This Is The Strangest thing???
Discussion in '1st Gen. Tacomas (1995-2004)' started by MapleMoose, Apr 6, 2011.
  1. Apr 6, 2011 at 10:11 PM
    MapleMoose
    MapleMoose [OP] Drunk Canadian
    Ian
    West Kootenays
    1996 Tacoma SR5
    3" Eibach Coils, 3" AP Springs, AP 6" Shackles Toytec Diff drop, BAMF Sliders, Deck plate mod,Volt meter, Highbeam mod, PIAA fogs, 18" Magnaflow, LED dash swap, Color matched Satoshi Grille, Custom Rear Plate Bumper
    Ok, so i just did my front brakes tonight and after i finished i jump into the truck to test them out when this happened.
    I didnt even put the key in and i put my foot on the brake and my dash lights, front parking lights, clock, CD, and my chime goes off. But only when i tap the brake. Very strange... never happened before.
    I didnt touch any wires while doing the brakes.
    Any ideas?
  2. Apr 6, 2011 at 10:14 PM
    Camo23
    Camo23 Well-Known Member
    Drew
    Fallbrook, CA
    08 DC 4x4
    Not much yet
    battrey dead?
  3. Apr 6, 2011 at 10:27 PM
    MapleMoose
    Ian
    West Kootenays
    1996 Tacoma SR5
    nope, just drove home from work.
  4. Apr 6, 2011 at 10:31 PM
    Camo23
    Drew
    Fallbrook, CA
    08 DC 4x4
    Not much yet
    hmmm idk then maybe a blown fuse?
  5. Apr 7, 2011 at 5:55 AM
    EnolaGaia
    EnolaGaia Well-Known Member
    Midwest USA
    '01 & '04 S-Runners
    01 SR: Double Cab conversion, S/C, lowered.
    You've probably got some sort of short involving the taillight circuit.
    One possible cause could be a wiring fault or bulb failure in the rear lamp(s).
    A short in the engine bay fuse block (stop, tail, and / or panel fuses) and / or those fuses' circuits' wiring would also explain it.
  6. Apr 7, 2011 at 7:57 PM
    MapleMoose
    Ian
    West Kootenays
    1996 Tacoma SR5
    Thats what ive been hearing from mulitple sources. Doesnt make sense though, when could that have happened?
    Thanks for the help
  7. Apr 7, 2011 at 8:10 PM
    newskooler
    newskooler Well-Known Member
    Nick
    Lake Shastina,ca
    03 Tacoma x-cab TRD SR5
    881/5100 front, 5100 rear, AAL, K&N intake, Diff breather, grey wire mod, tg Low pro and sliders, Custom tube bumper, pinch weld mod, and more... smoked taillights, fabtech tire carrier, sony headunit, 12v always power mod, #70 unhappy clutch spring mod,
    this happend to a 4runner that my girlfriends mom had. we never could figure out why. :confused: im definately interested in a solution.
    oh ya and it only had 300k on the OD
  8. Apr 8, 2011 at 7:55 AM
    EnolaGaia
    Midwest USA
    '01 & '04 S-Runners
    The reason you've heard it from multiple sources is because it makes perfect sense (as a diagnosis). How it got that way is a different issue.
    Check the engine bay - and particularly the front corner lamps - to see if you somehow messed up a ground wire or shorted the corner lamp wiring while you were working on the front brakes.
    Then again - it might simply be a coincidence.
  9. Apr 8, 2011 at 7:56 AM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    it could just be coinsidence, it has to be a wire. one time every time i hit the brake my blinkers came on?? it was so weird.... but it was just wire touching metal.
