires (which were stock sized). The beauty is that when my 2G was totaled I actually still had the 265/75 BFG in my cellar as I hadn't replaced the spare yet. So now with the new truck I've got two spares, one in 265/75 and one in 265/70.
    For how rare you will use a spare, I don't see a point in having a matching spare wheel / tire set-up. Just make sure that it's the right size and that it's in good condition / inflated and you should be golden. Also occasionally drop it and oil the winch setup so that you don't have a situation where it's completely seized up. On my 93 Xtracab the winch was completely seized and I had to cut the spare out of the truck. It was original to the truck and almost 20 years old, so the tire and wheel were both completely rotted out.
  18. Feb 1, 2018 at 7:47 PM
    JDR07
    Colorado
    2016 DCSB TRDOR
    Duct Tape
    anybody know what the backspacing is on a 17" oem steelie?
  19. Feb 1, 2018 at 8:20 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Should be the same as a 16” steelie, if you wanted to measure yours. Definitely not enough to run a 295 though.
  20. Feb 1, 2018 at 8:56 PM
    Friedtacolover
    Travis
    Ontario, Ca
    I got one :) but in so cal haha
