Third Member
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Mlea, Mar 25, 2023.
  1. Mar 25, 2023 at 8:36 PM
    Mlea
    Mlea [OP] New Member
    Question:
    Does a 2013 Tacoma pre runner and a 2013 4x4 have the same third member? Like exactly the same? We are trying to replace the ring and pinion with all the bearings (front, rear and 2 carriers) Everything/everywhere matches what we have originally on the truck but it’s for a pre runner. My truck is a 4X4.
    4.0L V6 Base model
  2. Mar 25, 2023 at 9:53 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Some PreRunners were Off-Road.
    They had an e-locker. So that one is not the same.
    Also, the 2.7L (4 cylinder) trucks had 4.10 gears.
    Yours has 3.73.
    What you want is a 3rd member from a 6 lug, 6 cylinder truck WITHOUT an e-locker.
    Just_A_Guy and Dm93 like this.
  3. Mar 25, 2023 at 10:17 PM
    Mlea
    Right! Mine is a 3.73. 12 bolt, 30 spline, 8.4in ring and pinion. When I look for the bearings everything to that match (3.73, 12 bolt, 30 spline, 8.4 in) matches a prerunner, and says nothing about a 4x4. My husband was trying to look it up and found where it said both 2013 pre runners and 2013 4X4 had the same third member. I was trying to confirm that. It would only make since to be the same being we can’t find a match for a 4X4. The place we bought the ring and pinion can’t find a bearing set for that specific ring and pinion. I’m just trying to find the bearing I need. And everywhere I turn no one knows lol
  4. Mar 25, 2023 at 10:43 PM
    TnShooter
    Deogee
    STOCK
    The 3rd member should be the same.
    As far as I know, In 2013 Toyota only offered 2 different differentials for the 6 lug trucks.
    An 8.4” and an 8”. The 8.4” was in all the trucks EXCEPT the TRD Off-Road trucks.
    The Off-Road had the 8” differential.
    Have you looked into buying a drop-in fully assembled 3rd member?
    That’s a lot easier. And to be honest, it worth the money, time, ease of swapping.
  5. Mar 26, 2023 at 12:49 AM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    TnShooter likes this.
  6. Mar 26, 2023 at 10:36 AM
    Mlea
    Thank you so much!!!
