This or that. Tranny question.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MachTac, Jun 14, 2015.
Should I replace the clutch or do only what is needed?
  1. Replace Clutch
    1 vote(s)
    100.0%
  2. Wait Until It Needs Replaced
    0 vote(s)
    0.0%
  1. Jun 14, 2015 at 3:59 PM
    MachTac
    MachTac [OP] Well-Known Member
    Kody
    MD
    Storm Trooper in boot camp
    2'' Spacer Lift 15% Tint Thrush Turbo Muffler It's All About That Bass STICKERS!
    I have the dreaded t.o. chirp which has gotten progressively worse in the past few weeks. It when from a chirp to a whine while driving. So going with the URD t.o. kit but unsure whether I should replace the clutch while I'm in there. Money is tight but I also don't like doing projects more than once. I would be going with the Aisin replacement clutch to keep the stock feel. Current clutch is absolutely fine right now but It has 105xxx on it. Should I bite the bullet or hold out until I need to replace it? Like I said, money is tight.
    Thanks
  2. Jun 16, 2015 at 7:13 AM
    Mfreund1
    Mfreund1 Well-Known Member
    Eastern Ia
    2007 SR5 Sport
    If you are doing it yourself, may let it ride after inspecting. If you are paying for install definitely do it now.
  3. Jun 16, 2015 at 7:17 AM
    Larry
    Larry CARL
    CARL
    man...I was afraid to click...
    figured it was a Bruce Jenner thread. :laugh:
    MachTac[OP], Capt Jrod and VandalTaco like this.
  4. Jun 16, 2015 at 7:52 AM
    Capt Jrod
    Capt Jrod Well-Known Member
    Jarrod
    Northern Ohio
    15 WHITE DCSB 4x4 TRD SPORT
    I was gonna suggest the pre-game reach around. Always best to be sure.
    As for the clutch... I was always taught to replace it. Problem is which brand to use. OEM is usually best.
