This 99 taco again!!!
Discussion in '1st Gen. Tacomas (1995-2004)' started by 36tacundra, Nov 26, 2017.
  1. Jun 9, 2018 at 4:23 PM
    #101
    36tacundra
    36tacundra [OP] Well-Known Member
    Hooked up the throttle, bled the brakes, and hooked up the e brake today. Now she moves again on her own power again. I have to hook up the shift lock. the 2x4 cab had a column shift, so the wiring is not where I need it. When the steering column was removed, they clipped the wiring. This will not be a problem. I solved the same issue when I put the tundra wiring in the 03 Tacoma for the v8 swap. The Tundra had a column shift. I still need to weld up the exhaust also along with finishing the front 4x4 system...and fenders...and head lights...and registration... Im going to drive this thing while I work on the 05 prerunner conversion. Fenders optional, LOL December 13th 2017DSC00575.jpg
    Here is the most recent progress
  2. Jun 11, 2018 at 12:53 PM
    #102
    MagicMexican
    MagicMexican Well-Known Member
    Alejandro
    Pueblo, Colorado
    1998 Tacoma Xcab TRD 4WD 5-Spd
    Aftermarket Wheels
    Did you polish that door up?
    You know what funny is that it looks like a junker from the outside, but if you open it up, the interior is nice and clean lol
    36tacundra[OP] likes this.
  3. Jun 11, 2018 at 2:37 PM
    #103
    36tacundra
    I know, It will be the best part of it. Runs good, feels good, looks like new inside, and a POS from the outside. At least it is a Toyota. Other makes, I would loose my ass on a rebuild like this.
  4. Jun 11, 2018 at 2:41 PM
    #104
    36tacundra
  5. Jun 13, 2018 at 4:26 PM
    #105
    36tacundra
    Dalandser and MagicMexican like this.
  6. Jun 13, 2018 at 8:13 PM
    #106
    MagicMexican
    Alejandro
    Pueblo, Colorado
    Aftermarket Wheels
    That looks pretty good!
  7. Jun 21, 2018 at 9:22 PM
    #107
    36tacundra
    I cut out the radiator support. I used a pinch weld drill bit. I ground off the excess. I hammered out the inner fender and set the new support in. I also set the fenders on just to get a look at it. Here it is.DSC01081.jpg DSC01084.jpg DSC01087.jpg DSC01085.jpg DSC01088.jpg DSC01089.jpg DSC01091.jpg DSC01090.jpg DSC01093.jpg
  8. Jun 21, 2018 at 10:34 PM
    #108
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    What was wrong with the old one - I couldn't make out any damage on it?
  9. Jun 22, 2018 at 10:08 AM
    #109
    36tacundra
    DSC01083.jpg The damage was not that bad. I could have hammered it out. I am going to put a 01 to 04 tacoma front clip on the truck. I could have gone with 99 or 01 style. I chose 01 style because the hood I have on the truck is damage, so I will get another. As the fenders go, 01 to 04 can be used on a 99 just by removing the bracket the headlights attach to.
    Dalandser[QUOTED] likes this.
  10. Jun 22, 2018 at 10:15 AM
    #110
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Figured it must be on the far side in the photo I was looking at. Yeah I don't see too many people restoring these and sticking with the 96-00 style front clips. They make 1 piece headlights for the 01+ too.
  11. Jun 22, 2018 at 10:23 AM
    #111
    36tacundra
    They make 1 piece headlights for the 01+ too.[/QUOTE]
    I had a set on the 03 v8 conversion. They ended up being a pain in the ass. I went to change the alternator and I had to remove the electric fans, the radiator, the head lights with the grill, and the ac condenser. But hay they sure look cool, LOL
    Dalandser likes this.
  12. Jun 22, 2018 at 4:52 PM
    #112
    COMAtized99
    COMAtized99 Well-Known Member
    North Carolina
    99 DCLB v8
    The Bed is stock...ish
    So... Many... Colors....
    Love it!
  13. Dec 28, 2018 at 1:28 PM
    #113
    36tacundra
    So I have not been on in a while, June! LOL, but I have been busy. I got the 01 04 taco hood, grill and lights. The auto trans I had in it did not have drive or over drive gears. It seems I burned them out bringing this pile home with the pre swapped 03 v8 truck. I installed a 5 speed manual. I cut out the old trans crossmember mounts from frame, ordered a new cluch, installed 5 speed, mounted crossmember, welded mounts in new location, change cab wiring, changed engine wiring, mounted hydrolic cylinders with clutch pedal, changed brake pedal, got another set of wheels, made the best of 2 front 99 bumpers. I am still missing some pieces, but it is looking like a truck again.
