This blows-well maybe not.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JJPF, Apr 12, 2010.
  1. Apr 12, 2010 at 4:00 PM
    JJPF
    JJPF [OP] Member
    Dillingham Alaska
    07 access cab sr5 2.7 5 spd
    So my blower motor is not working, it has been working intermittingly for the last couple of weeks and just nothing now. It has always been all or nothing. I've heard that if it is the resistor it will work on HI but not the rest of the settings? Any suggestions appreciated.
    JJPF
  2. Apr 12, 2010 at 4:04 PM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    BSP '10 4x4 TRD Off-Road DC
    See build thread in signature
    Well, first is there any chance you're still in the 3yr 36k warranty?
    Otherwise, I'd pull it out and look to make sure nothing is blocking the blower from being able to turn (debris can get in there pretty easily). I'd start with the simple and go from there.. not sure on the resister bit though it sounds familiar.
  3. Apr 12, 2010 at 6:31 PM
    bb609
    bb609 O.F.
    NH
    '09 TRD Sport Access Cab
    Bilstein 5100 CO's @ 1.75" - Icon UCA's - TSB Rear w/Bilstein 5100's - Air Lift System - Flowmaster 50 Duals(RIP...back to stock for now) - Avid Offroad Arctic Bar - Avid Offroad Nerf Bars - Leer 550 Bedcover - AVS Hood Protector(RIP) - Ventshades - Yota Bed Mat - Sheepskins!!! - Weathertechs
    If it's working on one setting and not another, it is most likely a resistor.
  4. Apr 12, 2010 at 6:42 PM
    NelsonTacoma
    NelsonTacoma This is my derpawayinator!!!!!
    Tucson, AZ
    06 PreRunner TRD Sport 03 4Runner Limited 4wd
    Bilstein 5100's , 6000k HID Hi/Low Kit, Magnaflow Muffler, 1.5 inch AP Wheel Spacers, Mudflap Delete
    If you tap lightly (not too hard) the blower motor with a small hammer and it starts working than you know that its the blower motor. I know fuses are obvious and with your intermittent statement I doubt it's that but make sure you check those too. Hopefully it blows!!:eek:
