This came out of my Front Differential ????
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Taco93, Feb 2, 2010.
  1. Feb 2, 2010 at 9:50 AM
    Taco93
    Taco93 [OP] Well-Known Member
    Milton, Ontario
    2011 TRD Sport
    Extang Trifecta Tonneau, Weathertech Floor Liners
    I changed the front diff oil last week and in amongst all the metallic gook stuck on the magnet was this little piece.
    I am getting a slight vibration/growling/shimmy feeling in my gas pedal when doing about 60 mph. I was thinking wheel bearings but someone had mentioned front differential. Does anyone know what the hell that little piece is and could my front differential be on its way out?
    Thanks
  2. Feb 2, 2010 at 9:57 AM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    Flattened snap ring :pray:
  3. Feb 2, 2010 at 9:57 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    That is from when the housing was machined. It's the little bit of metal leftover from when the drill broke through the housing.
  4. Feb 2, 2010 at 10:05 AM
    Taco93
    Milton, Ontario
    2011 TRD Sport
    Makes sense, Thanks
  5. Feb 2, 2010 at 10:21 AM
    05Moose
    05Moose Middle-Aged Member
    Jim
    In the snow (NorCal)
    '05 4x4 DC LB SR5 #8 (LSD, Tow Pkg)
    '05 4x4 DC LB SR5 (LSD & Tow Pkg), Timbrens, AAL, 5100s (1.75), Owned: 12/3/04 Mods: Fog, Map/Dome Light, Illuminated 4wd Switch, Washable Cabin Air Filter
    Been wheelin' in the ocean lately? Looks like a barnacle.:eek:
  6. Feb 2, 2010 at 10:30 AM
    Crom
    Crom Outside
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    Is your truck lifted?
  7. Feb 2, 2010 at 10:57 AM
    Taco93
    Milton, Ontario
    2011 TRD Sport
    haha, I thought the same thing...only I don't know of any metal barnacles.
    Nope
  8. Feb 2, 2010 at 11:14 AM
    Crom
    Crom Outside
    Nick
    San Diego, CA
    Millions
    Okay so no lift... Good. Then I would do the obvious things first and have the tires inspected and balanced to see if your vibes go away. How many miles do you have on your truck?
  9. Feb 2, 2010 at 11:23 AM
    Taco93
    Milton, Ontario
    2011 TRD Sport
    Just over 60 thousand miles, I'll do the tire thing one day this week. What are some obvious signs that the front differential is failing?
  10. Feb 2, 2010 at 11:31 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    I had the same thing come out of the rear diff on my 98, two of them actually.
  11. Feb 2, 2010 at 11:37 AM
    Taco93
    Milton, Ontario
    2011 TRD Sport
    The oil was black, the only metal was the glob at the end of the magnet. It looked like it was way past due for a change.
    I don't hear any grinding or crunching while driving, only a shimmy type growl that comes and goes and you can feel it in the gas pedal. It is starting to drive me nuts. It has to be either the tires, wheel bearings, or front diff but I'm hoping it's one of the first 2..I'd hate to replace the differential.
  12. Feb 2, 2010 at 11:39 AM
    Taco93
    Milton, Ontario
    2011 TRD Sport
    Nope
  13. Feb 2, 2010 at 11:44 AM
    Taco93
    Milton, Ontario
    2011 TRD Sport
    Will do, I gotta try something. Thanks for your help.
  14. Jan 29, 2011 at 6:54 AM
    ecoterragaia
    ecoterragaia Well-Known Member
    Mid-Atlantic
    '06 RC, 4X4, 5 speed
    Just picked up an '06 Tacoma with 18,000 miles. In changing the rear diff fluid (it's actually still draining now) I got the EXACT same metal piece. I'm also experiencing a very low grumble at 60 mph or above, but only when the throttle is applied. You feel it more than hear it.
    I'm doing the front diff and transfer case this weekend too, as well as cleaning the throttle body, MAF sensor, and hopefully the IAC sensor. Plan to change out the manual trans fluid on monday once I receive the Redline MT-90 that I ordered.
    Hopefully all of these together will get the truck up to par on maintenance.
  15. Jan 29, 2011 at 6:56 AM
    0wrx2
    0wrx2 Well-Known Member
    north nj / upstate ny
    '10 trd sport 4x4. dbl cab. shrt bed.
    i work in a machine shop. thats exactly what it looks like.
