Third gen tailgate strength
Discussion in '3rd Gen. Tacomas (2016-2023)' started by pdeinc, May 30, 2022.
  1. May 30, 2022 at 11:50 AM
    Toyko Joe
    Toyko Joe Here for the pictures
  2. May 30, 2022 at 11:58 AM
    TAZMINATOR
    TAZMINATOR Well-Known Member
    2017 Tacoma
    That's how I got the website via Google Images. I meant to copy an image but I selected 'open link in new tab' by mistake instead. And I noticed that site has bunch of images. So I posted a link instead of image.
  3. May 30, 2022 at 12:08 PM
    Lava-road
    Lava-road Well-Known Member
    2019 trd-off road
    Hard top camper...many more to add+
    I read someone found Toyota ratings tailgate is 400lbs. Remember that cable and hinge is just a screw. The hinge at the bottom of the tailgate is just a screw (bolt). Holding the tailgate. I added a SS hose clamp to prevent a easy removable for my tailgate, I am sure it will not stop the thieves.
    The tailgate is a double side sheet metal too. But anything can be done.
    Sounds like a trailer maybe a smarter idea? Vs damages to the Tacoma bed and tailgate?
    Better yet , use your friends Tacoma first? Lol
  4. May 30, 2022 at 1:22 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    IMHO, pickup beds are for stuff you can lift by hand or in rare occasions with a fork lift. I know you can roll/drive stuff up a ramp, but in those cases a trailer makes more sense to me. The taco’s bed and payload is teeny tiny. My 4x4 DCSB has about 600 lbs of payload capacity left over with just me and a few bits gear and armor. That said it preforms like a champ at 5000 lbs.
    Junkhead likes this.
  5. May 30, 2022 at 1:41 PM
    Lava-road
    2019 trd-off road
    I have seen a few places that rents trailers? Most Home Depot and Lowes sells trailers too. Reasonable prices.
    In fact , the landscapers all have trailers, many buy them from these box stores.
    My trailer had small tires, I ended up fitting in 32 inch tires. For off roading. Wish I install a spinning hitch mount.
  6. May 30, 2022 at 6:29 PM
    pdeinc
    pdeinc [OP] Well-Known Member
    Ken
    2019 TRD 4x4 Sport
    ARE Z topper, Roadmaster baseplate, Remco DS disconnect
    Thanks!
  7. May 30, 2022 at 6:33 PM
    pdeinc
    Ken
    2019 TRD 4x4 Sport
    I provided the dimensions earlier, 42 1/2" between wheel wells, cart thread width about the same, max width across sidewalls is 44". And it's a long bed.
  8. May 30, 2022 at 6:35 PM
    Lava-road
    2019 trd-off road
    I broke my 1999 Ford Ranger tailgate cables two times, got old and worn out. When you see the above pictures, notice the screw holding the cables, those screws can be a weakness too , besides the cables and clamps of the cable holders.
  9. May 30, 2022 at 6:35 PM
    pdeinc
    Ken
    2019 TRD 4x4 Sport
    Not sure you understand, I'm towing the Tacoma behind our RV and plan on carrying a golf cart in the truck. I already have a golf cart trailer but don't wish to double tow and deal with trailer storage in the campground.
  10. May 30, 2022 at 6:45 PM
    oconnor
    oconnor Where am I?
    Midwest
    '18 TRD Sport 4x4 AC 6MT/ '04 TJ Rubicon
    I was one of the 2nd gens who bent their tailgate.
    Loading motorcycles in my '05 slightly bent it in a V shape. It would still latch but you could see the gap was larger at the top on both sides and a slight bow when open. TSB replaced it with the V2 tailgate that I was told contained a new "stiffening plate" across the top. Never had another issue.
  11. May 30, 2022 at 6:46 PM
    pdeinc
    Ken
    2019 TRD 4x4 Sport
    You don't give these trucks much credit. I've had minis (before Tacos), a 1st gen Taco, Gen 1 and 2 Tundras, and a FJ Cruiser before this Taco. I put over 3,000 pounds in my first one several times after upgrading the tires to 6 ply and adding helper springs. And this bed is nearly identical in size to my first Tundra so wouldn't call it "teeny tiny"!
    I'm towing the Tacoma behind our RV so trailering the GC is out. I already have a trailer for it but not going to double tow. The payload is 1,440 lbs so there's plenty of capacity and since it's being towed, there's no passenger weight.
  12. May 30, 2022 at 6:47 PM
    pdeinc
    Ken
    2019 TRD 4x4 Sport
    Thanks for the reply, that's what I was looking for.
  13. May 30, 2022 at 6:50 PM
    TAZMINATOR
    2017 Tacoma
    Okay.. Good luck and have fun.
  14. May 30, 2022 at 6:57 PM
    pdeinc
    Ken
    2019 TRD 4x4 Sport
    400 pounds seems reasonable and also a little light for my intended purpose. I also bet the limit is based on the cables which is how I got here in the first place...looking for rigid support bars to use instead of the cables.
    I'm towing the Taco behind our RV so trailering the golf cart is not an option.
  15. May 30, 2022 at 6:58 PM
    #35
    Lava-road
    2019 trd-off road
    Oh , towing the Tacoma, and want a golf cart in the bed of the the Tacoma. Wow! Thank you for the correction.
    pdeinc[OP] likes this.
  16. May 30, 2022 at 7:07 PM
    #36
    OldSchlPunk
    OldSchlPunk I'm not sick, but I'm not well
    Rich
    East Central Wisco
    '17 AC OffRoad Silver Sky Metallic
    Small lift, slightly oversized tires, well...
    An inch and a half is an awful large difference to wedge between the wheel wells. It may be tire sidewall, but there is only so much give. Maybe you can make some blocks to run the tires over the wheel wells. Good luck.
  17. May 30, 2022 at 7:43 PM
    #37
    pdeinc
    Ken
    2019 TRD 4x4 Sport
    The wheel wells angle away from the center so the width at the height of the max tire sidewall is probably equal to the cart width. If not I was planning to lay down some 1 x 6 planks. It won't take much to create the needed clearance.
  18. May 30, 2022 at 7:47 PM
    #38
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    Check your door jam sticker, payload on a long bed sport generally maxes out at around 1100lbs on an access cab, less on a double cab.
    Sharpish, Junkhead and shakerhood like this.
  19. May 30, 2022 at 9:20 PM
    #39
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Yeah l think the DCLB has the lowest payload of the entire Tacoma lineup.
  20. May 30, 2022 at 9:28 PM
    #40
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    Yep, mine says 950.
