third member gear ratio
Discussion in '1st Gen. Tacomas (1995-2004)' started by seaker236, Jul 22, 2017.
  1. Jul 22, 2017 at 8:37 AM
    seaker236
    seaker236 [OP] Member
    2003 wht ex cab trd
    I have a "03" trd V6 4x4 excab Taco, can anyone tell me how to determine what the gear ratio is in my rear diff or third member ( and why is it called the "third member" and is the T case the "second member" or what) other than counting the teeth on the ring and pinion?
    Thanks for your help
  2. Jul 22, 2017 at 8:40 AM
    charliegt35r
    charliegt35r MALL CRAWLERs
    CenCal
    2003 tacoma dc
    OME 2.5 LIFT 285/75/16
    https://www.tacomaworld.com/threads/oem-gear-ratio-chart.365138/
  3. Jul 22, 2017 at 9:02 AM
    seaker236
    2003 wht ex cab trd
    A/TM B03A/ means 4.10?
  4. Jul 22, 2017 at 1:13 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    Should be. If you want to make sure you can turn the wheel and count the rotations of the driveshaft (and vice-versa) but I forget what the math was.
  5. Jul 22, 2017 at 1:15 PM
    stevotivo12
    stevotivo12 Well-Known Member
    Stephen
    2016 Silver Tacoma TRD Sport MT
    Front hellwig sway bar,All pro sway bar end links, Fox 2.5 Resi Coilovers and Shocks, Fox 2.5 Hydraulic Bumpstops, Budbuilt Traction bar, Total Chaos UCAs w/ heim joints, Icon AAL, AFE Power Intake with dynamic scoop, URD spec U, URD short shifter, Flossy weighted shift knob, michelin tires, black badges, black tailgate letters, black grill with custom Diaz Fab Devil horn yota logo, retrofit/morimoto HID conversion, red interior LED lights, Pioneer head unit, kenwood excelon door speakers, 2 10" pioneer subs,
    Wheel spins 4.1 times per driveshaft rotation
  6. Jul 22, 2017 at 1:20 PM
    COMAtized99
    COMAtized99 Well-Known Member
    North Carolina
    99 DCLB v8
    The Bed is stock...ish
    Or, if your lazy like me, you get the vin, call your favorite Toyota dealership, and ask the parts guy what gear ratio came* in your truck...
    * The vin tells you what your truck came with stock....
  7. Jul 22, 2017 at 5:51 PM
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    backwards.
    it's 4.1 turns of the drive shaft to one rotation of the tire :)
  8. Jul 22, 2017 at 6:01 PM
    stevotivo12
    Stephen
    Whoops! Good catch
  9. Jul 22, 2017 at 6:55 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    Yup. Called them up this morning to make sure (and to check for recalls) I have 4.30 like I thought.
  10. Jul 23, 2017 at 8:10 AM
    tacoma_2002
    tacoma_2002 Where We're Going We Don't Need Roads...
    Andrew
    Cotton Plant, Mississippi
    '02 Tacoma 4x4 TRD
    If you ever have a diff that you suspect has been changed the gear codes on the door might not be accurate. Best bet in this case is to count the number of teeth on the ring gear and pinion. Ring Gear #/ Pinion #= Final Ratio
