THIS IS FOR TOYOTA TECHS - got 2nd spiral cable replaced, now runs REALLY ROUGH!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by discoy2k, Feb 17, 2014.
  1. Feb 17, 2014 at 8:13 PM
    discoy2k
    discoy2k [OP] Well-Known Member
    DISCO
    NOLA
    05 TRDSport 3" Iron Man Coil, Stealth
    2005 to 2012 Front End Replace,2010 TRD Interior,6x Escort Shifters, Escort 9500ix, Escort LIVE w/ 4G Data, 100% Stealth on Interstate,De-Badged Completely,5% Tint Blacked out,Iron Man lift,InfraRed military Humvee Spots, Drive in 0lite,Lexus/Fujisu NAV, dual 8in lcd sun visors, 2 10" kicker solobaric dvc 2ohm, phoenix gold 2000 watt, lunar 100watt @ 1/4 ohm,3 farad cap kicker 250watt,2800watt ,TRU-SINE inverter, dual HID bulb+HID fogs w/ mod, Roof rack,Westin Bull Bar, Manik Side Bars, Sirius/XM (HACKED) Undercover Bed Cover, bosch Wipers, Iridium Plugs, Undercover Bed Cover
    the first time and second time (done saturday) i said don't touch ECU! but this time when i picked it up it seems to run relly rough, not as responsive. they say they did not touch ECU, but i remember a toyota tech saying they had to if they did the recall work? is there a way i can check to see if they did reprogram it? if i understand correctly if the ecu is updated the brake overrides the gas pedal, so if i can still "power brake" like lock the brakes and spin both rear tires on dry pavement does that mean it still has old program?
    can i read anything on OBD reader that will tell me?
    side note - the first time they did the recall or first notice i got which was MANY years ago, it was about the same time i got the acceleration notice, i was bringing it in anyway to have diff/trans/motor oil changed so i did it al at once. the oils and the 2 recalls, but at that time i had no symptoms of the bad spiral cable. but the dealer i brought it to was the same dealership we bought about 25 cars/trucks new from over the previous 10 years so they i am sure of it did what i said, DONT TOUCH ECU! this dealership was about 200 miles away and i dont trust/distrust/know them?
    i know tacomas have the ECU breakin per say where it 'programs itself' sorta, would this be a symptom of that happening?
    i just need to know if the ECU is a possible reason, because it is AWFULLY suspicious that RIGHT AFTER I LEAVE after the spiral cable was replaced it runs extremely rough. like shifts at different rpms than before, hesitates more, i mean i used to be able to 'floor it' and it but your head back, now it like 'steps' up???
    also, symptoms i had when cable did fail, was OBD codes on failure of seat sensors, squibs, and horn intermittently stopped working. the cable is a BIG DEAL!
    cheers,
    disco
  2. Feb 17, 2014 at 8:43 PM
    ralphyc517
    ralphyc517 Member
    miami, fl
    2014 DCSB Silver
    they disconnected the battery to do the spiral cable replacement, resetting the ecu. you will need to clean your throttle body and drive it till it (ecu) relearns everything.
  3. Feb 17, 2014 at 8:46 PM
    adanfon
    adanfon YNWA
    Adán
    Hanford, CA
    '11 Tacoma DCLB 4x4
  4. Feb 17, 2014 at 9:17 PM
    discoy2k
    DISCO
    NOLA
    THANKS GUYS!
    I was worried for a second there!
    just curious, does the way you drive in the learn period matter? meaning how do i get the best performance (if it makes a difference) gas mileage doesn't matter just performance.
    cheers,
    disco
  5. Feb 17, 2014 at 9:27 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Drive it like you always do...
