This is why I change my own oil!
Discussion in 'Florida' started by TacoTRD78, Aug 21, 2018.
  1. Aug 21, 2018 at 2:42 AM
    TacoTRD78
    TacoTRD78 [OP] Well-Known Member
    Stuart,fl
    15 tacoma trd off road
    4X Innovations Sliders Tech deck Bilstein 5100's OME 885 CB radio install Rear diff breather mod After market front bumper lights Redline hood struts Shorty antenna door seal protectors Glove box/ Center console motion light Trailer harness plug relocation mod/Edit SOS HC rear bumper Ditch mount Lights with CBI brackets morimoto fog lights
    Walmart Employee Botches Oil Change After Filling Up Wrong Hole
    August 20th, 2018
    Post Categories
    You should always check reviews and references before taking your car into a shop whether its a mom and pop or a Walmart. Because something like filling up the wrong hole during an oil change could end up costing you thousands of dollars.
    That's exactly what happened to this Sacramento woman a few years ago. She took her car in for a basic service and the technician who handled it ended up botching the job...big-time. After draining the oil, the technician put the drain plug back in and filled up the engine again. All sounds good except instead of putting the liquid in the correct receptacle, filling up the engine with oil, he poured it in the opening for the transmission fluid. Not even kidding.
    The woman says that instead of offering to make things right and paying for the damages, the retail giant stalled getting her a rental car and offered her only $4400 instead of the $7500 that she asked for to repair damages. Talk about making a mess of the whole thing.
  2. Aug 21, 2018 at 3:04 AM
    Cullen@GotExhaust
    Cullen@GotExhaust Well-Known Member Vendor
    Cullen
    Virginia
    White 2019 Tacoma TRD Off-Road
    Stock
    I work at a Chevrolet dealer during the day, we just put an engine in a Honda two weeks ago that came from Walmart. Employee double gasketed the oil filter, causing it to leak out the oil and the cam to seize.
    TacoTRD78[OP] likes this.
  3. Aug 21, 2018 at 3:27 AM
    TacoTRD78
    Stuart,fl
  4. Aug 21, 2018 at 3:43 AM
    Cullen@GotExhaust
    Cullen
    Virginia
    Stock
    :annoyed:
  5. Aug 21, 2018 at 3:49 AM
    Taco302
    Taco302 Well-Known Member
    Greenbow, Alabama
    2003 2.7L 5 spd 4x4 xtracab
    Yeah..every time you remove the old filter always make sure the gasket is intact. This happened to me once while doing an oil change. When i started her up i heard oil spraying and sure enough the old gasket was in place. No damage but had to buy more oil.
  6. Aug 21, 2018 at 3:56 AM
    Cullen@GotExhaust
    Cullen
    Virginia
    Stock
    It can happen to the best of us! Of you dont already know to check it then by the time you realize what's happened it could be too late. Or atleast cause you to buy more oil. If youre lucky
  7. Aug 21, 2018 at 3:59 AM
    TacoTRD78
    Stuart,fl
    I have never experienced the gasket not coming off with filter. Is the result of it coming off the filter do to over tighting?
    Cullen@GotExhaust likes this.
  8. Aug 21, 2018 at 4:07 AM
    Grossomotto
    Grossomotto Complete 3rd Member
    39.9526° N, 75.1652° W
    2017 4WDV6LB6MT
  9. Aug 21, 2018 at 4:10 AM
    Cullen@GotExhaust
    Cullen
    Virginia
    Stock
    It can be that, in my experience it's mostly from not lubing the gasket with fresh oil before installing but over tightening can do it too!
  10. Aug 21, 2018 at 4:12 AM
    TacoTRD78
    Stuart,fl
  11. Aug 21, 2018 at 4:14 AM
    TacoTRD78
    Stuart,fl
    Yeah I always add a lil bit of the lube on the seal and usually just hand tighten the filter with like a half turn with a wrench.
  12. Aug 21, 2018 at 4:17 AM
    Taco302
    Greenbow, Alabama
    Yup, that's what I did..sometimes you get a faulty one. Always ALWAYS check for the gasket.
    TacoTRD78[QUOTED][OP] likes this.
  13. Aug 21, 2018 at 4:28 AM
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
    Though I wouldn't personally allow a Walmart "technician" to lay a hand on my vehicle.....I know lots of people who've had oil changes done there for years without incident.
  14. Aug 21, 2018 at 5:00 AM
    Rattletrap66
    Rattletrap66 (ノಠ益ಠ)ノ彡┻━┻
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    2014 TRD Off Road DCSB
    ╭∩╮(ಠ۝ಠ)╭∩╮
  15. Aug 21, 2018 at 5:17 AM
    Plain Jane Taco
    USA
    Now....on a some what related note....I know of a few relationships that have been botched after filling up the wrong hole. :notsure:
  16. Aug 25, 2018 at 6:27 AM
    Grey 2015
    Grey 2015 Well-Known Member
    Skip
    Loxahatchee Florida
    2015 Tacoma
    Had one of those quick change place botch the wife's car many years ago. They topped off the brake fluid with the wrong shit ruining the entire brake system. Thank God I kept the receipt showing they had added brake fluid. That cost them a pretty penny.
  17. Sep 9, 2018 at 4:21 PM
    Killowatt
    Killowatt Well-Known Member
    Citrus County Florida
    2013 4x4 TRD OFF ROAD
    My neighbor just had an engine rebuilt after an oil change, drain plug was loose and the oil drained out over a few days.
  18. Sep 9, 2018 at 4:48 PM
    TacoTRD78
    Stuart,fl
    Who reccovered the bill of tbe rebuilt?
  19. Sep 9, 2018 at 5:05 PM
    Markcal
    Markcal Well-Known Member
    I worked with a woman who had the wrong oil filter installed on her mini-van, costing the fast lube place the cost of a new engine.
  20. Jul 28, 2019 at 8:27 AM
    Kevins60
    Kevins60 axle wrap tells me my rear brakes are working
    Kevin
    Odessa FL
    ‘04 4cyl SR5 AT Pre-runner Garage Queen
    SCS Cruise Westin step bars Lund tonneau Jensen HU
    I know this is an old thread but I fixed an oil “leak” on my ‘04 two weeks ago. Just got the truck in April and one of the things that prompted me to buy it was the dozens of receipts the PO had for oil changes from various places, the last of which was from about a month before I was buying the truck and there was only 40 miles put on the truck since that last oil change.
    Flash forward... A few weeks back I noticed that the truck was leaving a few drops of oil on the garage floor so I degreased the pan and discovered the drain plug was leaking and even better, there was blue permatex around the plug that I missed seeing before I bought it. So I just knew (assumed the worst) that the threads on pan were stripped so I loaded up on everything I would need to drop the pan and tap if for a larger drain plug. To see how bad the pan was stripped I torqued the plug to 27 ft-lbs. and discovered that the pan wasn’t stripped, the f-ing plug was hand tight! And judging by the solid 1/4 inch of oily crud built up on the rear skid that I scraped off with a putty knife, none of these oil change places ever removed the skidplate to change the filter.
    Moral of the story? No one will ever service my Tacoma but me.
