This misfire is gonna be the end of me.
Discussion in '1st Gen. Tacomas (1995-2004)' started by Thetantaco2004, Aug 15, 2025.
  1. Aug 15, 2025 at 1:41 PM
    Thetantaco2004
    Thetantaco2004 [OP] New Member
    Max
    First gen Tacoma 2.7L
    CAI borla exhaust
    Okay so I’ve been chasing this misfire for about 3 months now on my 3rz-fe in a 2004 Tacoma. The spark plugs and coil packs were replaced. The injectors were replaced. The miss fire happens at 1500-1600 rpm when slightly accelerating in any gear. Stft says it’s pulling fuel when it’s happening. Almost -19%. New to the Tacoma world
  2. Aug 15, 2025 at 1:47 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Mileage?
  3. Aug 15, 2025 at 3:24 PM
    nzbrock
    nzbrock Well-Known Member
    Noah
    San Marcos, TX
    99 TRD Prerunner 3RZ
    compression check? check the valve clearance?
    Did you replace the injectors with OEM? If you didn't get quality injectors, you will probably need to swap them again.
    t0p_d0g likes this.
  4. Aug 15, 2025 at 10:44 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Do you get a code for what cylinder?
    Multiple cylinders?
  5. Aug 15, 2025 at 10:56 PM
    Thetantaco2004
    Max
    CAI borla exhaust
    It’s throwing no codes
  6. Aug 15, 2025 at 11:00 PM
    TnShooter
    Deogee
    STOCK
    If you have a scan tool, maybe look at misfire counters.
    Toyota is pretty lenient on the number of misfires before it sets a code.
  7. Aug 15, 2025 at 11:00 PM
    Thetantaco2004
    Max
    CAI borla exhaust
    I got oem injectors. I am fairly confident it’s not compression because It happens at any gear at 1500-1600 and then comes back like nothing ever happened. But I could be wrong. Ill still check it out
  8. Aug 15, 2025 at 11:02 PM
    Thetantaco2004
    Max
    CAI borla exhaust
    130k
  9. Aug 15, 2025 at 11:28 PM
    Glamisman
    Glamisman Well-Known Member
    See if she has the mis before the system goes into closed loop. I am thinking this might be an O2 sensor issue. You could alway unplug the front O2 and see if that changes it.
