This is not suppose to happen!!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by chickon1, Mar 20, 2021.
  1. Mar 20, 2021 at 4:47 PM
    chickon1
    chickon1 [OP] Member
    steve
    2013 Tacoma
    6" BDS lift. Fox 2.5 coilovers 33x10.5 17
    SO got rid of the 35s today with some new 33s DuraTracs and now when I hit around 65mph, there is a horrible low noise vibration that seems like it's coming from the front passenger side under the truck.
    It seems like it is wind related but really can't tell..(still there if I put it in neutral or let off the gas) the vibrations feel and sounds like a body panel is going to fly off or something the faster you go. There is really no vibration in the steering wheel either..
    I'm wondering if with the small/thinner tire, with a 6 inch lift there is too much air getting into the wheel wells now? A lot of the plastic was cut out for the rubbing with the 35s.. but never experienced anything like this with the 35s on there.
    I plan on lowering the coil overs about an 1 to 1 1/2 soon.
  2. Mar 20, 2021 at 6:45 PM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    To rule out anything mechanical related to the wheel/tire combo, you could switch the fronts with the rears and see if the problem goes with it.
    Vishnevian and chickon1[OP] like this.
  3. Mar 20, 2021 at 6:48 PM
    toyrunner
    toyrunner Puddle Jumper
    Danny
    Pasadena, Ca.
    2004 4X4 Tacoma TRD Xtra Cab
    Kings in front, Bilstien Reservoir rears, Custom sway bar disconnects, 265/75 16 BFG AT's, ARB front bumper and FROR rear bumper. Bao-Feng 2 meter radio and Cobra CB
    My 1st gen made a terrible sound randomly at higher speeds. Turned out to be the inner plastic liner oscillating in the wind! It was a terrible sounding noise. Cut it back so it wasn't loose anymore and no ore noise! Hope this is your problem as well.
    chickon1[OP] likes this.
  4. Mar 20, 2021 at 7:10 PM
    chickon1
    steve
    2013 Tacoma
    This doesn't do it randomally.. it's every time I hit 65-70.. depending on wind too. I'm going to take off the skid plates first.. then start duct tapping!
  5. Mar 20, 2021 at 7:11 PM
    toyrunner
    Danny
    Pasadena, Ca.
    I would check the plastic. Its way easier than dropping a skid plate or two!
  6. Mar 20, 2021 at 7:55 PM
    ryfox0276
    ryfox0276 Well-Known Member
    Montana
    2013 RC 4x4
    Sounds like a tire balance issue. I've heard duratracs can be a b!tch to balance.
  7. Mar 20, 2021 at 9:21 PM
    chickon1
    steve
    2013 Tacoma
    That's what I was thinking but it got worse when I encountered like a strong wind at lower speeds, which made it worse. My 35s weren't balanced worth crap, I know what that feels like
  8. Mar 20, 2021 at 9:52 PM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    Check the plastic first,make sure its all secure.Simple things first.
  9. Mar 20, 2021 at 10:00 PM
    chickon1
    steve
    2013 Tacoma
    The reason I'm thinking it's metal because there is no way plastic could make this kinda of noise or vibration. It's like a really low bass sound.. almost like a "vibrator" sitting on metal..starts really low then get real intense like front body panels of the truck are going to fly off. Gonna switch the tires around too..
  10. Mar 20, 2021 at 10:06 PM
    lynlan1819
    Tacoma
    Lifted
    Start with your skid plate then first.
  11. Mar 20, 2021 at 10:11 PM
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    Def check the skid plate. Was with a guy a few months back had a similar issue and his skid bikes were loose vibrated like crazy and was loud. random but def something to look at.
    Also I would check your drive shaft and related parts make sure nothing is loose.
    only other think I had before was my exhaust used to bang my skids and was really mount. Had to remove skid and cut out a spot where it was rubbing the skid.
  12. Mar 21, 2021 at 11:03 AM
    chickon1
    steve
    2013 Tacoma
    I'm pretty sure it is the carrier bearing.. It is pretty easy to move and the rubber looks like it is shrinking. I checked it a couple months ago, had a little play in it.. I'm thinking this has probably been there, just with the smaller, smoothers tires, I can actually feel it now. I rarely even went over 65mph with the 35s because it was so horrible to drive.
  13. Mar 21, 2021 at 1:11 PM
    Crosis
    Crosis Tertiary adjunct to unimatrix 01
    Dunedin Fl
    09 Tacoma 4x4 TRD Off Road
    Should we ask how he knows what a vibrator sounds like? :rofl:
    Jimmyh and ToxicTwin like this.
  14. Mar 21, 2021 at 1:13 PM
    sorevilo
    sorevilo Well-Known Member
    Maybe the wheels bearings?
  15. Mar 21, 2021 at 5:35 PM
    chickon1
    steve
    2013 Tacoma
    I knew that was coming..
  16. Mar 21, 2021 at 5:37 PM
    chickon1
    steve
    2013 Tacoma
    Could be anything at this point.. there is zero play in the wheels, ball joints, new outer tie rods.. I'm got the center bearing out.. It's all tore up, but from what I read, seems like it might not be the issue. We will see.
  17. Apr 13, 2021 at 5:24 AM
    chickon1
    steve
    2013 Tacoma
    The vibration was from the prinsu roof rack.. This was a painful process to figure out.. lots of panels, plates removed and duct tape.
    Seems to be a common issue with these roof racks and have have all the" fix actions" to stop it.
    I removed the wind deflector and it fixed the issue.
    deanosaurus likes this.