    DSC00223.jpg DSC00566.jpg DSC00178.jpg DSC00181.jpg DSC00179.jpg DSC00180.jpg DSC00185.jpg DSC00187.jpg DSC00188.jpg DSC00194.jpg DSC00207.jpg
    Jc91 and Wulf like this.
  14. Dec 29, 2018 at 10:42 AM
    #114
    36tacundra
    Anyone Have a electrical wiring diagram for 1999 4WD (w/o 2-4 select SW) system?
  15. Jan 9, 2019 at 2:18 PM
    #115
    36tacundra
    I had to steel the manual hubs for my 2nd gen prerunner to 4x4 conversion. I did not have another set. I did have auto hubs lying around. I put them in a set of non abs steer knuckles with new wheel bearings. That would leave me with a type of full time 4x4. I changed out the front diff to an add style. I had to figure out how to make it work. Thanks to COMAtized99 for sending me a wiring diagram, I was able to build relay wiring to work the system. Yesterday I went to the wreaking yard and fished around in a 90s 4runner. It had add. The wiring was different colors, but I was able to track down the add relay. It was behind the dash gauges above the steering column. It has fuel pump relay printed on it (multi purpose) I guess. So last night I built a wiring harness. I did not know if it would work. Today I tried it out and the relay switched on. So a friend and I hooked it up and plumed it to vacuum. It worked!!! I put it in 4x4 and tried it out on the 30 year old grass pile. I had fun. All of this work and I finally got to mess around on the grass pile YAHOO! To be honest I thought about bagging this project more than a time or two.
    Tour991, Pervy, 16Tacos and 2 others like this.
  16. Jan 10, 2019 at 1:35 PM
    #116
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    FrankenTACO!!!
  17. Jan 15, 2019 at 10:24 AM
    #117
    36tacundra
    So I am not sure if I really did this correctly, but It works. After figuring out how the ADD relay worked, I needed to hook it up in the final position. The engine bay had the ADD vacuum solenoid wiring. It went into the cab into one side of the plug, but not the other. I looked at all my wiring. 3 cabs and 3 engine bay head light side.
    I was looking for wiring I could use for the relay. The original white 99 cab had a 2.7 auto with manual hubs. It was also wired with the add relay and 4wd computer pig tail. I think they did this because it had an automatic transmission.
    So I fished the ADD relay wiring pig tail out. It was located at the passenger kick panel. It ran to J/B #3 all but the two wires that run to the plug by the fuse box.
    So 5 wires 2 black and yellow. I ran to acc on power in J/B 3 in the new cab
    The red with white stripe I ran into the back of the dash to a green with back stripe. This wire is grounded when switching from 2x4 to 4x4 and the 4x4 light comes on. the other two wires I ran to the plug at the left kick panel. It works. I wonder if I will be blowing a fuse. I still need to locate the relay. I was thinking of the glove box for easy access.
  18. Jan 15, 2019 at 3:36 PM
    #118
    COMAtized99
    North Carolina
    99 DCLB v8
    Awesome, glad you got it figured out
  19. Jan 28, 2019 at 10:40 PM
    #119
    36tacundra
    I was bothered by how I ran the ADD power wires black and yellow stripe. I tied them into the gray and red striped, but I did not what system they powered.
    So I pulled out the wiring loom I got the ADD relay pigtail from. I followed the back with yellow stripe from junction block 3 to the main fuse box. I unpinned the wire from the back of the fuse box. I marked the location with a sharpie.
    DSC00257.jpg I then took apart the bottom dash to get to the one in the truck. The plug at the back had an empty slot. When turned the the key to on, the pin had power.
    I then installed the black with yellow stripe and ran it to the junction block 3. I moved the ADD wires to run off of this system alone.
    So I believe I can now rest.
    This junction block also had illumination going to it. green with red stripe power side and white with green stripe negative side. The only radio antenna I could find was a power antenna from an 98 4runner. I got the antenna relay with it. I wired the relay into the radio system, but I was a little board. I used the ECT button from the automatic transmission to make a power antenna switch. It is a 4 wire switch. 2 for Illumination and two for the system. I ran the illumination to junction block 3 and tied into the others wires of similar color. The other 2 I ran to the antenna relay and the radio antenna power. For this switch I did not have to cut or splice any wires. I just repined them. Now the radio antenna works like normal with the antenna going up and down with power or when switching from tuner to cd, only I now have the option of turning the antenna off while keeping the radio on in the AM/FM tuner position. This can be help full at car washes or 4x4ing the bush with the local radio station tuned in.
  20. Feb 4, 2019 at 6:39 PM
    #120
    36tacundra
    I have my appointment for vin inspection at the WSP. I will be getting in some drive time with this bucket of parts real soon. I can't wait.
    COMAtized99 and tony2018 like this.
