This doesn't look good!! How much is this gonna cost me?
Discussion in '1st Gen. Tacomas (1995-2004)' started by bpkrules, May 21, 2012.
  1. May 21, 2012 at 10:40 AM
    bpkrules
    bpkrules [OP] Well-Known Member
    Jon
    Houston
    Tacoma4x4 BATMAN
    ARB Front bumper. Custom rear bumper. ARB snorkel. 883s 90004s. 1 inch daystar body mounts lift. Full skids. Leather seats.
  2. May 21, 2012 at 10:45 AM
    Hiatt1991
    Hiatt1991 Well-Known Member
    Hiatt
    Flagstaff, AZ/Walnut, CA
    2005 Tacoma Prerunner SR5 TRD offroad
    4" Bodylift 20" Offroad shock spacers Turbo Encabulator
    Torn cv boot. Not terribly expensive if you do it yourself.
  3. May 21, 2012 at 11:04 AM
    BulletToothTony
    BulletToothTony Im only a dick 90% of the time
    You can call me Susan if it makes you happy.
    To much fun on the dunes huh :D
  4. May 21, 2012 at 11:04 AM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    Looks like wet boot though... might need a bear or bushing or whatever the hell is on the differential side as well.
  5. May 21, 2012 at 11:07 AM
    45acp
    45acp Paint me back in Wyoming again...
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
    Meh... keep a spare in the truck and just drive around with that one til it falls off or something.:D
    Seriously, you're probably fine for a long time.
  6. May 21, 2012 at 11:08 AM
    lonzorizo
    lonzorizo Well-Known Member
    Lonnie
    Hoopa, Ca
    2003 TRD OR, 2016 TRD OR Tacoma
    Reboot kit will cost like $13. Not a hard job at all. Or buy a replacement cv with lifetime warranty and keep OEM as spare.
  7. May 21, 2012 at 11:23 AM
    bpkrules
    Jon
    Houston
    Tacoma4x4 BATMAN
    Thanks for the Help:D
    Time to see if i'm up for the job. I will try to replace the whole thing a keep the old as a spare.
  8. May 21, 2012 at 11:34 AM
    Toyotacrawler
    Toyotacrawler She's got the jimmy legs
    Cusseta/Opelika AL
    2010 Tacoma DC TRD Sport
    5100's set to 1.75" Wheelers 3 leaf progressive AAL & 5100's for the rear Konig Countersteer Offroads K&N Drop in WeatherTech's Bed Mat Blacked out Badges Rear leaf TSB
    OP, I think I have a new in box boot at the house from when I had my 2001 Taco. I'm not sure what model you have but I'll look for the boot tonight. If I have it, it's all yours.
  9. May 21, 2012 at 11:48 AM
    bpkrules
    Jon
    Houston
    Tacoma4x4 BATMAN
    That would be great!
  10. May 22, 2012 at 6:38 AM
    Toyotacrawler
    Cusseta/Opelika AL
    Jon I looked last night but I couldn't find that thing anywhere. I can picture the dang box and I remember seeing it I just don't know where. Sorry man. I would go with what the other guys said though and replace the whole thing. That is why I had the spare boot. I found this that might help you.
    http://www.4x4wire.com/toyota/maintenance/cv_axle/
  11. May 22, 2012 at 7:02 AM
    DblstuftTaco
    DblstuftTaco Well-Known Member
    Joe
    Ohio
    02 TRD SR5
    OME 3" Kit New frame
    my boot had a leak last summer, forgot about it and looked at it a couple days ago, inner boot was in 2 seperate pieces. Not a spot of grease left in it. Not sure how long it had been that way. Just got 2 re-man'ed cv axels from Autozone. Smthg like 60 a piece plus core charge.
  12. Aug 28, 2012 at 4:01 PM
    YotaYota
    YotaYota Well-Known Member
    Hey guys, accidently tore my cv boot on both sides yesterday(ripped just like the pic of the OP). Would you guys recomend replacing just the boot ot the the entire cv shafts on both sides?
    keep in mind that im on a pretty tight budget because im a college student, THANKS!
  13. Aug 28, 2012 at 4:01 PM
    YotaYota
    Or is this a good idea?
  14. Aug 28, 2012 at 4:03 PM
    Box Rocket
    Box Rocket Well-Known Member
    Adam
    Syracuse, Utah
    1995 FZJ80 Land Cruiser
    3xLocked, lifted, well used
    superior minds think alike.
  15. Aug 28, 2012 at 4:06 PM
    RacerP
    RacerP Well-Known Member
    Chicago
    2003 4x4
    7th Injector kit, Trans Cooler, Donohoe c/o's, Billy's in the rear, FJ Cruiser Trail Team SE wheels.
    Just a matter of price, time, and your abilities???
    You can re-boot the CV with a reboot kit, or for a little money more buy a reamanned one from autozone for $60
  16. Aug 28, 2012 at 4:20 PM
    YotaYota
    I just think i should fix it because this year ill be living where it snows and they put salt on the rod and dont want that crap in there...
    My abilities are ok to TW standard... Those ok abilities would included installing a lift kit, replacing brake pads, welding and semi redesigning exhaust system etc... I have basic tools and a chilton manual and little money haha
    Time wise i can drive other cars around while i fix the yota but i leave in 2 weeks so it has to be done by then
  17. Aug 28, 2012 at 8:10 PM
    YotaYota
    bump for help with the cv questions
  18. Aug 31, 2012 at 6:49 AM
    crainholio
    crainholio Well-Known Member
    If money is tight, I'd just replace the CV shaft assembly on the failed side. I use NAPA "Max-Drive" new (not rebuilt) pieces having compared them to AutoZone and finding them to be somewhat better. Thicker/heavier boot material, larger shaft diameter, wider ABS reluctor ring.
    And spray the boots on the other side w/ aerosol silicon spray to slow deterioration and dry-rot. I do all my under-chassis rubber & neoprene this way at each oil change...CV boots, swaybar bushings, frame donuts, exhaust hangers. I have yet to replace a torn/failed CV boot so it appears to be working well.
  19. Aug 31, 2012 at 10:41 AM
    BamaToy1997
    BamaToy1997 ASE Master Tech
    Bill
    Navarre, FL
    Multi-point tow hooks, new bored 2.7L engine, custom paint. 3 inch adjustable Fabtech front coils, 2.5 inch rear AAL. Front Aussie locker. LED bed lights. Full LED conversion interior and exterior. Relentless Fabrication front and rear bumpers. 4X4innovation sliders. BAMF bed rack. CVT rooftop tent.
    The only problem I personally see with just replacing the boot, is you have no idea if any wear or damage has already been done. If the tear is recent, you can get away easily with a boot kit. That being said, sometimes it is worth the time and work involved to just swap out the whole CV shaft and keep the other as a spare.
